12X Crank 11 Speed Cassette
I got a hold of a Shimano Deore XT 11 Speed shifter and Derailleur. Wanting to go with a 1X HG Shimano Crankset. All I'm finding are 12 speed cranksets. Can I run a 12 speed Crankset with an 11 speed chain? Might I have to change out the chainring? Going 11 speed instead of 12 so I don't have to chance my rear wheel for the micro spline.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Liked 269 Times
I’m running an Nx eagle crankset with an Nx derailleur and shifter. SRAM lists the crankset as 11/12 compatible. I’m also running an 11 speed Kmc chain, and a Shimano Slx 11/46 cassette without any problems at all.
I would assume it would work fine for you, but I would check the specs on the crankset you’re looking at first.
Likes For Wileyrat:
Advanced Slacker
Liked 2,557 Times
In general, an 11 speed chain will work with a 12 speed ring.
The only issue I am aware of for sure that may be relevant is that 12 speed Shimano chains need a 12 speed Shimano chainring (or one listed as compatible). I am not certain about whether the Shimano 12 sp ring cares about the chain, though.
In any event, I am certain a non-Shimano 11 or 12 speed ring will work.
You may have already considered, this, but it is possible to convert most 2x and 3x cranks to 1x.
Advanced Slacker
Liked 2,557 Times
If you mean you have considered doing a 1x conversion with a 2x or 3x crank, then yes, you will definitely want a new ring, because you will want a Narrow/Wide ring which are 1x specific.
![lol](images/smilies/lol.gif)
