New brake lever is hard to pull
I replaced my old rear (left) brake lever (Sunlite) with a Tektro RL-520. It takes a lot of grip to get any braking; all my strength doesn't get as much as I used to get with the old lever. The lever works freely when the cable wire isn't attached to the brakes (cantilever); the wire runs through the housing freely. It seems that the lever tightens up when there's tension. I followed the instructions. Could I have missed something? I've had the replacement levers for 3 years, waiting for a wire to break to bother to replace, so it's a new wire and I still have the old lever on the front brake. I lubricated the housing.
Likes For Rick:
Likes For Rick:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Yep, easy mistake to make. It's good you found out before you needed to make a fast stop.
If there's a co-op or non-profit bike shop nearby, that would be a good home for the levers.
It's a Pair
a V brake has a lot of MA, so demands more cable pull ,
the hand-lever must deliver that long cable pull by having a lower MA..
I improved the effort required to pull my brake lever on my V brake bike,
by going from a short, 2 finger lever , .. to a longer 3~4 finger brake lever . still a lower MA long cable pull
but a longer brake lever handle to pull it..
OTOH inverse: short cable pull demand by brake road caliper etc. , then brake lever has higher MA
. pulling less cable with greater leverage..
distance from pivot axis, to where cable end goes , is much shorter than distance length of hand lever to that axis..
classical mechanics of the lever, as old as civilization itself..
Bought Tektro RL-340s, also put new pads on the front (the old were near the metal). It's a real joy. A frugalist, I let things go until they're completely worn out, get used to the slowly-degrading performance.
Quoted: 4802 Post(s)
Liked 3,922 Times
I am actually a fan of those V-brake levers and good, powerful, conventional calipers. I have them on my three good bikes with dual pivots and cantis. Yes, braking suffers a little from the hoods but I have been in the habit of being in the drops for serious braking (as I was taught 40 years ago). I love that I can come to a blind mountain corner that is much sharper than expected, slam on the brakes with full grabs and nothing happens except I slow a lot. I also love the huge hangles they provide for climbing.
Edit: modulation in the form of squeeze distance basically doesn't exist but modulation in terms of squeeze effort is excellent. That setup also means brake clearances are large, a nice plus with big tires and skinny rims.
Ben
Ben
