Frame Fit Pumps
Frame Fit Pumps
Old 10-11-20, 07:55 PM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
Frame Fit Pumps
I got a flat today. It was my first flat in a very long time. The latex tube failed by blowing out into a spoke recess (even though it was covered with an intact rim strip).
I had a Lyzene mini-pump and a spare tube with me, so I was not stranded. It did point out how insufficient those mini-pumps are when trying to reach 100-120 psi.
I limped back home on a tire inflated to only about 60-70 psi.
Ironically, I have a vintage Silca Impero but took it off the bike. I get so few flats, I was looking to preserve it.
So, what does the hive know about the new Silca Impero frame pump? Anyone have one? They are expensive ($165) but do they work?
Bad Lag is offline
Old 10-11-20, 08:35 PM
davester
davester's Avatar
Quoted: 930 Post(s)
Liked 1,293 Times in 489 Posts
The vintage versions (sporting Campagnolo metal heads) can usually be picked up pretty cheaply, work much better than the mini pumps, look better than the modern version, and only weigh an ounce or two more than the mini pumps. I find myself often telling riders I encounter on the road who are struggling with their mini pumps or have accidentally released all the CO2 in their cartridge to get out of the way so that I can pump up their tire with a real pump. Zefal HPs are functionally even better, though are less attractive. All my road bikes have either vintage Silca Imperos or Zefal HPs.
davester is offline
Likes For davester:
Old 10-11-20, 10:49 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times in 7,209 Posts
...I cannot pump a road tyre with a Silca frame pump much beyond 80 psi. Even with all the various bracing tricks, I still can't reliably expect much over that pressure. With a Zefal HPX frame pump, I can get to 120psi pretty dependably. I know there are people who really like Silca frame pumps here. I am just not one of them. I don't carry a pump on the frame for how it looks.
3alarmer is offline
Old 10-12-20, 01:00 AM
Dfrost
Dfrost's Avatar
Quoted: 502 Post(s)
Liked 466 Times in 256 Posts
Neither wife nor I feel “safe” riding without a useful pump, every ride. We’ve had too many surprising flats in our combined 65+ years of road riding. And we’ve each helped out a few folks, typically experienced riders, who didn’t carry a pump for whatever reason.
We use Topeak full size frame pumps (apparently no longer made), like a Zefal HPX but without the annoying rattle-causing flared handle, on the bikes with a pump peg. The others with no peg but two bottle mounts get the largest size Lezyne road drive. It has reliably and without much difficulty/too many strokes got a 28mm tire to its nominal 85 psi, measured with a Lezyne in-line gauge that is surprisingly accurate. The Lezyne is attached with the included pump mount under a water bottle cage.
Dfrost is offline
Old 10-12-20, 05:59 AM
smontanaro
Bikes: many
Quoted: 1445 Post(s)
Liked 1,395 Times in 762 Posts
I use a Zefal HP. In fact, I like them so we'll, when my 40-ish year old pump gave up the ghost, I scrounged a small collection from someone who had several take-offs laying around and now have two working pumps and a third which might work in a pinch.
The HPx is the current incarnation of that series and is, I believe, still in production. I'd give that a look-see. You might well need a pump clip, but that's easily found.
Monti Special
smontanaro is online now
Old 10-12-20, 06:41 AM
jamesdak
Quoted: 2324 Post(s)
Liked 4,992 Times in 1,777 Posts
Yep, I pretty much carry a Zefal HPx on every ride no matter which bike I take. Only have a few I can't fit one on. That said, to be honest I also carry a CO2 setup with me also with and extra cartridge. Plenty of room in my saddle bag for that , two spares, two tire levers, etc.
I usually flat only once or twice a year and the last couple of times it's been super quick and easy getting back on the road using the CO2. But I will always carry a Zefal as a dependable backup.
I recently picked up another one so they are still around. Sometimes hard to find the size you need to fit your bike though. Remember to take that into consideration.
Steel is real...and comfy.
jamesdak is offline
Old 10-12-20, 09:26 AM
Mr. Spadoni
Quoted: 362 Post(s)
Liked 408 Times in 220 Posts
HPXs are almost always on the Rivendell site but My last two came from garage sales. Goal is to collect enough that I don’t have to swap them between bikes.
Mr. Spadoni is offline
Likes For Mr. Spadoni:
Old 10-12-20, 09:27 AM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
I like Leyzene pumps - I have three - and 80 psi is perfectly adequate for me to get home, I don't even consider that limping, I can see that if I felt I just had to have 120 PSI that the leyzene might not be up to that task but I have not needed anything over 100 psi in at least a decade, I am not sure my local roads would be very welcoming for a bike running 120 PSI tires
ryansu is offline
Old 10-12-20, 09:31 AM
jamesdak
Originally Posted by Dfrost
... like a Zefal HPX but without the annoying rattle-causing flared handle, on the bikes with a pump peg.
??? I've got 4 of these I use and no rattle. Just curious, do you mean the pump handle itself or the lock lever for when you lock it onto the valve?
jamesdak is offline
Old 10-12-20, 09:37 AM
Salamandrine
Quoted: 2317 Post(s)
Liked 597 Times in 430 Posts
FWIW, I've never had a problem reaching 100+ psi with a Silca and campy metal head. Generally I used to run my training sew ups at 100. The silca plastic heads that came with the pumps kinda sucked IIRC.
I can't speak to the reissues. Pretty different pump, from what I can tell.
Salamandrine is offline
Old 10-12-20, 09:48 AM
Bad Lag
Is this a strength issue you have or are you saying the pump and its seals cannot go over 80 psi? Zefal has a smaller diameter tube, less cross sectional area, so it requires less force to reach a given pressure.
Bad Lag is offline
Old 10-12-20, 10:04 AM
northbend
northbend's Avatar
Quoted: 554 Post(s)
Liked 3,794 Times in 668 Posts
I use one of those new Silca Frame pumps on my touring bike. The bike as a whole, is what I consider an affordable luxury, the pump being part of that package.
It works fine but not head and shoulders above any other frame pumps I use (Zefal, Topeak) on other bikes.
Of the three, the Zefal is the best from a functional point of view, the Topeak the least.
The new Silca is heavy compared to the others, much more solid and sturdy.
I am sure I could hold off a pack of wild dogs with it and I like how it looks.
northbend is offline
Likes For northbend:
Old 10-12-20, 02:30 PM
Dfrost
Dfrost's Avatar
Quoted: 502 Post(s)
The Zefal rattle was caused by the pump handle flare against the frame tube, not the locking lever. It was probably the result of pump pegs positioned a bit closer to the TT (Klein and Erickson frames), certainly not a problem for most. Those HPX pumps are very nice and I’ve got a few in our two sizes tucked away. At the time, we solved it by wrapping window seal strips around the handle.
Dfrost is offline
Old 10-12-20, 02:39 PM
Kabuki12
Quoted: 874 Post(s)
Liked 2,291 Times in 1,280 Posts
My Silca Impero pumps still work fine but 65lbs maybe 75lbs tops. It gets me home but that's about it. My Zefal HP pumps are definitely better and can easily pump 80-90 lbs. The Silca pumps are on the bikes and are original matching pumps but I really should overhaul them , maybe it would change my opinion of them . Both work ! Joe joesvintageroadbikes.wordpress
Kabuki12 is offline
Old 10-12-20, 02:52 PM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
I had two ancient HPX-4s around, that I was hoping to make into one functional one. But alas they only come apart so far, and what I needed to do couldn't be done(by me anyway). I now have three HPX-3s, for my three regular riders. And nice chrome pump umbrellas to mount them with.
seedsbelize is offline
Old 10-12-20, 03:52 PM
philbob57
Quoted: 715 Post(s)
Liked 613 Times in 377 Posts
The failure point of the Zefal HP that stumped me the most was the piston seal. If you come across an HP with that problem, an OEM replacement is available from a seller on the 'bay for $13.49, including shipping. (I am not connected in any way with the seller, except as a customer.) I imagine it's available directly from Zefal, too, for Europeans.
philbob57 is offline
Old 10-12-20, 05:12 PM
Salamandrine
If a Silca frame pump won't pump higher than 75 or 80, then likely the seals in the pump head need to be replaced, and/or the main diaphragm needs to be greased or possibly replaced. 110+ no problem with a Silca in good condition. They are trickier to use than a Zefal HP/HPX, and require technique and a bit of strength.
It's kind of funny that the reissues are on the heavy side. The main reason people used Silcas BITD was because they were very light. Perhaps they figure the target market demographic is not longer worried about a few ounces here or there...
Old 10-12-20, 05:33 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 868 Post(s)
Liked 721 Times in 396 Posts
Zefal HPx here too.
Reynolds is offline
Old 10-12-20, 06:39 PM
top506
Death fork? Naaaah!!
top506's Avatar
Bikes: Seriously downsizing.
Quoted: 559 Post(s)
Liked 631 Times in 282 Posts
Zefal will ship direct to the US.
Top
top506 is offline
Old 10-12-20, 11:31 PM
Bad Lag
Maybe I should just get my old Silca Impero back on the bike.
Bad Lag is offline
Likes For Bad Lag:
Old 10-13-20, 12:34 AM
bikingshearer
Crawlin' up, flyin' down
bikingshearer's Avatar
Quoted: 1027 Post(s)
Liked 2,531 Times in 1,059 Posts
+1 on everything in this post.
BTW, Zefal XPs may be the best dog defense system ever made. Silcas are okay, Zefals are more substantial.
bikingshearer is offline
Old 10-14-20, 06:00 PM
devinfan
devinfan's Avatar
Quoted: 100 Post(s)
Liked 50 Times in 27 Posts
I’m not sure vintage Silcas work the absolute best, but they definitely look the best!
devinfan is offline
Old 10-14-20, 06:03 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
I have a Park frame pump. Nice thing is it's adjustable, so fits on different frames.
Homebrew01 is offline
