Noisy drivetrain the norm with oval chainrings?
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
I just installed Absolute Black oval 48-32 chainrings on an Ultegra 8000 crankset on my gravel bike. I was told shifting would be a bit slower but not noisier. After five rides, two mechanic adjustments, the problem persists. The drivetrain is quiet when the chain is in the middle cogs but gets noisy on the edges on both rings. Is this normal or do I need a better mechanic?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
If it is a rhythmic noise in timing with the shape of the oval, chain rubbing the cage as it is pedaled then check that the front derailleur cage is parallel to the chainring and not angled.
I have AB 46/30 oval rings on Ultegra 6800 cranks. The FD was set up with the cage slightly angled relative to the ring. Noise was significantly reduced when the front derailleur was set parallel to the rings instead.
It still isn't perfect but I also run an XT 11-42 cassette with the B screw turned around so all bets are off for me.
Nice kitchen, by the way.
-Tim-
-Tim-
Quoted: 4206 Post(s)
Liked 3,867 Times
Where is the noise coming from is the real question. If it's chain rub on the ft der cage then one would hope that "adjustments" would reduce or eliminate the noise. If coming from the meshing of the chain onto the new rings' teeth (as I suspect is the case) then avoiding those cog/ring combos, trying various different chains (as in brand), or tolerating the noise as the teeth wear in more are the likely choices.
Of course this assumes that you're not meaning a cross chained combo as they really should be avoided if possible. Andy (whose kitchen is being updated as this is written).
AndrewRStewart
AndrewRStewart
- Soli Deo Gloria -
Liked 736 Times
Bianchi bottles next to the sesame oil are a nice touch.
I need a new toaster.
-Tim-
-Tim-
Friendship is Magic
Bikes: old ones
Quoted: 26420 Post(s)
Liked 10,380 Times
...I run a couple of oval chainrings, but I don't run any of them on the largest position. Mine run quietly. You might try replacing the largest chainring with a round one and see if that solves your problem.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
-Tim-
-Tim-
The problem is that the cage has a taper that causes some light contact with the chain as the oval ring decreases in diameter. If I adjust in extra clearance on the inside, shifting is slower. Getting it precisely adjusted is a learning curve.
