Looking for 2X crank for my gravel bike
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Right now I have a Shimano Ultegra 8000 crank with Absolute Black 48-32 oval chainrings. I hate them! The drivetrain is noisy except in the middle cogs. I've had three of the best mechanics in town dialing in the front derailleur without much success. All three mechanics hate oval rings. So now I'm looking at the Easton EC90SL (46-30), Shimano GRX 810 (48-31), and Praxis Zayante M30 Carbon 48-32. My bike is a 2019 Giant Revolt Advanced 0 with Ultegra drivetrain. The crank/chainrings need to play nice with Shimano Ultegra front derailleur.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
im not an expert ,, but i usually just run a compact double sram gxp , i have a fsa crank in a hollowtech 2 BB. i assume your going from a triple oval ( interesting ) to a compact double ?
maybe your front mech is damaged or took a hit if its making noises it should not ??
maybe you could just try an ultegra crank or 105 ???
if you are doing gravel , i think it would be wise to focus on the crank more than the rings because then you can just get a bunch a rings to match your terrain and you will never be miss-geared on your rides , assuming you look at the route or do minor research into the terrain , elevation and such ...
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I can't help with the new crank selection but I can offer what I found through trial and error, that the front derailleur can't be angled with oval rings. The cage has to be parallel with the rings but even so, there will be some rub especially with larger range cassettes used for gravel. It isn't perfect on my bike but I am running an 11/42 MTB cassette.
Oval rings feel great to pedal but I'm having a bit of knee pain after switching to the oval rings. I've also resumed trail running so it is not possible to say which is causing the pain. Either way, I'm interested in the GRX 810 because of the higher geared 48 ring vs the 46 Absolute Black ring on my bike now. Going from stock Ultegra 50/34 to Absolute Black 46/30 has been great for bikepacking with a heavy load but I'm definitely slower on shorter, unloaded rides. The 48/31 should split the difference and give me back some speed and rub less.
GRX changes the chainline, no? Does anyone know if this requires the GRX front derailleur to be used or if an Ultegra FD will work?
I've seen the Praxis on a Trail Donkey 3.0 but can't offer any advice.
Please let us know what you decide on and how it works out. I'm interested in your experience and how it pans out.
-Tim-
-Tim-
I went from XT 1x to Zayante Carbons.
Praxis was around the same price as XTR and I wanted a Q closer to road.
I also think they were the second lightest cranks I looked at (XTR, Dura Ace). I think Force1 was a bit lighter. Not a SRAM guy.
From what I read, Praxis had an excellent reputation for shifting. This was a factor in case I was going back to a 2x.
I also liked the 'modular' thing with the spider and rings, and the availability of third party rings.
Installation was easy; BSA, just follow the instructions and watch the size of the dust covers.
Cranks and BB come with everything, including some crank arm protectors (which I just found in the box!).
I got maybe 50 miles on them and so far no issues.
In the end I went with a 34t Blackspire DM ring.
Probably going to change my road bike over to Zayante carbons too.
Hope this helped.
Hope this helped.
I'm thinking about getting the FSA Energy modular crank Seems like a decent alternative. FSA also makes some other 46/30 cranks
Quoted: 32 Post(s)
Liked 8 Times
Are you running the RX clutched rear derailleur? If so, could that be the culprit? I ask because I'm running Ultegra 6800 with the Absolute Black oval rings (11-34/48/32) and recently my drivetrain began to get noisy too. Initially thought it was my bb or chain, but I traced it down to the clutch in the RX derailleur. I've had the AB rings for about a year now and while they don't shift as nice as the OE Ultegra rings, I do feel the benefit of the oval and the gearing really improve my riding to justify the slower shifting. If you decide to sell your set up, let me know.
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
When the GRX cranks become readily available, it's going to be difficult to consider anything else. Shimano cranks just work, IMO.
Likes For shelbyfv:
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
I use a Zayante crank on one of my road bikes, the aluminum model.
Assuming the carbon model works the same(safe bet), the rings are excellent and shifting is smooth and fast.
Chases Dogs for Sport
I rode nothing but Shimano cranks for 13 years . . . until recently. I went to an FSA Modular Adventure (46/30) crankset and I have been very happy with the results. The gearing is what I want but, to my surprise, the shifting (and lack of noise) is perfect. No real difference (shifting wise) between the FSA and the Shimano cranksets on my other bikes.
To go to the Shimano gravel crank requires not just the purchase of the crank, but also the purchase of a new front derailleur. That makes it an expensive upgrade. And I doubt it will be available as a separate component to the public until 2020. (I hope I'm wrong, but history has a way of repeating itself. Shimano tends to "introduce" things nine months to a year before they are generally available to the public.) As it is, I'm perfectly happy with the FSA. I won't be changing.
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
If you go from your current Shimano cranks to the Easton EC90SL crank, I believe you will have to change your bottom bracket out to accommodate the larger spindle of the Easton cranks. Maybe someone else here can confirm.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I've been happy with Ultegra 6800 cranks with Shimano 46-34 rings.
I've been using an R8000 FD with the Praxis Alba 48/32 and very happy. No noise, no shifting issues. It was also fine on the R7000 FD before I swapped.
Quoted: 376 Post(s)
Liked 124 Times
Sunshine
Liked 7,490 Times
Likes For mstateglfr:
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
For all of us running SRAM shifters made for Yaw type FDs, thus having no trim steps in the shift pattern, I sure hope it will work.
Bikes: 2014 Trek Domane 5.2c, 2015 Niner BSB 9 RDO, 2006 Scott Speedster S30
I have successfully used both the Easton EC90 SL 47/32 and FSA SL-K Modular 46/30 on my gravel bike. Both shifted fine with minimal noise on my Shimano r8000 series Di2 FD. I have kept the Easton crankset on my gravel bike, but that's due to power meter selection not something wrong with the FSA crank.
Quoted: 376 Post(s)
Liked 124 Times
I just ordered the Easton EC90 SL crank with their 46-30 chainrings. Looking forward to headache free rides.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Cinch-system chainrings are cute and easy to replace, but the tool to work on the lockrings are order-only items.
Likes For Marcus_Ti:
Quoted: 376 Post(s)
Liked 124 Times
Just be sure to pay attention to that torque spec. 50Nm is what their manual says. Nothing holding that crankarm on other than that torque. My FSA SL-K 46/30 is similar in that regard and has given 10K miles of faithful service (another user on BF had theirs come off, check that torque)
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Another reliable crank is the Shimano CX50 Cyclocross crankset. It has 46 & 36 chainrings. A wide range of 110bcd 34t chainrings will fit the inner position. A 33 chainring from TA also fits, as seen below. Ten speed cranksets are forward compatible with eleven speed chains.
https://www.chainreactioncycles.com/...CABEgJTsvD_BwE
https://www.google.com/shopping/prod...:1,prmr:1,cs:1
Likes For Barrettscv:
Bikes: Santa Cruz - Stigmata
Quoted: 13 Post(s)
Liked 13 Times
Also changed the 50-34 rings on the Ultegra to Absolute oval 46-30. Setting the FD was big pain in the ass!!! It took me hours to get it somewhat right, so that the derailleur has no rub in the smallest and biggest ring. Problem is that the Absolute chainrings are closer to the frame, so i couldn't move the FD all the way closer to the frame to avoid chain rub. When i managed to get it set i worked without any problems, but there is like a millimeter or lees space between the chain and FD.
Likes For DavidfGR:
