Ok, what model Peugeot is this:
Old 10-08-20, 03:58 PM
oneclick
Quoted: 1106 Post(s)
Liked 1,328 Times in 784 Posts
Looks like the PF60 in the 1982 US brochure on bikeboompeugeot.com, BUT this one has Mafac cantilever brakes, and the bars are Phillippe, and the crank is branded Peugeot (rings say stronglight) - and it goes 28-40-52 not 32-42-52 as in the brouchure...not that I'm complaining...
Everything looks original to me, Helicomatic with a 30-tooth big cog, Weinmann levers, Rigida eyeletted rims. Pedals will need work, does anyone have the caps for these (I need both).
Pics as received:
oneclick is offline
Old 10-08-20, 04:18 PM
francophile
PM me your cotters
francophile's Avatar
Quoted: 1137 Post(s)
Liked 590 Times in 422 Posts
Decals would put it more in the early-mid 80s. We could really use to know the number stamped into the bottom bracket so we can iron out the date.
But I will say, if memory recalls, outside of the MTB/ATB bikes, the Vagabond should've been roughly equipped the same.
francophile is offline
Old 10-08-20, 04:47 PM
oneclick
Originally Posted by francophile
decals would put it more in the early-mid 80s. We could really use to know the number stamped into the bottom bracket so we can iron out the date.
b3026620 - that's an upper-case B but the forum won't let me edit it to be one - odd.
oneclick is offline
Old 10-08-20, 04:56 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2298 Post(s)
Liked 2,055 Times in 1,255 Posts
Looks a lot like the Centenary we saw recently. '82?
Without the Aero shifters of course. And cantis?
clubman is offline
Old 10-08-20, 05:27 PM
francophile
PM me your cotters
It's a 1983, Feb '83 so early. Let me see what I can find. I know Vagabond fits roughly the bill in this case for US, but ... maybe it's CAN or EU
Actually, if Vitus, it's PF-something if we follow Peugeot's standards with regard to PF/PV/PSV
Likes For francophile:
Old 10-08-20, 05:54 PM
oneclick
Vitus 181 on the decal. All the PF60 images I've seen have centepull Mafacs, not cantis.
oneclick is offline
Old 10-08-20, 06:06 PM
francophile
PM me your cotters
Yeah, you got me on this one. There were a number of PFxx and PFNxx models. At least we know definitively the date of the frame, you should find the hubs, seat post and stem share an '82 or '83 date due to how closely the frame manufacture was to the 82/83 cusp.
Old 10-08-20, 08:45 PM
Chombi1
Chombi1's Avatar
Quoted: 1641 Post(s)
Liked 831 Times in 540 Posts
Decals are typical to 1983 models......
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
Chombi1 is offline
Likes For Chombi1:
Old 10-08-20, 09:54 PM
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times in 193 Posts
I'm the least qualified for this...
... but could it be an early cyclocross example? Notice no mounts really for racks, just mounts for mud guards. I've seen Pinarello's with similar brakes during that time.
Again, way out of my expertise area.
mechanicmatt is offline
Old 10-08-20, 10:15 PM
mechanicmatt
Quoted: 246 Post(s)
1983 PH60? I have found earlier examples of the PH60 with Cantilevers...
Old 10-09-20, 06:07 PM
oneclick
All the catalogues/brochures I looked at seemed to have PH models built with 103 or something else low-end - this one has the Vitus decal.
oneclick is offline
Old 10-11-20, 04:35 PM
oneclick
Ok, started taking it apart; there is good news and there is bad news.
Good news - everything is threaded english.
Bad - stuck seatpost.
frame is now upside down and penetrating oil being applied throuigh the BB shell (that's how I know it's english).
Edit: fork is 25mm and French. Tant pis, c'est normal.
Edit again, not english, swiss (see below).
oneclick is offline
Old 10-12-20, 05:47 AM
oneclick
This bike is seeming more and more like floor sweepings. I've looked at every 1980 to 1985 catalog on bikeboompeugeot, at pages & pages of google images for various searches involving combinations of vitus/peugeot/cantilever/touring/randonneur/etcetera, nothing matches. Cantilevers and a Vitus frame and a triple crankset - a wider triple than anything in the brochures; and pretty much surely 1983.
No paper label.
oneclick is offline
Old 10-12-20, 08:43 AM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
The important stuff - does it fit? how does it ride? good luck with the seat post
ryansu is offline
Likes For ryansu:
Old 10-12-20, 09:23 AM
oneclick
After finding the fork was metric I started measuring and checking things again.
Tubes are metric - Steerer 25mm, seat and down 28.1 (paint) and top 26.1 (again paint).
And that adjustable cup that came out nice and easy left-handed? Not English, it's SWISS, both cups are metric.
What the hell have I got here?
oneclick is offline
Old 10-12-20, 10:11 AM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,296 Times in 866 Posts
Chainstays look short, so looking more like a cyclocross model than any touring bike.
But a cyclocross bike doesn't typically have a triple. I use a triple for CX so that the chain has a good place to fall if it does fall off the small ring.
dddd is offline
Old 10-12-20, 10:43 AM
oneclick
16 3/4" from crank centre to the back of the axle slot.
oneclick is offline
Old 10-13-20, 05:29 AM
oneclick
More measurements - 126mm rear, frame weighs 4.6 lbs, for 1.7 lbs, Seat post is 26.3-ish (got the damm thing out, had quite a crust of corrosion on it, might have made it a bit smaller cleaning all that off).
That's a pretty light frame for steel-not-high-end, I'm happy, except now I don't know what to do with it. It's too big for me, I already have a tourer.
It's a shame to part it out - it's in fabulous shape and everything matches - but who would buy it whole, with all the oddities - swiss BB, french steerer,metric tubes, cantis - plus shipping form here?
oneclick is offline
Old 10-13-20, 07:12 AM
John E
feros ferio
John E's Avatar
Quoted: 1393 Post(s)
Liked 1,329 Times in 837 Posts
I presume you mean the left-threaded fixed cup. My 1980 PKN-10 has as Swiss-threaded bottom bracket, so I am not surprised your Peugeot does, as well.
John E is offline
Old 10-13-20, 07:15 AM
John E
feros ferio
John E's Avatar
A 26.4mm seat post is entirely consistent with a double-butted moly steel frame with a hard metric 28mm outer diameter seat tube.
Nice find!
The deviation between your chainring sizes and those in the catalog could just be the result of a bit of "gear freaking" or customization on the part of an earlier owner, or just a substitution at the factory because of a parts shortage. I have routinely regeared every bicycle I have owned, to meet my own needs -- there is absolutely nothing sacred about catalog-listed tooth counts on either the crank or the rear axle.
John E is offline
Old 09-20-21, 06:55 AM
T-Mar
Quoted: 4722 Post(s)
Liked 3,039 Times in 1,877 Posts
I checked my Canadian market literature and there was nothing with cantilevers in 1983 (or 1982 and 1984).
T-Mar is offline
Old 04-04-22, 12:54 PM
paulocaputo
very nice bike, beatiful one
paulocaputo is offline
Old 04-04-22, 06:39 PM
oneclick
This might well be an import, from what I remember of the conversation with the seller (left behind in an apt complex by departed foreign tenants, after <n> months stuff gets sold).
oneclick is offline
