Cable housing wire strands shifted?
New one on me, but I just work on my own bikes. Any idea how this happened? It is the original Jagwire Lex cable housing for the rear derailleur on my Jamis Renegade. Both ends look like this with half the wires of the housing shifted various distances out of the outer housing, and the outer housing torn up under the ferrules. I have seen frayed, but not that shifting of the wires. The bike is only 2 years old and has less than 2000 miles, mostly this summer. Cables are a bit to long after lowering the bars; so I just recut the housing for now and used a new cable. I wonder if I should replace all of this housing on the bike?
Quoted: 4198 Post(s)
Liked 3,851 Times
This happened because you used your bike, and likely didn't replace cables as frequently as you obviously should have. We see this casing strands migrating lengthwise often enough. On cheap as well as quality bikes. But, regardless of my somewhat tongue in cheek opening, I have never yet had anyone explain why it happens to the green bike but not the blue one given both having a similar situation. We have concluded that the short term fix is simple, replace the casing loops (and inner cable as precaution). The long term avoidance is monitoring and servicing more frequently.
My personal thoughts are that when the casing gets flexed frequently the casing strands can loose their ability to keep as a unit (all the strands act in unison) and some will migrate. My evidence for this theory is that we almost never see this with the casing loops that are between non moving stops but do see it when there's a stop on the frame and the casing's other end is (usually) at the shifters. So the steering rotations of the bars are the flexing I refer to. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1818 Post(s)
Liked 1,693 Times
Just wondering if you used proper ferrules for shift housing. If the ferrules were designed for brake housing the casing ends will not be properly supported and they can push through the larger hole in the brake cable ferrule
Liked 3,851 Times
We see this problem with both the proper steel SIS ferules as well as the plastic ones. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2603 Post(s)
Liked 1,925 Times
Liked 2,966 Times
It comes from being used. Only way to stop that is to not use it... or possibly painting the bicycle cyan?
-Oh Hey!
-Oh Hey!
Quoted: 2026 Post(s)
Liked 1,096 Times
Liked 3,851 Times
To add detail though- SIS casing has been made in both 5mm and 4mm diameters. Brake casing is nearly only 5mm. So to use a steel brake casing ferule on a 4mm SIS casing means that the wrench (be they pro or home) wasn't able, or didn't, notice the fit being wrong. Not saying this doesn't happen, just that it requires two mistakes.
I'll also note that casing strand punch through (as when a brake casing ferule is used on a SIS casing, regardless of diameter fit) is, IME, generally not the same as what the OP is showing. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1438 Post(s)
Liked 1,092 Times
Did you form the cable housing to its approximate final shape before you cut it? If you left it straight while cutting it, when you bend it to its working shape you will stress the strands in just the pattern that is exhibited. This is most apparent in the loop of cable going to the derailleur since it makes a sharp almost 180 degree bend.
Likes For dsbrantjr:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
It is already blue.
Sure if a bike was equipped with the wrong ferules it would increase the likely hood of problems. This isn't a common thing but it does happen, more often after a casing replacement had been done by someone who wasn't informed of the improper ferule issue (or didn't care, thankfully these people are few, IMO).
Ha! Several of my bikes have friction shifters, and I have even considered switching this one out to Gevenalle Audax friction shifter/brake levers from the current Claris brifters.
Quoted: 1163 Post(s)
Liked 442 Times
I like the idea of bending the housing to the desired shape before cutting to allow the lengthwise strands to be allowed to orient themselves first and then once terminated the trimmed section might have waste wire strands of slightly different lengths.
