[Shimano hydraulic brakes] Would You Reuse an Olive?
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Not that I'd want to reuse one, but, in a pinch, would it be safe to reuse an already compressed olive - even temporarily - and get the brake working?
Quoted: 714 Post(s)
Liked 800 Times
Are you referring to reattaching a hose that has been removed, or removing the olive and insert from the hose and using it in another hose? The first is fine, the second would likely be impossible. I have re-used an insert with a new olive, but that required destructive removal of the olive.
Quoted: 792 Post(s)
Liked 1,494 Times
Let's say I'm swapping levers as an example.
I also have two or three pieces of hose that I had cut earlier with the barbs and olives still attached; i know I could burn the pieces of hose away, save the barbs, and throw the used olives away, but I wondered if I should keep them for emergencies instead.
Quoted: 4416 Post(s)
Liked 1,569 Times
I have successfully reused barbs.
I have successfully swapped levers without installing a new barb and olive.
Look at what you're working with. Frequently the olive wasn't seated correctly and you can see the distortion. But if the olive looks good, it will likely seal again.
The downside to any of this is that it might leak, not explode. If it doesn't leak, it's working.
Likes For Kontact:
Liked 2,981 Times
I would not if parts are available.
-Oh Hey!
-Oh Hey!
Quoted: 5793 Post(s)
Liked 2,593 Times
Olives are use once and done items. I might try to reuse an olive in an emergency field repair. However, consider that a used olive will have a smaller ID and will probably to de difficult to slide onto the line.
For non emergencies, check that you have olives BEFORE cutting the line.
FB
Chain-L site
FB
Chain-L site
Liked 1,569 Times
Likes For Kontact:
