Big Chainring Size - What's your Preference?
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
I'm really liking a 48T on my Superior. I have it paired with a 12-23 8sp on the back.
Seems like this combo is really good for headwinds as well and I find myself using all the gears on the cassette.
I was considering moving up to a 50T, but I think I'll stay put.
Likes For thinktubes:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
One road bike, steel frame, has a 50 T with 14/25 cassette and another, titanium frame, has a 48 T with 12/27. I no longer have a need for 52/53 rings. They have plenty of high and enough low for my bicycle needs.
46. With an 11t cog, that's higher than the old 53/13 top. And I've hit 50mph descending in the Oregon Cascades with a 46/13 top.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
On my rando bike, 45T and shrinking. In 2014/2015, I had a 50/13 top gear that I never used but once in a blue moon. From 2016 'til a week ago, I've had a 48/13 that I rarely shift to, its only use is to soft-pedal on downhills and begin pedalling a bit sooner when the hill points up again. But even then, it's not long before I'm shifting down again, so it hasn't proved to be a valuable gear to have with me all the time. A 45/13 top gear splits the difference between that and my former next lowest gear, a 48/15. As someone who also rides a fixed-gear a lot, it's not a big deal to spin up a 72" gear to 25+ if the situation calls for it, so my plan is to eventually settle on a 44/30 crank for this bike.
My "go-fast" Bianchi is set up with a 49/42 crank and 13-21 cassette. I bought the 49T so that I could satisfy some OCD and have a perfect 100" top gear. But I never spun out the 48/13 it had before, and here again, I could probably go a lot smaller. Heck, the 42T would be sufficient on its own.
The '88 Bianchi which I haven't ridden in a couple years is set up with an old 52/42 crankset, and I was running a 15-24 freewheel on it last. The 92" top gear seemed totally adequate. I feel like I'm starting to repeat myself, so I'll stop there.
RUSA #7498
Originally Posted by noglider
Bikes: my precious steel boys
Quoted: 438 Post(s)
Liked 603 Times
realistically, I should swap out my 53-42 for easier climbing, but those fluted Record cranks just look so nice...
what's everyone's preferred option for a 48/39 (or something similar) on a vintage frame?
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Now at 60 years old, but still strong and fit, I'm comfortable with a top gear of 100-106 inches. I don't need anything higher, because I appreciate the ability to coast sometimes.
Liked 2,568 Times
(Images pilfered from VeloBase!)
RUSA #7498
Likes For ThermionicScott:
Quoted: 5888 Post(s)
Liked 3,471 Times
If running 5, 6, or 7 on the back, there are always trade offs. I like a 48 on the outside as I can spin it with the lower 5 of 7 but there is no doubt that you will spin out from time to time. As far as I know there are no freewheels currently being made that go as low as even 12 on the outside so the highest gear I can get is a 48 running on a 13 which gives me a 99.7 inch high gear. That works for me.
Quoted: 438 Post(s)
Liked 603 Times
Well, I'm currently going to swap for a 7-speed 13-28 to see if I can get up longer hills easier on the 53-42 but if that doesn't work, yeah, it's probably one of those Shimano cranks for me.
either that or spread the frame and put a brand new Potenza 11-speed set on it...
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,097 Times
I still like going AFAP down hills and I have some long ones around here so I find that 52 or 53 - 12 comes in handy for that. 50 tooth + 11 also works but I have to go modern for that. If I lived on flatter roads I wouldn’t need more than a 48-13.
@sheddle - 42-28 gets me up most of my hills, even the 15% stuff as long as they’re not too long and I’m not trying to ride over too many of ‘em.
Doesn't matter much to me. It's the final gear ratios that matter.
I like the current compact 50/34 with an 11-28 in the back. I was and still am also fine with the old standard 52/42 or 53/42 on old bikes with 5 or 6 speeds.
It is nice to have the increased range options of modern gearing. I almost never use my two lowest or two highest gears, but it's good to have them if needed. BITD with 6 speeds every gear had to be chosen carefully. No room for rarely used gears.
Quoted: 3241 Post(s)
Liked 2,512 Times
52/42/30 triple except for SOTR ride. I put on a 50/36/28 for that one.
Liked 2,568 Times
Liked 2,512 Times
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
I have set up many of my bikes for L'Eroica-type rides, which means hills, gravel and vintage racing gear.
I can't handle the 49-21 low gear Fausto Coppi supposedly rode in the Alps, but do stick to the format of a short cage rear derailleur and a double chain ring. To get the desired gear range with those (max cog size and max chain wrap usually no more than 28T) and a 14-28 freewheel, I want either a 48/34 or a 50/36 up front.
When out riding with mrs non-fixie, I often find myself pedaling around all day in the 50-20 combo on those bikes, as long as it's not too hilly.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I have a 28-38-48 setup, but the 38 is plenty big enough for me. Primarily because of bad knees, but I also like coasting on the downhills, when possible. 😉 Still, the 48 could prove useful coming down a mountain, so I'll leave it on.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
The largest ring I currently run is 50T, on my Trek 720 touring bike. I have several 48T rings, one on my S3X-equipped fixed gear, and two other road bikes. And 46T on my other fixed gear bike.
Quoted: 741 Post(s)
Liked 818 Times
I love my 52s. I have them on 4 vintage bikes, two have Megarange 34-14 6 speeds, and two are 28t-13 (I think) 6 speeds. I've tried 50s, but I like the 52t extended flat road cruising speed, while the 34t takes care of the hills. Of the two with 34t Megarange, one is a 52/40/32 triple, and the other is a 52/42 double. One of the 28t freewheels has a 52/42 the other is a 52/40. My modern bikes are 50t, one a compact 50/34, the other a 50/39/30 triple. Both modern bikes have 30-13 10 speed cassettes. For some reason, I feel the need for 52s when riding vintage, but don't miss them on the modern bikes. Back in the olden days I used to race on a 53/45 crank, and have never owned a bike with less than a 50t big ring.
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
On a road bike, I like a top gear in the mid-90s:
50/14 (Bianchi), 46/13 (1959 Capo), 49/14 (the "keep it original" Sieger), TBD (the "restomod" Sieger project), 45/13 (Peugeot)
I do run a 104 on the mountain bike: 48/12
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
As long as I have a hundred gear inches, give or take a few, I'm happy. Once I have that I'd rather add tight spacing than more top end I won't use. 53 or 52 up front with 13 or 14 out back is fine. 48 or 50 x 13 works too. I don't know why so many cassettes start with 11.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
My road bikes are all either 53T/39T or 52T/48T. I try to stay on the big wheel. My new Pista SS is a 48T with a 16 rear cog.
