Rear wheel spinning out when climbing - ideas/suggestions?
Old 10-16-19, 09:16 AM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
This past weekend I was riding some technical single track. Talk about working on your bike skills. Anyway...
Some the sections had rock faces that needed to be climbed. I was finding that my rear wheel was spinning out, maybe half of the time. The rock faces were not wet (at least as far as I could tell) so I'm curious why my rear wheel was spinning out. Could it be I was in too low of a gear? Does temperature affect the bikes ability to climb up rocks?
Also, I was having a lot of what I am calling rear slide-outs. I'd be riding up over something - a root, a rock - and the rear wheel would slide over to the side and down. So long as I was pedaling I was able to keep the bike moving forward. Probably just bad route picking on my part.
NoWhammies is offline
Old 10-16-19, 12:54 PM
KDTX
Quoted: 24 Post(s)
Liked 6 Times in 5 Posts
Initial thought is too much pressure in your tires
KDTX is offline
Likes For KDTX:
Old 10-16-19, 12:57 PM
mackgoo
mackgoo's Avatar
Bikes: 87 Bianchi X4, 95 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33, Gold plated Columbus AIR Guerciotti, 74 Galmozzi Super Competizione, 52 Bianchi Paris Roubaix.
Quoted: 259 Post(s)
Liked 539 Times in 166 Posts
And put more of your weight on the rear wheel.
mackgoo is offline
Likes For mackgoo:
Old 10-16-19, 03:49 PM
Brian25
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times in 15 Posts
Dropping your heels makes a huge difference.
Brian25 is offline
Old 10-16-19, 03:59 PM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times in 260 Posts
Old tyre gotten hard?
Too much pressure?
Try a different tread pattern, or even a fatter tyre?
Sit down more while climbing?
If it's happening consistently, these are the things I'd try to see if they made any difference.
Is it a hardtail? Compared to a dual-suspension, traction won't always be as good, it might be fun to borrow one and ride it up the same sections back-to-back with a hardtail. I did this a *long* time ago and was pleasantly surprised at being able to go up stuff on a dualler that I couldn't on a hardtail.
ridelikeaturtle is offline
Old 10-16-19, 04:14 PM
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Thanks folks. I think their is too much air in my tyres. I think I had 30~35psi in there.
I'll also work on sitting more while climbing.
Cheers.
Old 10-16-19, 07:08 PM
Leebo
Bikes: Kona Dawg, Surly 1x1, Karate Monkey, Rockhopper, Crosscheck , Burley Runabout,
Quoted: 854 Post(s)
Liked 111 Times in 66 Posts
Rider weight, rim width, tire make and psi? Suspension set up correctly? I'm 230, running 2.5 front width tire, 2.4 rear, 29er. 30 mm id rims. 18 psi front, 20 psi rear most days. Tubeless.
Leebo is offline
Old 10-16-19, 07:40 PM
ab_antiquo
Quoted: 44 Post(s)
Liked 25 Times in 17 Posts
You need to ride more. Less equipment blaming, more skill building.
ab_antiquo is offline
Old 10-16-19, 07:44 PM
Bigbus
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times in 244 Posts
I used to have that problem too until I switched up a wider traction tire on the rear. I run 2.35 Bontrager on the front which gives good stability and cornering and a 2.5 Delium on the rear which is seriously knobby. There are slopes of slick mud I can climb now with barely any tire slip that I would spin out prior to changing. Tire pressure is a definite factor also, especially in sand and scree/
Bigbus is offline
Old 10-16-19, 11:37 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3427 Post(s)
Liked 3,563 Times in 1,790 Posts
When I have to climb something steep and slick, I concentrate on spinning circles at a fairly high cadence. Staying in the saddle, of course.
That usually works.
terrymorse is offline
Old 10-17-19, 07:24 AM
pickettt
Bikes: DiamondBack Podium 7, Focus Raven 1.0, Ritchey BreakAway Cross, (2) Trek 8500, Paramount PDG 90, Trek T2000, Redline Flight Pro 24
Quoted: 160 Post(s)
Liked 57 Times in 33 Posts
Body weight distribution. With experience and saddle time, you'll learn right where you need to be and right when to be there. Good luck to you
pickettt is offline
Likes For pickettt:
Old 10-18-19, 06:16 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
Cheers.
Whats size tires, and how much do you weigh?
Some of it is just practice, knowing just where to put your weight and when.
Kapusta is offline
Old 10-18-19, 08:27 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
This^^, too much weight lean forward. You can still have weight in the back in a standing climb, just takes practice. Could also be tires, but practice is free
qclabrat is offline
Old 10-25-19, 06:41 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
Weight the rear wheel and smooth your pedaling. Spin, do not hammer.
c_m_shooter is offline
