Box brakes help!!!
Boom
Quoted: 5 Post(s)
Box brakes help!!!
my bike has box brakes in the front and they keep squeaking loud. I tried spraying them with wd40 that helped for maybe two days. Then I noticed the rim had black rings around it so I cleaned it off but after a few days they are back to squeaking. Should I just change the pads? Or should I sand the rim down? Not sure what to do.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Replace the pads, clean the rim thoroughly with fine steel wool and a cloth with rubbing alcohol, and never use oil on them again. If you're not sure how to adjust brakes properly, including proper toe-in, get some help with it.
Quoted: 4201 Post(s)
Liked 3,857 Times
Quoted: 1572 Post(s)
Liked 643 Times
Might be the answer right there. There is almost nothing that can't be made a little bit more cheaply but worse.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
As mentioned, toe-in might fix the squeak, but clean the WD40 off of everything and possibly get new pads.
China works for less than even South Carolina.. expect logo is all that is added ...
I'll wait for the pictures ...
whole bike in house manufacturing was more a fact in Soviet Bloc Eastern countries in the 60's & 70's
when they were not permitted to buy parts from the West..
Liked 2,011 Times
Box is new in the mountain bike world, but I don't think it's the typical Chinese copy junk. They're trying to be a viable alternative to the Shimano/SRAM, but that's a touch road.
