WTB nice vintage 28t inner 74mm and 38t/110mm black.
Quoted: 792 Post(s)
Liked 1,789 Times
I'm looking here to see if someone has these sense have gone nearly unabtainium on ebay or Amazon only a couple of not great options. Basically all I want is strait none worn rings of good quality 3/32 strait in the 28t inner 74mm and 38t middle 110m 5 hole pattern chain rings for a older MTB 89 Hardrock.
small ring
Quoted: 438 Post(s)
Liked 925 Times
Sram makes a black 38t for about $20
28s are expensive, might I suggest moving to a 30t? It's about 1.5 gear inches difference on the bottom end and it might be easier to get a cassette with an additional tooth or two on the biggest cog.
Not exactly what you want but as you discovered there's not a lot of options. It would be cheaper to buy a triple crank set than one 28t ring (speaking about new, of course)
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Not what you are asking, but modern 64/104mm bcd cranksets/chainrings are plenty and cheap.
Can use shorter bd if chainline is too far out.
Quoted: 792 Post(s)
Liked 1,789 Times
On this bike I really want to keep the really nice 175mm crankset with the same ring size and Strait type. It has 3 x 6 orignal accushift gearing which works real nice and is original to the bike. So it will be easier and better to find rings than change .
Quoted: 355 Post(s)
Liked 345 Times
Vuelta $18
https://www.ebay.com/itm/Vuelta-SE-F...bvEmDvlyGu5X-A
https://www.ebay.com/itm/Vuelta-SE-C...sAAOSwqOBe1re6
Italvega and Torpado Enthusiast
Quoted: 792 Post(s)
Liked 1,789 Times
I got the 28t and a 26t nice steel from Iowegian thanks. I'm still looking for nice vintage black 38t or 36t but not in a hurry I was able to clean up the teeth on the current ring with a round file and flip so I can likely get another 1000 miles out of it.
Likes For zukahn1:
