Switch from bar con shifters to brifters
Hi:
I have a 2012 Kona Sutra which has a 9-speed Shimano XT Shadow SGS rear derraileur, a 3-speed Shimano Tiagra front derailleur and it came with Shimano Bar Cons.
I'm toying with the idea of switching from bar cons to brifters but I don't know if there are any special considerations I need to take into account. For example, I found some 2/3x9 Ultegra shifters on eBay but I think of Ultegra as a road (racing) drive train so I don't know if it would work with my derailleurs. I don't want to consider a full drive train change up, I'm hoping to find compatible brifters.
In addition to Shimano models, if there are any other brands I could consider, please don't hesitate to share.
Oh yes, I need to consider braking as well. Mine are Avid BB mechanical.
Many thanks,
Jules
Many thanks,
Jules
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Hi:
Many thanks,
Jules
Many thanks,
Jules
Front derailleur should also be fine, as Tiagra is a road derailleur.
As far as the brakes, it depends on whether your bike has the “road” or “mountain” version of the BB7, and that would depend on the levers being used currently.
Quoted: 1438 Post(s)
Liked 1,092 Times
Gevenalle's Audax line may allow you to move your barcon shifters to their modified brake levers, https://www.gevenalle.com/product/audax/ avoiding compatibility issues.
Look into Microshift's offerings. https://www.microshift.com/en/
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Shimano 9 speed brifters (road) are compatible with Shimano 9 speed mountain RD. I run Shimano Sora 3503 brifters with a 9 speed (non-shadow) Deore RD.
FD is Tiagra, it is a "road" model.
You need to check if your brakes use long ("mountain") or short ("road") cable pull. Most of the drop bar brake levers use short pull, but there exist some with long pull (Tektro RL520 in particular). Shimano brifters use short pull.
Since you are dealing with Shimano 9speed, mountain and road shifters and rear derailleurs are interchangeable. So a shimano 9 speed brifter (such as the Ultegra you are looking at)will shift that 9 speed XT fine.
Advanced Slacker
Liked 2,537 Times
Yes, Ultegra is a technically a road group, but thats what “brifters” are. IMO, if they are in good shape, those would be perfect.
Likes For Kapusta:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
I changed rear derailleur Tiagra to Deore, 9 speeds, and no issues with the compatibility. Also made the same change with the cassette. I like having the wider gears on that particular bike.
Quoted: 217 Post(s)
Liked 155 Times
Another suggestion: Shimano's most recent R3000 (Sora) 9 speed brifters have hidden shifter cables, if that matters to you. The cables do not interfere with the handlebar bag then.
Liked 1,092 Times
Be aware that those under-the-tape cables have a tendency to fray the center wire due to the relatively sharp bends they undergo, so inspect them frequently.
Quoted: 4201 Post(s)
Liked 3,860 Times
Two points- One is that all the Shimano (and to a lesser degree other) brifters tend to stress/fray the cable about 1/4" from it's head (out of sight and hopefully not out of mind too). This isn't limited to the current under bar wrap cable routing. Second is that the road shifter and ft der really want a road crankset. There's no subtle trimming of cage position so mixing MtB cranks and road rest can be a frustrating combo of chain rubs in some cases. Andy
AndrewRStewart
AndrewRStewart
Quoted: 257 Post(s)
Liked 70 Times
I did the same with my touring bike. Originally swapped out a downtube Campy setup to barends XTs, then to SRAM 9 spd with butterfly bars, then 9spd 105 with XT derailleurs, but now on 10 spd Ultegra triple with Cowbell bars. The latter has been my setup for the past two years which is really comfortable with the newer ergo hoods and cleans up the cockpit quite a bit.
Quoted: 283 Post(s)
Liked 262 Times
I have a Trek that’s all Ultegra with brifters and triple front. The rear shifter works great, i don't care for the front. I would put a bar-end friction shifter on the front if I had one. It’s easy to miss shifts/half shifts.
Liked 3,860 Times
This is the beauty of the first couple of generations of Campy (and Sachs) Ergo brifters. The left/front lever isn't a true indexed one. It just has a number of stepped points of movement and one just moves through the steps until the shift is done, maybe trim either way as needed. Andy
AndrewRStewart
AndrewRStewart
