Help - Welding / drilling seat post to frame
Hi all,
struggling to fit a seat post to this frame.
It’s part of a personal refurb job… the frame has been cut too short so cannot use a clamp.
FYI It’s only for light use…
Other than drilling the frame and seat post to put bolts through at different positions, or welding the seat post to the frame… does anyone have any suggestions ??
Thanks for any help.
Randomhead
Liked 3,700 Times
Well, he can't post pics in a thread, but if he posts them in a gallery on his profile, we can move them here.
Quoted: 28 Post(s)
Liked 60 Times
There were a few vintage bikes built which used a seatpost with an internal expander bolt, sort of like used for old adjustable quill stems (before aheadsets). Either search and find a suitable size/length expander seatpost or modify an existing seatpost to work with an expander.
Welding together is a bad idea, especially if dissimilar frame/seatpost metals. Epoxy might be a better one time semi-permanent technique but loosing ability to ever adjust height is just a bad idea. If frame were steel, it should be possible to slot the top of seattube and add a binder bolt however short the seattube were cut.
Quoted: 4211 Post(s)
Liked 3,881 Times
This!
I've seen (long ago, forgot where) a repair with a machined insert that is bonded in the seat tube. This insert extends above the top tube enough to have it's own binder and slot. The replacement seat post is sized to fit the new insert (or other way around, you get the idea). Not hard to do if you have a lathe. Expensive if you don't Andy
AndrewRStewart
AndrewRStewart
Quoted: 714 Post(s)
Liked 800 Times
I posted this seat tube from Nate Zukas in the last thread about this issue. If you have the skills to do this, it is the best solution to the problem.
Likes For dsaul:
I don’t have the tools to do the above.
(it doesn’t need to be pretty)
thanks
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 157 Post(s)
Liked 146 Times
Neither do I but it sure is a neat solution to a fairly frequent problem! My '70's era MB GR's seatpost clamp shows its age and results of my efforts to get it secured. Clamp ears are rather close together now after the surrounding metal they're attached to has stretched. At this point there's still enuf clearance between 'em to keep post secured. If I keep riding it I may have to resort to taking a die grinder to the ears' inner edges to bring back a little more space.
Here's your pic BTW:
Looks like that frame's seen some bodging for repairs? Evidence of brazing showing, besides the rough texture after attempts at smoothing out fillets?
Likes For spclark:
Definitely taken some bodging to get the old seat post out.
aluminium post in a steel frame corroded so a combination of heat, cold, drilling and cutting to set free. Work to do to neaten this up.
What about some kind of clamp used lower down the frame to tighten around the frame and post - any ideas if this is possible ?
Thanks!
thanks!
Thanks!
thanks!
Quoted: 28 Post(s)
Liked 60 Times
Would but also weaken seatpost a bit. Maybe not enough to worry about, but then...
Quoted: 2490 Post(s)
Liked 2,958 Times
Quoted: 321 Post(s)
Liked 263 Times
You could probably braze or weld a pinch bolt on the back where the slot is? I make these on a minilathe: get some round bar, drill and tap it to M6, weld it on, then cut it in half in place, then drill out one half of the threads so the bolt just goes in and threads on the other half.
Quoted: 157 Post(s)
Liked 146 Times
There's a lot of metal in that intersection that'd resist pulling a gap in back much closer together.
Looking at the bodgework done on that tube joint I'd:
1) Find a piece of steel pipe close to the ID needed;
2) Cut a piece maybe 1-1/2" long;
3) Braze (or weld) that onto the cleaned-up stub above that joint.
Then do what you suggest: add a pinch-bolt above the new weld. Lastly cut a new slot into extension tube and pinch bolt with a thin cut-off wheel.
Or maybe just square off that stub end, weld one half of one of these on top, go ride:
Likes For spclark:
Quoted: 49 Post(s)
Liked 13 Times
That'd work as long as whatever's left of the slot – that we can't see in that pic – is long enough below where you'd fix that pinch bolt bit.
They look like a nice clamp for normal use too.
Liked 3,881 Times
I use shaft clamps on a few of my building and alignment tools. Do know they are pre made in a limited range of inside diameters which need to be very close to what they will be slid onto. There are a wide variety of other aspects, number of splits/bolts, width, materials. I get mine from McMaster-Carr shaft clamps | McMaster-Carr. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 157 Post(s)
Liked 146 Times
Advantage over a pinchbolt being you're using a full-circumference clamping surface rather than pinching a thin-section tube to sustain the friction needed to keep a seatpost in place. There's a lot more metal behind most split shaft collars than in the typical downtube.
Randomhead
Liked 3,700 Times
Shaft clamps are a good idea. McMaster has them in 1 1/8", but I suppose the paint would add some thickness.
