Shoe recommendation
Shoe recommendation
After owning a variety of shoes, both 2 bolt SPD and three bolt, I have found I prefer the 2 bolt/"mountain bike style" shoes. They are just plain easier for walking when off the bike.
I currently have the Giro Republic. There are 2 bolt and lighter than traditional mountain bike shoes. The issue is that the Giro Republic has laces; these are a pain to lace-up and occasionally the loops of the laces have gotten caught in the chain rings. So, what I am looking for: 2 bolt SPD style, with the BOA style tensioners, which are also light weight.
Any good recommendations?
Thanks. .
Thanks. .
Randomhead
Liked 3,698 Times
Not Boa, but I have the giro privateer HV model and I like them a lot. I recommending buying up a size
Randomhead
Liked 3,698 Times
I probably could fit a 44 and use a 45. My street shoes are size 10, which are also a little big. I always used to buy 9 1/2.
Quoted: 18378 Post(s)
Liked 4,512 Times
Many of my Shimano shoes have a velcro strap that can go over the knot, and help keep it out of the spokes. Or put the loops into the velcro.
I think Lake makes some very lightweight, very stiff carbon fiber SPD style shoes with the BOA.
Lake also sells half sizes.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Around here, by far the most popular rando shoe is the Sidi Dominator. Almost universal. I find them very comfortable, very durable, plenty stiff enough.
Results matter
Results matter
Specialized has redesigned the "Expert" since I bought mine so I'm not sure if they're comparable -- mine were velcro, now they've got BOA, but I'm quite happy with them so the modern version is probably worth a look.
Quoted: 1217 Post(s)
Liked 187 Times
I also like the Giro Privateer R HV. The rubber sole for the newer models is much better than the plastic/nylon one on the model I have from 2013. I'm a 47 for Giro and that's the same size I have in both regular and HV. The HV is incrementally larger and honestly I couldn't tell the difference between the regular and HV until I put some miles into the HV and it bedded in.
Liked 4,512 Times
For moderate winter riding, the Shimano MW-81 is also a good shoe. High top, neoprene. Velcro closure. Comfortable enough for longer rides.
Jedi Master
My next pair of shoes will be Dromarti if my Dominators ever wear out.
Randomhead
Liked 3,698 Times
If I got Dromartis, i would feel compelled to keep them polished.
On a lot of the rides I do, walking is pretty common. I like the walkability of mountain shoes.
Quoted: 2604 Post(s)
Liked 1,933 Times
Jedi Master
Bikes: Fuji Jari Carbon 1.1, Honey Winterando (made by Seven), Litespeed Arenberg
Quoted: 11 Post(s)
Shoe recommendation
I have been using Lake MXZ 237. They come in normal and wide widths and half sizes. They have a carbon fiber sole. Only downside is the rubber on the heel wears down but I fixed that with Shoe-Goo. They are kangaroo leather and can be stretched a bit. They Sidi Dominators which is a shoe a lot of my friends ride did not work for my foot shape. They have a fairly decent width/height in the toe box. I replaced the insoles with a pair of Sole one's which are heat moldable and of better quality.
Jim
Jim
The CX332 by Lake is a mere $550....seems reasonable for a pair of shoes.
Liked 4,512 Times
E-Bay is your friend.
I think my experience is that the Lake shoes tend to run slightly large (by metric sizes).
I put a lot of really nice km in last year with a pair of Bontrager Cambion... boa and a velcro down by the foot box. Sole is pretty stiff and it's not over-aggressive looking like some MTB shoes are. They feel much lighter than the shimano m163 shoes that I was using, I was using shoes a bit too big since I couldn't find them wide enough for me. The Bontragers were nice in that they were wide enough without having to size up... and I also had an LBS that was very willing to order shoes to try on and they had a comfort guarantee... I ordered the shimano shoes from CRC so it was a pain exchanging them and waiting for the bigger pair to come.
Randomhead
Liked 3,698 Times
The soles on the privateers are not all that stiff. I was a little worried about the Giros because of that, but it makes walking a lot nicer and I think they may be the only shoes I have ever owned where I haven't experienced hot foot. I attribute that to the amount of room in them, not the soles.
I know my feet start swelling like clockwork at 95 miles. I have some lake cx carbon soled shoes that have very stiff soles. They are pretty nice but they give me hot foot once my feet start swelling.
Have a Shimano TO 92 shoe SPD but not a lugged sole.. uses the replaceable nut plate, so a bit of ingenuity will help male the insole better..
Velcro strap closure...
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
"Walkability" is nice, but I would rate comfort far higher. My first couple of brevets had my feet in agony before the ride was even over, and you don't have a lot of other contact points to shift the load to once they start aching or going numb...
Randomhead
Liked 3,698 Times
do you know what was causing the problem? I am pretty sure any shoe that has caused me problems was too tight, at least late in a ride. I also had some toe covers that caused me no end of pain, took me nearly 400k to figure that out. I had used them plenty of times before without issue.
Other than the foot itself, a shoe can cause problems at the ankle. I think I had problems with that on one pair of shoes.
