How much of a difference does tire width make on road bike performance?
I used to have an Cannondale with 23mm tires that had great performance but was difficult riding as almost any bump/crack in the road could affect the rims. I am considering purchasing another one since I have such fond memories of that one, but am wondering how much of a performance difference I could expect if I went with 28mm instead; or could I even go as far as 32mm?
Likes For Spoonrobot:
Quoted: 822 Post(s)
Liked 1,961 Times
Even going from 25mm to 28mm was immediately noticeable with less road chatter, less hand/shoulder fatigue and just more enjoyable on longer rides.
Performance, can't say I noticed a difference. Then again, I am just an average recreational rider.
I found that going to a wider tire (32) really improved my personal performance. I can go faster on average over a wider variety of road surfaces over longer distances with less body fatigue. I am also more confident in a variety of road and weather conditions and more confident going down hill and taking turns at speed. There is also a nice variety of super armored tires in the bigger sizes. You can pass people fixing flats (well, slowing to ask them if they need any help, of course).
Bikes: Giant Contend SL 1 Disc
Quoted: 156 Post(s)
Liked 78 Times
jag
Likes For sirjag:
Now, when I ride my bike with 28mm tires, I run 60 front/90 rear and the difference in feel for bumps in the road is very noticeable. Definitely a softer/smoother ride. On smooth surfaces it really makes little difference, but as you get to rougher surfaces you will gain by not being bounced around so much.
In terms of performance, buy top quality tires in whatever size you end up with, properly inflate them, and you will get very similar performance.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Depending on the model, you may not be able to fit 28mm tires.
Try 25, with a little less pressure.
Quoted: 427 Post(s)
Liked 700 Times
Here is an article that you may find informative--I sure did!: https://www.roadbikerider.com/the-ti...-jan-heine-d1/
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I would never even consider buying a road bike that could not clear 32s at a minimum, as that is the smallest I will probably ever run.
But that’s just me.
But that’s just me.
Likes For Kapusta:
Quoted: 17 Post(s)
The roads around here are poorly maintained. Broken asphalt and poorly performed patchwork(they really go for the lowest bidders here) everywhere. I won't ride with anything narrower than 30mm as it would slow me down and put me at a higher risk for mishaps.
If your riding surfaces are better it may not matter as much. As the poster above stated, check clearances. Even if you can't go up to a full 32, 28 will still make a noticeable difference.
Great article. I've had the habit of pushing my pressures toward the high end on my road tires. I think I'll back them off a bit and check my tires' response to laden force to gauge ideal pressure.
here's a video of a guy absolutely railing on 23mm tires at high speed
Likes For aclinjury:
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Tire type makes more difference in performance than size. A supple tire (Rene Herse/Compass) in any size, will beat a heavy flat resistant tire like a Gatorskin every day.
Having said that, if we are comparing identical tires in various sizes, rider weight needs to be factored in. As a feather weight at 135 lbs, I find the 28mm Chinook Pass to offer the best performance. I also have two bikes with the 32mm Stampede pass, which are also great, but I think would be better for heavier riders than me.
That depends on the tire\rim combo. My wife has a Trek 2.3 road bike, it came with 23's. she would pinch flat every other ride, even when I pump up the tire to 110+ lbs before each ride. I was making both of us crazy. I got her a set of 25's, no more snake bites.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
This has been debated endlessly, and the consensus shifting, since I began cycling and that's only been 13 years +/-
When I migrated from 700c-32 to smaller diameter higher pressure tires, no question the performance improved. Drifting back to wider tires, even better. Mine are all 26-28 now. It depends on the tire itself, and a tire pressure sweet spot for that tire.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
I'm a big fan of 25-28mm tires on road bikes. I find 23mm tires squirrely on imperfect surfaces. The slight weight/aero penalty for going up a size is more than made up for by the reduced road buzz and sure-footed crossing of cracks and gravel/sandy spots. Running lower pressures on a wider tire also increases your contact patch which is nice when crossing metal manhole covers or paint on wet days. I've got 25mm on my road bike and 32 on my mutt bike and the difference in average speed over 50 miles is less than 1 mph. This despite the fact that the mutt is a flatbar and about two pounds heavier.
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Huge. Bigger = better. I just test rode a Jones LWB with 29*3.0 tires and it rode better than anything with about 10-11 PSI.
Sub 50MM tires are for a sprint finish and not actually riding.
Others can fight me but the science bears this out.
True, as the actual mounted width will vary with tire/rim combo. Any pressure calculator is best used with a measured mounted width and weight to best reflect reality. Rider technique and road quality also plays into this. If your roads are such that you can't avoid hitting potholes, then a wider tire will always give you more protection. I'm curious what something like the Berto calculator would give you?
I think this plays a lot onto the actual road surface. I have seen it most on my gravel road riding. Started with 30-32mm tires on my gravel bike and was being bounced around a bunch. Switch up to a 38mm tire and suddenly I can pedal right over 99% of the bumps. More comfortable and faster. The right 50mm tire will even roll very fast. But, go too wide and you fall off the other side of the curve and while comfort may go up, so will rolling resistance.
Conversely, a local bike club has Tuesday night rides on a road course. It was just repaved last fall and only sees limited traffic when the venue races cars. The pavement is as smooth as you could ever wish for without a pothole or crack in sight, so I will add 10-20psi to my road bike tires without any ill effects.
Quoted: 1163 Post(s)
Liked 442 Times
Quoted: 1572 Post(s)
Liked 643 Times
The real benefit to skinny tires comes at higher speeds because they have less frontal area.
Likes For Retro Grouch:
Quoted: 874 Post(s)
Liked 2,288 Times
In theory, wider tires would be a bit worse in a head wind . For me , that has not proven to be true. I ride 28mm minimum tire width and in my area works good. As previously stated , the fatigue factor is huge. I have one bike left with 23's and it is going to get changed before the next long ride on that bike. My Super Mondia allows for wide tires and I am running 27 x 1.25" tires that , when inflated , check 1.390" . I like the wider tires for comfort and safety. It is less likely to catch a groove in the asphalt and much better on gravel roads. Joe joesvintageroadbikes.wordpress
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I see 28-32, maybe even 38 kicked around here as the consensus ideal width for road riding. This is absolutely not the case, you can go FAR wider and enjoy MUCH better efficiency at FAR LOWER psi. I would guess most of the commenters here have not ridden a bike with 29+ tires.
If you insist on getting another CAAD roadbike please know it's really a RACING bike engineered for a sprint finish, not actually made to be ridden in normal conditions. That said, if you're just in love with the aesthetics or whatever then I suggest getting 650b rims and running the highest tpi casings you can find in the maximum possible width at the lowest possible psi.
Unless you're training to compete in one of the Ground Tours, then you'll thank me later.
I started out commuting on a track bike with 28mm tires @ 50/60 PSI; I am now on a CX bike with 33mm tires @ 35-20 PSI (they're tubulars, very hi TPI count casing). The 29+ bike I just test rode absolutely SMOKES my CX bike even with it's hi-TPI/super supple sew up racing tires at very low pressure.
The only downside is you'll feel it in a sprint but if you're not trying to break away from a peloton regularly (you're not) then look at bikes built on the 27.5+ and 29+ platform. Don't ask me, ask science.
ps: I tried an experiment for a couple weeks where instead of topping off the tire pressure before each ride, I let it naturally deflate by that couple psi or so per day to see what the rides would feel like at progressively lower pressure. Based on the last time I'd checked the pressure one day I went out on a ride with an estimated 75psi or so in the rear (and less in front) and got a snake-bite flat hitting some bump in the road (think it was a big dip in the road surface around a manhole cover), with the tire going flat seconds later as I made a sharp turn and came the closest to totally eating it that I've ever gotten while actually recovering and not crashing. So for me, almost certainly due to the weight, using that 90psi max pressure for the Stampede Pass 32mm tire is non-negotiable. That's still much less than the 120psi or so I road on my 25s, and it feels much nicer.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
I can throw my weight behind this statement. I'm one of those heavier riders (270s right now, lowest I've been in forever was high 250s, heading back that direction right now), and I ride the Compass Stampede Pass 32mm tires. I run 90psi (listed max) on the rear and 80psi on the front. Not all of the roads that I ride are terrible surface quality, but some definitely are, and a couple stretches are downright awful with many large cracks in the road surface of over an inch width. When I got a road bike again around 9 years ago it had 23mm tires on it, and I almost immediately switched to 25mm and noticed a big difference in comfort. Went to 28mm on the rear but the front couldn't fit it (depending on the tire, and even ones that fit were just squeaking by). With my new bike a couple years ago (Lynskey R260) it'll fit not only these 32mm tires, but would fit larger if I wanted. I've considered giving 34mm a go, but these 32mm Compass tires are just a pleasure to ride on. There are stretches of road where the surface was so bad on the 25/28 combo I still had to slow down somewhat, where I can go full speed on the 32mm tires. I imagine the 34mm would just make the truly bad stretches of road that much more pleasurable to ride.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
- Lighter = they spin up quicker if you're in a sprint situation (less mass to get moving)
- Less rolling resistance on a drum testing unit or inside a velodrome (not real life riding situations)
If neither applies, then avoid.
Very Slow Rider
Quoted: 500 Post(s)
Liked 132 Times
Likes For davei1980:
