Chainless Bike / Ceramicspeed Driven - The new thing?
Bikes: SL8 Pro, TCR beater
Quoted: 1006 Post(s)
Liked 588 Times
Hi all,
One of my friend sent me this video yesterday about a Chain-less Bike that uses a driveshaft that provides 99% efficiency. It's also explained that it shifts perfectly even under load.
We all know that energy is lost when transmitted/transferred - this technology looks cool IMO. It's advertised to revolutionize the industry, but I doubt it will take over chains and gears in a near future.
What do you guys think?
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
*rides in the rain once*
*takes bike to shop to diagnose horrible noise*
"Well, crud got in the bearings and they need replacing...all 15 ceramic bearings. Oh, and the "cassette" is toast as well, so they need to CNC a new one. Your total, with labor, comes to $3200."
Liked 588 Times
Did you see the protective cover available? Might not solve all issues, but would certainly help in situations where dirt or other elements could damage the components.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Hi all,
A single speed bike is about 98% efficient and derailleur drivetrains a bit less, depending on chain angle etc.
https://www.cyclingabout.com/drivetr...between-1x-2x/
Drive-shaft systems were around 100 years ago...they never caught on.
Quoted: 4717 Post(s)
Liked 1,882 Times
Quoted: 480 Post(s)
Liked 277 Times
I love (!) seeing new tech hit the cycling segment. This may not do much for us, catch on, etc... but glad to see innovation in any form. It's ironic for me though - I've considered the rear derailleur one of the most elegant pieces of mechanical engineering. They're so simple and just work. Rain, mud, dirt, abuse... and they just keep working.
Liked 406 Times
IGHs...now those are elegant. Not as mechanically efficient, but chains last longer, they aren't fouled by mud, stronger wheels, and no exposed bits of mechanism or frame to damage.
Quoted: 1814 Post(s)
Liked 923 Times
Since that cassette would have to be really stiff,
it could be the brake rotor as well- oh wait, that would make it fixed gear...
multi-speed fixed gear.
Liked 588 Times
Same scenario with coaster brakes. That thing could throw you in front of your bike if you pedalled back by mistake.
Advanced Slacker
Quoted: 2763 Post(s)
Liked 2,537 Times
The gear ratio spacing is going to be really whacked out.
Think about it: the tooth count jump is going to have be exactly the same between each gear (if the reason is not apparent in this video, it is in others). When looking at really wide range cassettes (which the one pictured it), that does not work well. You either really wide ratio spacing at the high end, or uselessly tight spacing at the low end.... or both.
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
I'd like to see how that system would cope with a 1600+W start from a dead stop. It may work great in a lab, but I just can't wrap my head around how all of those tiny bearings running on a 90-degree cassette would be able to not skip/explode as soon as someone really gave it the beans.
Quoted: 480 Post(s)
Liked 277 Times
We can agree to disagree on this one. I race mtn and gravel bikes. I also keep my bikes relatively clean - after races/rides. I get years (!) out of derailleurs.
