Fork/brake question
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times
Fork/brake question
I'm building a 26" mountain bike with rim brakes. I have a Marzocchi MZ Comp fork (I know, heavy, cheep, etc...) the frame is a steel talon frame so I was intrigued by the Italian fork. Anyway, the fork doesn't have the Canti studs for the brakes to attach to the fork. It has the braze ons but not the studs. I'm trying to find out the size, thread pitch or what ever it is that I need to get them ordered.
any help will be appreciated.
Frame for reference...
Quoted: 1188 Post(s)
Liked 1,154 Times
No idea if there is a standard, but the ones on my Surly are M10x1 . Take the fork to a bolt shop and see what screws in would be my advice....
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 669 Post(s)
Liked 725 Times
Apparently there are some exceptions to the 10 x 1 "standard," but I've never seen them. 10 x 1 is a fairly common thread size--rear derailleur mount, many QR axles--so it should be easy enough to check your bosses. Or remove one of the rears, see if it works in the front, and measure the diameter and pitch. (You may want to remove them anyway to strip the paint.)
Quoted: 4171 Post(s)
Liked 3,789 Times
Most all the pivot studs I've dealt with have a fairly coarse thread pitch. Like 10x1.25, 8x1.25. There are different threadings and, for the newbie, which is needed can best be confirmed by actual trial fit. I have seen the fork needing different posts then the rear stays did. A good service focused shop (that did a lot of MtB work) likely has a box/draw full of possibilities. Andy
AndrewRStewart
AndrewRStewart
Quoted: 109 Post(s)
Liked 234 Times
Thanks
Go to your local LBS, they probably have a box of them laying around as spare parts. Or they could order you some.
Liked 3,789 Times
I suppose one could ride their bike to a friendly hardware store (or other source) and trial fit common bolts into the fork/stay pivot bases to find out the specific threading. Then when the search for pivot posts is made there's no guessing. Andy
AndrewRStewart
AndrewRStewart
