Bike gear calculator
Is bikecalc.com accurate? Not an app, not sure if they have one, it’s just a website. Site looks so simple, but what i like abt it is aside from gearing ratios, they also calculate the cadence u need to achieve or maintain a certain speed per gearing combination, plus some more.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
My favorite so far is Bicycle Gear Calculator -- I could play with those sliders all day.
Edit: Just tried playing with it now. It’s great. I like how those triangle marks are lined up for each chainring, you can easily see where it’s best to shift down from big to small ring, compared to using the bikecalc chart. This will be very useful for me. Instead of just trying to grind it out on the big ring on not so steep hills, i now know which small ring and cog combo to switch to to climb faster and easier. Thanks for sharing!
Quoted: 523 Post(s)
Liked 227 Times
These two gear calculators have been around for years. I never read a complaint about inaccurate results.
Mike Sherman's Bicycle Gear Calculator
https://www.sheldonbrown.com/gear-calc.html
Likes For VegasTriker:
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
Stuart Black
Stuart Black
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
The speed calculations for any gear calculator are going to depend on several factors that probably aren’t...and can’t be... considered in the calculations. Wind resistance will change the value. Headwinds will have an effect as well. They shouldn’t be looked on as “absolute” but only as estimates. They are probably good estimates but just estimates.
Liked 4,204 Times
Umm, yes. No bicycle gearing calculator can take into account the size of the rider, the rolling resistance of the tires, the wind and weather conditions, etc. All of those are going to have a small impact on the speed. That’s the real world vs the model.
The bikecalc.com calculator is probably worse than others I’ve seen. It gives the speed to the nearest 100th of a mile per hour. That’s a ridiculous number to report. Someone doesn’t understand significant figures. Giving the calculation to the nearest mile per hour is likely inaccurate.
Stuart Black
Stuart Black
I Ihave done the math using Excel and compared my results with two web based calculators and got so close with both I have no reason to believe any of them are inaccurate.
If you remember you grade 9 math, you can set up a custom chart showing speeds in gears at different cadences, gear inches and ratios in Excel too, like I have. It's not rocket science.
Keep in mind these are theoretical speeds in gears assuming we can generate enough power to overcome weight, Wind resistance, rolling resistance, ect.
Likes For RGMN:
Advocatus Diaboli
Liked 1,531 Times
The bikecalc.com calculator is probably worse than others I’ve seen. It gives the speed to the nearest 100th of a mile per hour. That’s a ridiculous number to report. Someone doesn’t understand significant figures. Giving the calculation to the nearest mile per hour is likely.
Likes For Sy Reene:
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I've used - and been happy with - various gear calculators for working out basic information on speed, cadence, development, etc., and found the information helpful for gearing choices on geared but especially single speed bicycles. Accurate enough for an average user/rider; for purposes of engineering, etc. there are probably more variables that need to be considered.
Likes For wipekitty:
Liked 2,563 Times
Wow, that one is pretty great - it's helpful to see all the information at once. The only thing missing is meters of development (which is likely only of interest for OCD riders such as myself.) Thank you for sharing.
Likes For ThermionicScott:
climber has-been
Quoted: 3417 Post(s)
Liked 3,546 Times
What? Some explanation of how these things might affect the cadence vs speed relationship, please. How small is "small"?
Ride, Rest, Repeat. ROUVY: terrymorse
Cycleway town
These calculators only cater for one crank. I have two. I don't use my CS-RK3 hub on the single-pedal tandem, but if i did, i'd have...
3-speeds front crank
2-speeds mid crank
10-speeds cassette
3-speeds hub
I know this'd be 180 gears but i don't know their actual ratios, and it could take some time to work out. I use an e-hub instead of the CS-RK3 but it'd still be nice to calculate the effect of experimenting with the front two cranks, which turn at different speeds.
2-speeds mid crank
10-speeds cassette
3-speeds hub
Quoted: 1572 Post(s)
Liked 643 Times
I don't know how many times I've seen somebody post you'll go faster with a 26" wheel than with a 20" wheel. While it's true that, at the same cadence, you'll definitely go faster with the 26" wheel it's equally true that it will be harder to pedal the 26" wheel at that cadence. Think about it this way. If you could somehow fit a Ferrari transmission into a Yugo, do you think it would go 200 MPH? No because the Yugo simply doesn't have enough power to go 200 MPH.
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
They don't figure in at all. The calculation is for a specific cadence. If you can achieve that cadence (say 90), then you will go that speed. Now, it is possible that you may not be ABLE to achieve that cadence in a specific gear combination because you aren't strong enough. Maybe you can only do 70 RPM in that gear up the hill. Yes, you will be slower than the person who can spin 90 rpm in the same gear. It doesn't mean the equation is wrong.
If the correct formula is used (grade 9 math at best) these calculators are probably 99.9% accurate.
I get almost identical results as the online calculators when I set up an Excel chart for the same gear ratio to speed calculations. The tiny differences are probably due to rounding.
Liked 643 Times
Advocatus Diaboli
Liked 1,531 Times
Nobody's talking about that though, the discussion was specifically about gear calculators which do one simple thing -- show you the speed you would go for a given cadence and gear combination for a given bike/wheel size.
Quoted: 1814 Post(s)
Liked 923 Times
Actually the calculation is not based on diameter, It is based on circumference. 1 revolution of a 4.5" fat tire that is riding nearly on the rim, or fully inflated does not change how far the bike travels with one revolution from a chalk line on the tire. If the correct formula is used (grade 9 math at best) these calculators are probably 99.9% accurate.
Clearly, you have not actually tried this.
Cycleway town
Yeah, he's talking out of his backside. Of course it does. One revolution of a wheel with a fully inflated tyre will travel further than the same wheel if the tyre is half flat.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
