Racer Tech Thread
Old 04-15-15, 08:05 AM
  #1251
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
Originally Posted by caloso
I have some barely used Reynolds carbon brake pads but they are the Campagnolo shape and my race bike is SRAM/Shimano. Is it possible to alter them to fit Shimano holders? I was thinking I could use a rat tail file on the groove. Anyone tried this?
It's your brakes. New Cryo Blue pads are $22.
shovelhd is offline
Old 04-15-15, 10:57 AM
  #1252
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times in 253 Posts
Originally Posted by shovelhd
True, it can take some work to get the preload right. Going to a Shimano crank in a BB30 BB is going to require adapters or a conversion BB.
We went adapters - then the conversion BB. IMO the adapters are inferior to a BB30 setup and the conversion BB (Wheels MFG) are superior to a standard BB30 as they kick the bearings out another 10 mm. My son and his teammate both say they feel that. Praxis also makes a conversion adapter but I'm told it puts pressure on the interior of the BB chamber, while Wheels Mfg uses the threads.
Doge is offline
Old 04-15-15, 11:05 AM
  #1253
Doge
Doge's Avatar
Originally Posted by mike868y
ah ****, i've already got the wheels mfgr on order. fwiw, most of my issues with this bike have been due to the crank, not the actual bb. but, when the wheels mfgr bb wears out, I may switch to a praxis.
Wheels Mfg makes adapters (https://wheelsmfg.com/bb-pf30-univers...no-cranks.html) and BB conversion kit (https://wheelsmfg.com/products/bottom...-outboard.html). The wheels Mfg adapters came with the bike. I purchased alloy Enduro adapters. Both adapters were nothing like the stiffness had in the wider bearing spacing on the prior MASI bike and was very noticeable to my son on the crank flex. I then went to the BB conversion solution which is much better.
Doge is offline
Old 04-15-15, 11:15 AM
  #1254
revchuck
OMC
revchuck's Avatar
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times in 49 Posts
FWIW, my 2015 Allez Comp Race came stock with the Praxis adapter and their Turn Zayante crankset. Nary a sound. My 2012 Allez E5 frameset had standard SRAM BB30 bearings with an FSA carbon BB30 crankset, also silent.
Regards,
Chuck
Demain, on roule!
revchuck is offline
Old 04-15-15, 01:35 PM
  #1255
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
You're right.
caloso is offline
Old 04-18-15, 07:10 AM
  #1256
echappist
fuggitivo solitario
Quoted: 243 Post(s)
Liked 13 Times in 9 Posts
More money (spent), more problems. On my old handlebar, i had space for my Garmin mount and a mount for a headlight (NiteRider Lumina). My new Zipp Vuka Sprint doesn't leave nearly enough space on the bar itself for mounting, which leaves me mounting to either the stem or my helmet. My stem is at -6 degrees, which means that the light would be directed above horizontal as opposed to slightly below horizontal as I would prefer. I could also do the helmet, but that seems to lead to problems of its own.
Suggestions?
Thanks in advance!
echappist is offline
Old 04-18-15, 07:25 AM
  #1257
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
I can't believe you changed to a compact bar after years of chiding me about mine.
The Barfly has a narrow profile at the bar end that might buy you a few mm. I'm not familiar with that model lamp but my Nightrider is adjustable about 30 degrees either way so I'm not sure why this is an issue. Maybe some pics would help.
shovelhd is offline
Old 04-18-15, 07:53 AM
  #1258
echappist
fuggitivo solitario
Quoted: 243 Post(s)
@shovelhd, thanks for the suggestion. I will snap a few photos later. In the mean time, i have mounted a small Sigma flashing light to the bar via elastic band/ zip tie. Perhaps i'll just get the helmet mount, though i hear drivers really hate helmet level lights...
PS. The bar is traditional round . And it gets even better as i apparently need special bar-end plugs as the Cat-eye screw-in type and the ones that came with my Fizik bar tape are both too wide...
Old 04-18-15, 09:45 AM
  #1259
ips0803
ips0803's Avatar
Echappist, depending on the stem you are using, you could use a Tilquist mount for the garmin to free up space for the light.
ips0803 is offline
Old 04-18-15, 09:47 AM
  #1260
spdntrxi
Bikes: not enough
Quoted: 189 Post(s)
Liked 86 Times in 52 Posts
or a stem cap mount for the garmin..again to free up space for the light.
spdntrxi is offline
Old 04-18-15, 09:49 AM
  #1261
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
heh, #zippproblems - 'grats on the bars though - I'm glad to hear you are still flying the banner for SRMMafia and Aerohomies
Hida Yanra is offline
Old 04-18-15, 10:03 AM
  #1262
echappist
fuggitivo solitario
Quoted: 243 Post(s)
thanks for the suggestions. unfortunately, the suggestion would require me to shift the bar off center to make space, which i would prefer not to do at the moment
thanks @Hida Yanra; hope your preparations are going well
Old 04-21-15, 12:39 PM
  #1263
echappist
fuggitivo solitario
Quoted: 243 Post(s)
gratuitous photos
now i need to find bar-end plugs that will fit the bars. The old ones are apparently too large. More #zippproblems ...
Old 04-21-15, 12:49 PM
  #1264
mattm
**** that
mattm's Avatar
Quoted: 1099 Post(s)
Liked 104 Times in 30 Posts
Dumb q about bb30 adapter cups - are they supposed to rotate/spin along with the cranks?
My old ones didn't but they were glued onto the frame (from what I can tell) to stop them from creaking or something.
The ones I installed (Wheels Mfg) do, and I got some fancy Campy cups that'll hopefully be stiffer than the plastic Wheels Mfg ones.
Anyway I imagine it can go either way, but I'm wondering which way it's supposed to be.
cat 1.
my race videos
mattm is offline
Old 04-21-15, 12:54 PM
  #1265
Dunbar
Dunbar's Avatar
Bikes: Roubaix SL4 Expert , Cervelo S2
Quoted: 85 Post(s)
These things? They are supposed to spin with the bearings/crank.
Dunbar is offline
Old 04-21-15, 01:10 PM
  #1266
mattm
**** that
mattm's Avatar
Yup those adapters.
With the campy cranks I have (external bearings) it seems like I'm not actually using the campy bearings, but only the bb30 bearings, if the cups spin too.. which obviously works, I was just confused about which way it's "supposed" to be.
cat 1.
my race videos
mattm is offline
Old 04-21-15, 05:39 PM
  #1267
Dunbar
Dunbar's Avatar
Quoted: 85 Post(s)
Not a Campy expert but I know that Praxis makes an adapter specifically for Campy Ultratorque cranks that the Campy bearings sit inside of.
Dunbar is offline
Old 04-21-15, 05:55 PM
  #1268
mattm
**** that
mattm's Avatar
The campy bearings go inside of the bb30 adapter cups I have, similar to what those do. (so I might've been wrong about the first pic you posted, but they look a lot like that)
At any rate what I have works, just wanted to double-check. Thanks!
cat 1.
my race videos
mattm is offline
Old 04-21-15, 09:25 PM
  #1269
tetonrider
Quoted: 693 Post(s)
the way to think about it is whether the adapter goes into the bearings or the bearings go into the adapter.
anything that goes into the bearings rotates (e.g. the crank arm/spindle when you don't use an adapter, or an adapter+spindle+arm pressed into the bearings).
if the adapter is an extension of the frame (bearings get pressed into the adapter), then only spindle+arm rotate.
tetonrider is offline
Old 04-22-15, 05:01 AM
  #1270
Matt2.8NJ
una carrera contrarreloj
Matt2.8NJ's Avatar
Bikes: Venge, Tarmac, Cervelo P2
Quoted: 32 Post(s)
Giro Synthe 200 mile review: Nice helmet, good quality of fit and materials. Definitely less cooling by a good margin than the Prevail it replaced. Not sure how much I'd like to race in August in the helmet.
Matt2.8NJ is offline
Old 04-22-15, 10:22 AM
  #1271
jsk
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
While I would expect it to have less cooling than non-aero road helmets, from pictures it looks like it's better ventilated than other aero helmets like the Evade or Giro Attack. I have the Attack Shield, it's definitely not suitable for summer riding/racing in TX. I was thinking the Synthe might be a good choice but now I'm reconsidering. I don't mind giving up a little cooling for aero, but I definitely need something with better ventilation than the Attack Shield.
jsk is offline
Old 04-22-15, 10:41 AM
  #1272
Edonis13
Edonis13's Avatar
Bikes: S-Works SL3 Tarmac, Allez E5, Leader 735TT, others
As far as aero helmets go, I am surprised by how much air my Bell Star Pro flows with the vents open.
Edonis13 is offline
Old 04-22-15, 10:51 AM
  #1273
misterwaterfall
I went from an Evade to a Synthe and they both seem fairly similar to me. I haven't used the Synthe over 70* or so as of yet, but I don't see if being a problem at all.
misterwaterfall is offline
Old 04-22-15, 02:14 PM
  #1274
spdntrxi
Bikes: not enough
Quoted: 189 Post(s)
I've used the evade up till the low 80.. Not bad.. Not a prevail but still ok
spdntrxi is offline
Old 04-22-15, 10:16 PM
  #1275
tetonrider
Quoted: 693 Post(s)
i've used the evade in 100+.
if you're climbing slowly in that heat, it is hot (so is the any helmet; the evade feels a tad hotter), but if you are riding at 25mph it is just fine (IMO).
