Yet another carbon wheel question
The roads near me are going longer between maintenance upgrades so some of my ride is on pristine tarmac, some is on post-apocalyptic tarmac. I have begun to wonder: are quality carbon wheels as likely/unlikely to cope with random cracks, bumps, divots etc of degraded roads as are aluminum wheels? Thanks in advance.
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
Those more qualified should chime in shortly, but until then........, here's my take. Quality carbon wheels (while admittedly being stronger) tend to be more expensive than aluminum, both to purchase initially, and when buying a replacement wheel.
It sounds like your conditions are not suited to nice, premium wheels, and especially not with thin,higher pressure tires. I'd consider some decent quality, but more robust and less expensive wheels, with some wider tires that will help cushion the impact on them. It sounds like you need to get low-weight out of your head entirely, if conditions are as you describe, and think more along the lines of, "strong, reliable-beaters" (IMHO).
I've read there's better options out there now, but for years one of the best heavy-duty wheels were the Mavic CXP33's, in 36 hole, with a decent but less expensive hub like 105 (that's just an example, but that's the way I'd be thinking). And again, replacing a jacked up wheel like this will be way less painful than half of some higher end carbon wheelset.
Another downside to carbon is that when they slam hard on a pot hole, I'd always be wondering in the back of my mind if I didn't really jack them up, and start them on the road towards a catastrophic failure. Someone will surely be along to take me to the woodshed on all that, but that's my .02, FWIW .
Likes For fietsbob:
I know in the mountain bike world there are a few carbon wheel manufactures that have a no questions asked for any reason carbon rim replacement deal. You pay for it up front but it is an option. Aren't there any roadie wheel guys offering that?
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Well, I should think they'll stand up to your roads just fine.
Likes For base2:
Very reasonable advice, and I thank you for it. I usually need lots of reasonable advice to counteract the very strong but unreasonable impulse to get bike stuff I don’t really need, like snazzy new wheels.
That said, I know they aren’t economical, and they aren’t going to cause significant improvement but a big consideration is - are they as durable?
However the only times carbon rims make any sense is when used in the highly aerodynamic area. like 30-100mm deep aero rims. since you can make the walls paper thin. so you save weight. its much thinner than you can extrude alu rims. so they weigh less.
but to be honest you really have to punish the crap out of the rims something serious to actually break any rims. alu or carbon. and then you are probably doing it wrong!
I would get alu since you simply have to worry less about it than carbon. alu will last longer i feel. a lot longer. its metal. the other one is plastic.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Santa Cruz Reserve rims/wheels now come in 700C options.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
ive bent a couple of aluminum rims , and saved one pair , if they where carbon i would have been out 800 plus , if you do go carbon start with a Chinese pair id say ?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Some misinformation in this thread already.
Decent quality carbon wheels will deform and regain its shape where aluminum alloy will bend permanently.
This isn't something I made up. Ask a wheelbuilder such as Psimet...
https://www.bikeforums.net/20740244-post16.html
And an explanation of why spoke count matters...
https://www.bikeforums.net/20741717-post31.html
-Tim-
-Tim-
Modern carbon rims are very, very strong, I have no qualms about riding mine on broken pavement.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Durable? both should last decades unless you are abusing them or crash. My weak point has been spokes which eventually just wear out - and I get tired of replacing them when they start going...
Senior member
Quoted: 943 Post(s)
Liked 658 Times
I have rebuilt numerous cf wheels that had suffered catastrophes that would have ended even a high quality aluminum rim's life.Carbon fiber has shape memory as you indicated, and makes survival for reuse more likely.
Thanks again
Thanks for the re-assurances; my dream to get carbon wheels has been fortified. And although nobody said so, I bet that the more I spend, the more forgiving they will be (even if my wife may not be).
I ride my Carbon wheels all the time (on year 3) on all road conditions...use 32 width tires...no issues.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
You might have broken one, but it takes quite an impact to do that. Enough that your Al wheel would have been a twisted taco.
Likes For TimothyH:
52psi
Quoted: 790 Post(s)
Liked 802 Times
^^ Well then.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Even many of the "cheap" Chinese carbon rims stand up to abuse better than aluminum ever could. I deal with large numbers of them, and failures are very rare.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
If we ignore super-light climbing wheels and 60mm deep-dish aero hoops, you're probably not going to see a huge amount of difference if it's say, a typical 20/24 spoke 30mm road wheel. The carbon might have more vibration damping with 23mm, 120psi tires, but your could get the same ride quality with Al rims and 28's for a couple of bills less.
You pays your money, you takes your choice.
