Quick detach saddle bag suggestions?
Old 10-02-19, 09:05 AM
Synack42
Quoted: 31 Post(s)
Liked 33 Times in 11 Posts
Just wondering if anyone could recommend a quick detach saddle bag that clamps onto the saddle rails? I've been using a Bell branded bag and the Velcro strap has been pretty horrible. I ended up using a bunch of Velcro cable straps around the entire bag in addition to the sewn in one just to keep it from falling off. I'd also like to be able to easily move it between bikes, so a permanently mounted clip might not be the best solution.
*I was eyeing Topeak stuff, but not sure how quickly the plastic clamp thing can moved around.
Thanks!
Synack42 is offline
Old 10-02-19, 09:24 AM
kingston
Jedi Master
kingston's Avatar
Bikes: http://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1210 Post(s)
Liked 71 Times in 59 Posts
I have several sizes of the topeak bags and the f25 fixer on a few bikes. It's not a bad system. Pretty easy to remove/attach the fixer if you need to for some reason. I also have a Rixen & Kaul KLICKfix Berthoud saddle bag that I move between two bikes. I like the topeak system a little better for small bags and the KLICKfix system better for larger bags.
kingston is offline
Old 10-02-19, 09:33 AM
Elvo
Quoted: 378 Post(s)
Liked 31 Times in 23 Posts
After using clip on quick release bags for years, I've found that the simple velcro design on the seatrolls works best:
https://roadrunnerbags.us/products/tool-saddle-roll
Elvo is offline
Old 10-02-19, 09:39 AM
jadocs
jadocs's Avatar
Bikes: Litespeed T2 Disc, Fondirest P4 Carbon, Fuji Cross 2.0, Specialized Fatboy
Quoted: 418 Post(s)
Liked 123 Times in 95 Posts
I've used the Lyzene (sp?) version. Don't use any saddle bag anymore. I prefer to carry my repair kit in my jersey's center pocket.
jadocs is offline
tagaproject6
tagaproject6's Avatar
Quoted: 511 Post(s)
Liked 170 Times in 92 Posts
Silca Capsule. I replaced my Topeak bags with these.
tagaproject6 is offline
Old 10-02-19, 01:11 PM
5teve
Quoted: 55 Post(s)
Liked 16 Times in 7 Posts
Ortlieb saddlebags. You can buy spare mounts too, to easily move it from bike to bike. https://ortliebusa.com/product-categ...cle-seat-bags/
5teve is offline
Old 10-02-19, 01:23 PM
eja_ bottecchia
eja_ bottecchia's Avatar
Quoted: 897 Post(s)
Liked 235 Times in 167 Posts
Check the SCICON line of saddle bags with the roller mount system.
I have used them in the past and like them a lot. I no longer use a saddle bag, so I don't need to use my SCICON. One of their best feature was the fact that one can easily move them from one bike to another. Another great feature is the absence of straps to damage bib shorts.
For those of us blessed with sprinter thighs, saddle bags with straps can quickly chew through most bib shorts.
https://us.sciconbags.com/saddlebags-frame-bags
eja_ bottecchia is offline
Old 10-02-19, 02:53 PM
mynewnchome
Bikes: Cannondale CAAD8 Raleigh Revenio 1.0
Quoted: 68 Post(s)
Liked 26 Times in 11 Posts
I have tried several bags....my favorite is the Lezyne model that's a clamshell.
mynewnchome is offline
Old 10-02-19, 04:28 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2405 Post(s)
Liked 93 Times in 80 Posts
No idea how much space you need, but the Arundel Dual is a single velcro strap and pretty quick to install. It's great for me. Holds 2 tubes, 2x CO2, Inflator head, tire lever, small multi-tool, pair of nitrile gloves, and a couple quicklinks.
Sy Reene is offline
Old 10-02-19, 04:54 PM
02Giant
Home School Valedictorian
02Giant's Avatar
Bikes: 13 Orbea Orca 02 Giant Cypress 88 Mongoose ATB 79 frame-built to 80 spec. Schwinn Traveller
Quoted: 869 Post(s)
Liked 68 Times in 47 Posts
Thanks!
Not sure what that means???
I've got Topeak saddle bags, in various sizes, that are easily moved from bike to bike.
I ain't broke and I ain't hungry but I'm close enough to care
02Giant is offline
Old 10-02-19, 10:40 PM
DrDyno
DrDyno's Avatar
Bikes: 2007 Quiring Ti + 2014 Focus Izalco + 2009 Dynamic Synergy + 80's Bottecchia w/105 Crank Set + 2010 Jamis Commuter-4 + 1999 GT Slipstream Hybrid
Quoted: 38 Post(s)
Liked 14 Times in 9 Posts
I use this from Amazon. I have two of them and, rather than fill each with my necessities, I just attached the under-seat clip on both bikes and switch one bag back and forth... instantly.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Regards,
John G.
St. Petersburg, FL
"If you feel like you're in control, you're not going fast enough!" Mario Andretti
DrDyno is offline
Old 10-03-19, 01:52 AM
canklecat
canklecat's Avatar
Quoted: 3019 Post(s)
Liked 386 Times in 275 Posts
SCICON bags have a nifty, quick and secure quick release. I used one of their smallest for a month and it worked fine. Just too small for my needs -- it wouldn't hold all I want on my road bikes. I snagged one on special from Amazon for only $5 so it was worth it to try their QR system. I'd consider one of their larger bags. The QR clamp attaches/detaches without tools, hold securely and the bag didn't waggle or pop loose during the month I tried it, including on some very rough rides.
The best compromise I've found in a compact saddle bag that's functional, small and easy to mount/remove is the Lezyne Road Caddy. It's squarish, flattish, uses a single wide Velcro strap and works very well. If I pack a thinwall tube like the Continental Race 28 Light, there's enough room for a tube, Lezyne patch kit, CO2 kit with teensy chuck (Lezyne and others make minimalist chucks), Hero Kit multitool (the flattest I've found with a spoke and chain tool), a pair of heavy duty tire levers, and a few other tiny items.
The Lezyne Road Caddy isn't a quick release, just a Velcro strap, but it's quick, easy and secure.
And, a plus, it leaves enough room to strap a spare folding tire on longer unsupported rides. I just use another Velcro strap to secure it under the Lezyne Road Caddy. It's still so flat there's no risk of rubbing the tire, and it doesn't waggle around.
canklecat is offline
Old 10-03-19, 06:14 AM
Witterings
Quoted: 554 Post(s)
Liked 22 Times in 18 Posts
Depends how much space you need but I use one of these and it attaches to seat post rather than the rails
https://www.amazon.co.uk/Rixen-Kaul-.../dp/B000OZBMZ8
Witterings is offline
Old 10-03-19, 06:31 AM
tcs
Palmer
tcs's Avatar
Bikes: 1980 Mike Melton, 1982 Stumpjumper, 1982 Santana, 1984 Alex Moulton AM, 2008 BikeFriday tikit T-11, 2010 Dawes Briercliffe, 2017 Dahon Curl i5, 2019 Surly DT14
Quoted: 621 Post(s)
Liked 87 Times in 70 Posts
Well, there's Carradice with their Bagman system and Frost & Seekers with their Quicklock system.
tcs is offline
Old 10-03-19, 05:14 PM
ddeand
ddeand's Avatar
Quoted: 142 Post(s)
Liked 23 Times in 11 Posts
This is my choice. Ive used all sorts if seat bags, and these are the ones Ive had for the past four years. I have two Micro bags and one bigger one in which I can carry a bit more stuff. Each of my bikes has the seat clamp, so I can just move the bags around from bike to bike. They snap on securely, and when we stop for coffee or a snack, I just pop the bag off and bring it with me. Best seat bag Ive used.
Some days, it's not even worth gnawing through the restraints.
ddeand is offline
Old 10-03-19, 05:33 PM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 749 Post(s)
Liked 94 Times in 64 Posts
Currently using a Topeak under saddle bag. The needs for both my hybrid (Trek DS) and Mongoose gravel bike are the same. So, just got two clamps and transfer the bag as necessary. A member also provided a suggestion for a bar bag capable of accommodating small cameras. It too was a Topeak. Bought two clamps and transfer it between both bikes as necessary. Both have worked well.
"Skepticism is the first step in critical thinking." -- Me
bobwysiwyg is offline
