Best setback seatposts?
Quoted: 1856 Post(s)
Liked 664 Times
I need a setback seatpost 27.2 mm, 27 cm or so. I've seen two main choices lately: the V-O two-bolt Gran Cru with Long Setback for $55, and the Nitto S-84 seatpost for about $160 right now at Rivendell. The Nitto setback is claimed 40 mm and the V-O is claimed 30 mm. From both companies "normal" setback posts are 15 mm to 20 mm, so these both give me more setback, which I need for Brooks or my Rivet.
The Nitto obviously costs nearly 3x the price of the V-O. How big is the quality difference between them, if here is one? i have a few of the Nitto and they have been good parts, but is anything lost if I buy the Velo-Orange instead?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Nitto S84 - $99
https://alexscycle.com/products/nitt...ged-seatpost-1
I've ordered from Alex's many times. They are legitimate with five day shipping to Atlanta from Osaka.
Track Supermarket has it for $100.
https://www.tracksupermarket.com/sad...st-27-2mm.html
-Tim-
-Tim-
Likes For Gconan:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
I have used the S-83
https://www.universalcycles.com/shopping/product_details.php?id=18232&category=167
S-84 is steel.
S-84 is steel.
The Left Coast, USA
Quoted: 18410 Post(s)
Liked 15,530 Times
Liked 664 Times
The Thompson and the S83 have nowhere near the setback of the S84. They are not on the table.
Liked 664 Times
Two-bolt is a need and the Thomson is a great design, but again it does not have adequate setback. At the same time, I can adjust an original Campagnolo Record with as much precision and stability. That Campy also has inadequate setback.
Liked 664 Times
Liked 664 Times
Nitto S84 - $99
-Tim-
-Tim-
Liked 742 Times
With 20-25mm of setback, a Brooks saddle pushed all the way back, is usually adequate. Why the need for this extra setback. Frame too small?
The Left Coast, USA
Strangely, I found a thudbuster was the perfect solution of rme. Lots of setback, micro adjustment, and suspension to boot. Big and heavy, of course. On another bike, the bent Thomson.
These problems had to do with using a Brooks B17. As I use Ergon pro carbon saddles on my fast rider bikes the set backs available are fine as is.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
That S-84 is a nifty piece. I hadn't seen one before finding this thread. Can't help but wonder though why the need for that much setback? If you truly need that much setback to achieve a good knee over pedal position the seat tube angle on your frame is too steep.
Best?
# 1 V O is an importing seller not a manufacturer ..
Q: what do you understand about the strengths of different alloys of aluminum. .. ?
generally, How about this one.. ?
A Nitto chromoly seat post has significant setback
Liked 664 Times
Likes For Road Fan:
Liked 664 Times
Fiets, which question are you directing to whom? what is your point regarding materials science, and regarding V-O? I'm pretty good at materials.
Cycleway town
I made this one...
Likes For MikeyMK:
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
But alas when looking for a lot of set back that is usually a good sign of a poor fitting bike. Bikes that fit are great, bikes that need a lot of parts to try to make it sort of fit aren't so great. I get it though sometimes there is a cool old frame you see and it is fairly unique or sufficiently vintage that finding another in your size is hard but you might just let it go and find the bike that fits.
Getting that out of the way, Nitto makes some top quality parts, a lot of time cold forged for extra strength and durability and they really take a lot of time and pride in their work. The only thing one could say about Nitto is there stuff can be weighty but their goal is not weight but quality and durability.
Basically to BF level generalizations; aluminum various alloys can be like steel ; ..high strength use less , low cost use more. to be equivalent .. in practical, use,..
- Soli Deo Gloria -
Liked 736 Times
Maybe the guy has a physical issue where he needs setback.
Maybe he is experimenting and wants to learn for himself.
Maybe he doesn't feel like getting lectured by a bunch of people who never met him but knows exactly what he needs.
Maybe he wants what he wants and that's all there is to it.
My pleasure. I hope it works for you.
-Tim-
-Tim-
Likes For TimothyH:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Is this an enquiry about non CF seatposts? Fwiw, FSA offers a K-force seatpost with 32mm of setback..
Quoted: 4805 Post(s)
Liked 3,927 Times
So, you have the option of ordering a TiCycles post of any setback you want with that first-class hardware. And being completely custom, everything, post length, material and diameter, finish, etc, are on the table. 2011 prices were ~$160 for mine. Their prices have gone up but not radically.
Edit: I hadn't read veganbike's post above yet when I wrote this, but I submit it now as an example that his generality isn't always true.
Ben
Liked 664 Times
Liked 664 Times
But ... Thompson clamp parts can be purchased from Thompson so a framebuilder with skills could make you a custom post of any setback using Thompson hardware. I have two TiCycles posts with aluminum heads and titanium posts, each with roughly 60 mm setback. Wonderful posts. (My preferred bike, no holds barred, has a tight rear end, 74 or steeper seattube (to accommodate the close rear wheel with decent size tires and fender. I want a setup that puts the clamp midway on my favorite seats so lots of options are available in the future. So I could go either curved seattube or big setback post. Maybe one day I'll spring for that curved tube.)
Ben
Ben
Liked 664 Times
Still not sure what you’re trying to say. The S83 is all Al, alloyed in some composition. The S84 has an Al head joined to a steel post. I see no problem with the S84 construction, nor that of the S83.
