C&V Buying Tips?
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
C&V Buying Tips?
Perhaps my midlife crisis is kicking in, I’ve bumped my head too many times or seeing all these beautifully restored classic bikes I grew up with is inspiring. But non the less, I can’t keep from searching, and ultimately have a burning desire to buy & refurbish a classic. Honestly I grew up in the late 70’s & 80’s and kind of remember my now vintage “10 speed”, and I’m not sure whether how much I will enjoy the ride again.
Time seems to be my most coveted asset at this time, so I hate to invest much time refurbishing a bike just to find out I invested time and money into the wrong build and it’s still a POS.
Any tips on what I should look for or what I should stay away from?
Any thoughts on (this may be offensive to some) vintage bike frames with the possibility of upgrading with modern components?
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 55 Post(s)
Liked 153 Times
Find out first what size and fit of frame suits you now which might be different to what fitted you back then and don't do what I did on my return to cycling 25 years ago and buy a newer version of the last bike I had as a teen which was a 10 speed racer, I ended up changing just about every single component on that bike to get it how I wanted it.
There is nothing wrong with a good cycling midlife crisis, I am thoroughly enjoying mine.
Likes For Small cog:
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 874 Times
I think the easiest way for you to start would be to look at slightly later C&V bikes (complete) from the late 90's or early 00 period. With something in that range, the components would be slightly more modern, and not need upgrade. Ride that a bit and decide what part of it you really like.
The old frame with modern group mods is doable, but more trouble.
If shopping for frames alone, get some lighter tubing. There may be compatibility issues between the old and new. Your local bike shop might not be very interested in helping, but there are some that might.
Good luck!
Good luck!
Likes For daverup:
Quoted: 1952 Post(s)
Liked 2,014 Times
Budget?
Simply look for a complete bike with Campagnolo Super Record, Nuovo Record, Dura Ace, or 600.
Where do you live? We will find a bike for you🙂
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
Make sure the frame is your size, fits the tires you want, and has your preferred geometry (some of the classics got very racy in the mid 70s aka PX-10). Then do whatever makes you happy with components!
Likes For BTinNYC:
Quoted: 878 Post(s)
Liked 2,296 Times
It is a great time to buy a classic bike . The prices for used bikes are very reasonable right now . As others have said , find out what size bike fits you and also the type of riding you do . Touring bikes have a more relaxed geometry and tend to have wider gear ranges . A racing bike is tighter clearances , shorter wheel base and lighter weight, usually. I think I’m a bit older than you and I like seventies bikes … still! I grew up in the sixties and seventies and I still have the first light weight racing bike I bought from the seventies. I strongly recommend trying out the bike before buying it just to make sure it will be right for you. Don’t invest a lot of time and money before riding it unless you know exactly what will work for you.
Likes For Kabuki12:
Likes For WaveyGravey:
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Quoted: 149 Post(s)
Liked 366 Times
If there was a bike you dreamed about or rider of a particular bike you were a fan of, search those out…if you want to stay enthused, best to start with something that stirs your emotions. Skip low tiered and even some mid-tiered bikes…takes as much time to refurbish an intro-level bike as it does a professional-level bike and when you are finished the low end bike is still low end…so get something that you are proud to ride and that elicits “nice bike” comments (helps keep you enthused). Basically same rules as car collecting…buy something you actually love.
Likes For Markeologist:
Quoted: 87 Post(s)
Liked 132 Times
Good luck!
Good luck!
what is this “friend” thing you speak of? lol
Quoted: 87 Post(s)
Liked 132 Times
Quoted: 87 Post(s)
Liked 132 Times
Likes For daverup:
Edumacator
Quoted: 2444 Post(s)
Liked 3,142 Times
What type of riding do you foresee doing with it? An all a rounder (gravel, longer sport runs, credit card touring), or something between sport and race?
That would inform your choice.
Anything with Reynolds 531, Columbus (SL, SLX, Cromor, even Aelle) Tange Champion 1/2, Tabge Prestige will not be a POS. Some Vitus and Ishiwata as well.
Quoted: 149 Post(s)
Liked 366 Times
so look for vintage frames, that had options for premium components? I see people restore Schwinn to Raleigh and everything in between, and identifying POS brands may be helpful. I do recognize the premium gram brands, but honestly surprised the at the Schwin restorations. I truly considered these as a hardware store brand. But I could be wrong about the vintage schwin
In your research you will see Schwinn did indeed offer high end and low end bikes as well as everything in between. Schwinn was never a department store brand as those bikes tended to be cheap imports with the stores brand names pasted on. Again, pick an era, read up on Schwinns if that is what floats your boat and after getting a little knowledge, see what is out there in your price range…and also again, you will have more pride of ownership on a high end Paramount over a base level Varsity (if the 70s is the period you pick) and in the long run the Paramount will be the better investment (time and $$$).
Quoted: 878 Post(s)
Liked 2,296 Times
great tip!
no real budget per say, will look for camp components in my size!
Haven’t seen much for clarification on type of geometry on vintage bikes, but this may be do to my lack of knowledge. When I utilize a geometry comparison tool, it seems the difference is negligible. Other than the handlebars being slammed, I’m not sure I’d notice. Currently I purchased my Topstone which falls under the endurance category, and this position seems to suit me the best.
Likes For Kabuki12:
Quoted: 3515 Post(s)
Liked 2,929 Times
BITD, Schwinn was only a bike-store brand. They probably had the largest dealer network in the country. Their high-end bikes in the 1980s were as competitive as anyone's, and their mid-80s Paramount was practically a custom-built frame--an utter work of art.
Likes For smd4:
Liked 2,014 Times
Likes For Classtime:
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,481 Times
Regarding your question about fitting modern components to an older bike, you should find plenty of inspiration in this rather lengthy thread.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Likes For obrentharris:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,872 Times
Probably the biggest question apart from bike fit...do you enjoy working on bikes? You said time is your most coveted asset, but just like money time is only valuable when it is spent. If you are interested in spending time restoring a bike, that can be very rewarding. If you just want to have and ride a beautiful classic bike, that's still possible but it changes the options a lot. For example, you asked about a vintage frame with modern parts. It's relatively unlikely that you'd find what you're looking for ready made. You could buy the frame and parts and pay someone to assemble it for you, but that gets really expensive in a hurry. Gathering all the tools you need to do it yourself can be expensive too, but the joy of good tools is a topic in and of itself. If you don't want to spend time and money on the build/restoration process, that leaves obviously you with looking for complete bikes in good working order. It sounds like you're willing to put some time into restoration, but it isn't clear how much or which parts you're comfortable doing yourself.
Regarding selection of the candidate bike, tubing is probably a better indicator than brand. Not that you'll necessarily notice a big difference between different tube sets, but it's an indication of the market the bike was targeting and therefore has a correlation to quality. You can't go wrong sticking with Columbus SL and Reynolds 531, and those are plentiful. Once you're into the 1980's, there were also some good Japanese tube sets under brands like Tange. The brand of the bike will probably give you some satisfaction, and it's also a rough guide to the kind of geometry you're going to get.
The brands with big reputations come with correspondingly big price tags that don't necessarily get you anything extra other than the name. Bianchi, Colnago, and DeRosa, for example, are all great bikes in high demand, but (with the exception of low end Bianchis) it's hard to find them at reasonable prices. A slightly off brand can be a real bargain and often has its own appeal once you learn more about it. For example, I have a Colnago C97 and a Machiagi-built Coppi Reparto Corse, both from the late 90's, both with very good original paint, both with chrome lugs. The Colnago has Columbus Thron tubing while the Coppi has much lighter Columbus Genius tubing. The Colnago cost me three times as much as the Coppi, and by most objective standards the Coppi is a better frame.
Mainstream American brands like Trek, Specialized, and Centurion were producing very good quality bikes in the early 80's, but in my opinion they aren't as sexy. They're really good for figuring out if you're going to enjoy riding a vintage bike though. I see that you're in Wisconsin, so you probably can't walk out your front door without tripping over a vintage Trek. Don't shy away from them. The 600 and 700 series bikes especially were very nice.
Consider tire clearance. As you get into the mid-to-late 80's you start losing the ability to use tires wider than 700x25. You're probably aware that this trend has reversed and many people are recommending 28's or wider these days. This is a personal choice, but it's something to consider.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 801 Post(s)
Liked 754 Times
The comment about working on your bike is important. Outside of a few savvy shops and co-ops, you're on your own for a lot of this.
Do you have a bike that you currently ride that fits you perfectly? If so, please post the model/year/size and a picture.
Likes For Piff:
Likes For Piff:
Quoted: 3464 Post(s)
Liked 2,831 Times
before the Ironman was the Turbo
more classic appearing paintwork.
https://www.bikeforums.net/classic-v...ion-turbo.html
Likes For repechage:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 165 Post(s)
Liked 267 Times
Be ready and willing to walk away from the project at any time during the build.
Back in 2014, I was working for a shop here in Philly and saw a bike that was amazing. Since then, I had stars in my eyes about finding one. 9 years later, I found one for pennies and built it up like a dream club bike.
The problem is my individual health issues and a neck injury I suffered while I was in the Navy. So, after all the research and collecting of parts, I got the bike together, adjusted the stem to its max height but after a few rides, I'm getting the hot fuzzy numbness in my fingers due to my neck position caused by riding a bike too small.
Now I have to either keep the bike around as a collector piece or send it along at a loss to someone who can use it; I'm choosing the latter. The experience of the build itself was fantastic and over a couple months led me down many rabbit holes of research and history.
So, do the restoration for the journey, not necessarily the end point. There will always be other bikes to bring back to life; be willing to let the grail go and the whole experience will be a lot more enjoyable.
Likes For PhilFo:
feros ferio
Quoted: 1393 Post(s)
Liked 1,331 Times
Consider a 1960s geometry racing frame, which is more like a 1970s or early 1980s touring frame, with wider tire clearances and a longer wheelbase.
Likes For John E:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
It shouldn’t be offensive to anyone. It will be your bike so you can do whatever you want with it. But it isn’t always necessary to modernize an old bike. My warm and fuzzies come from finding bike boom bikes from my teen years in as original condition as possible and keeping them that way. Those bikes I am able to enjoy for shorter rides to the grocery store, coffee shop or brewery. For longer rides, I have a more modern and more efficient bike.
Likes For Chuck M:
