Axle identification
Axle identification
Old 09-17-19, 02:51 AM
gate28
Quoted: 36 Post(s)
Axle identification
Hi Guys
I have a bent bottom bracket axle from a 90's Raleigh. It's a square taper. On it says WKK 3S P-10 and it's 125mm wide (not including the threaded ends that take nuts).
I cannot identify it online for replacement. Can anyone help?
Thanks
gate28 is offline
Old 09-17-19, 03:17 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
3S is what you need to know.
https://www.huskybicycles.com/mm5/me...t_Code=303-121
Bill Kapaun is offline
Old 09-17-19, 05:59 AM
gate28
Quoted: 36 Post(s)
Thanks. Does the 3S indicate the correct length as well? And what about caged bearings - are they identified by the 3S as well?
Appreciate the help.
gate28 is offline
Old 09-17-19, 06:27 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times in 430 Posts
This table shows the spindle designations.
The ball bearings are standard. Some suggest you get rid of the cages and add two more balls.
andrewclaus is offline
Old 09-17-19, 11:52 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2746 Post(s)
Liked 3,390 Times in 2,053 Posts
Personally if the cups (BB) are not the Raleigh proprietary threading, which it shouldn't be, I'd throw in an equivalent Shimano UN-55 cartridge unit and be done with it. Sheldon's stuff should show the Shimano cartridge equivalent. If you have to replace a spindle or cup the cartridge is the only way to really go
dedhed is online now
Old 02-15-21, 02:23 PM
gate28
Quoted: 36 Post(s)
That is a very good and in hindsight an obvious solution - which hadn't crossed my mind. Bike still in bits - but not for long! Cheers
gate28 is offline
Baby Puke
Track Cycling: Velodrome Racing and Training Area
13
09-05-19 03:13 AM
HuffyAllUltegra
Bicycle Mechanics
6
04-27-18 07:47 PM
stryper
Bicycle Mechanics
6
10-25-14 02:07 PM
okane
Bicycle Mechanics
9
03-16-13 04:18 PM
Daveyates
Bicycle Mechanics
6
12-14-10 07:09 PM
