Replace old component group on 1995 MTB?
Hi, I have an old 1995 Schwinn Sierra MTB that I'd like to modify somewhat. The component group on it is Shimano Exage 400 LX 7-speed with STI shifting. The brakes and shifters and such are all plastic and thus are really worn and I've even thought about replacing the Biopace crankset and possibly the whole drivetrain. I'll be giving it to someone else to use, and because of all the wear and tear (I've beat this thing up over the years - crashes, hard riding, etc.), I'd like it to be safe and easy to ride.
My question is, how do I pick a component group that will work correctly on this frame? I'm assuming that I can't just go buy a modern component group and install it, as the ones I've seen seem to be at least 9 speed. I would also like to find a group (even if I have to buy an older groupset) where the brakes and shifters are more sturdy than the cheap plastic that is on there now.
Also, it has 26" wheels. I appreciate any thoughts that you have.
Quoted: 1572 Post(s)
Liked 643 Times
If somebody else had replaced all of the parts you are considering and wanted to sell that bike to you, how much would you be willing to pay? Don't put any more money than that into it.
Honestly, what you are suggesting sounds to me like a recipe for converting a cheap old bike into an expensive old bike that has a few new parts.
Likes For Retro Grouch:
Quoted: 254 Post(s)
Liked 182 Times
Is there any co-op or nonprofit bike shop near you? I would try looking for cheap used parts that are in better condition than what you have, rather than buying new stuff. They can also help you figure out what really needs to be replaced vs just cleaned and regreased.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Ditto the co-op suggestion. Without looking at the condition of the headset, hubs and bottom bracket as well as shifters and brakes, it's really hard to tell what it might need.
Upgrading the rear wheel may require bending the frame and straightening the dropouts, which requires special tools and skills. You're probably stuck with a threaded headset. But upgrading to linear pull brakes and nicer shifters could be a good idea and economical, especially with good salvaged parts.
Likes For andrewclaus:
Quoted: 2026 Post(s)
Liked 1,096 Times
I'm going to post my usual "don't do it" recommendation. That Schwinn was a low line, cheap MTB when it was brand new and 24 years haven't made it any better. For what you will have to spend to modernize it you could pay a significant amount toward a far newer, more modern bike with better components. Craigslist usually has relatively new MTBs for sale at very attractive prices.
Unless you can find better components very cheap at a Co-Op and can do all the work yourself, this project can become a money pit for little gain.
I'm going to post my usual "don't do it" recommendation. That Schwinn was a low line, cheap MTB when it was brand new and 24 years haven't made it any better. ...
Really Old Senior Member
I can't find a 95, but the 93 & 94 Sierra's had Tange CR MO or Double Butted CR MO frames.
GOOD steel.
IF you are simply just giving this bike away, just service the rotating bearings & cables. Maybe new cables & housins if warranted.
Clean & relube. Maybe flush out the DER's.
See how it performs then before investing more $.
EXAGE was decent quality. If not worn out, it should perform fine. I think it's Deore level if not actually Deore of that era.
GOOD steel.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Shimano Alivio 3x9 drivetrain for $160:
https://www.ebay.com/itm/Mountain-Bi...-/253374039337
Or Acera for $140:
https://www.ebay.com/itm/SHIMANO-ACE...T/263789700602
Or you can spend more time shopping and get higher level but used components.
I'm pretty sure almost any 3x9 mountain bike drivetrain will work on a 90s era mountain bike.
Or Acera for $140:
Likes For tyrion:
GOOD steel.
GOOD steel.
I do appreciate everyone's input.
Quoted: 882 Post(s)
Liked 821 Times
AIR, the High Sierra was made in Japan and a relatively high-quality bike. Mine (with a 1500w electric system) has a combined TIG and Filet-brazed frame. I've had good luck with Altus-level rear derailleurs, cassettes and rear shifter ($20, $20, $10, respectively at Amazon). However, if you need to procure a new crank, I would consider a low end Shimano in order to keep the overall cost reasonable.
Likes For 2old:
