Carbon Frame - Tap test. What do you think?
Legs; OK! Lungs; not!
Bikes: ''09 Motobecane Immortal Pro (Yellow), '02 Diamondback Hybrid, '09 Lamborghini Viaggio, ''11 Cervelo P2
Liked 9 Times
Had a rather bad experience a week ago when, unbeknownst to me, a small rag fell out of my back jersey pocket and fell on my chain at a stop light. When I took off, the rag got sucked into the RD and snapped it off. The pulley housing came around and hit the seat stay. See it here: https://www.bikeforums.net/showthread.php?t=593808
Anyway, when I asked about assessing the damage, one of the posters suggested the "tap test." The idea behind it is sound (no pun intended.) Tapping a good carbon tube will yield a certain sound. If it is cracked, the sound will be "dead." Short of an Xray, it seems like a petty good test.
What do you think?
BTW, the mfgr has a "no-fault" replacement policy, but since this "failure" is not "manufacturing defect" related, it will not be a "no charge" replacement. There will be a discount off list. I figure I'll probably just ride the crap out of it and if it fails (and I survive) I'll consider the replacement then.
What do you think?
Actually, the tap test would work as long as you had a control group to compare it to (ie another identical frame). Solid tubes make one kind of sound, a cracked/broken tube will make another. In a non cycling example, a solid bell will make a pure ringing tone, a cracked bell just clanks.
Well your "control group" is a normal part of your frame in a similar area. Since your frame is still a frame and not a pile of rubble I'm assuming you have something to compare it to. And you probably don't want to ride it till it fails... not a good plan.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
I just don't think you are going to be able to discern enough of a difference. Especially given the damage to the OP's frame that I remember from another thread.
And there is the 64 dollar question, it kind of depends on how much ring you get to begin with, with a metal frame I would think that the difference would be more obvious.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
All of this sounds bad. Buy a frame and move on.
Michael
Michael
Quoted: 551 Post(s)
Liked 277 Times
A tap test? Well and good, but do you have the ears to discern subtle differences and the knowledge which sound is which?
Certifiable Bike "Expert"
Wheelsuck
I work with carbon structures quite a bit. As a first cut, this is actually a pretty decent way to determine if it's OK or not. It's more of a way to see if the carbon had delaminated from some sort of core (often foam or honeycomb), but could be used on tubes as well. The deal with tubes is that if you've hit it hard enough to mess it up, it will usually have a massive tear, dent or kink in the tube (and, yes, you can 'dent' a carbon structure, it is not always a catastrophic failure) that will be pretty much impossible to ignore.
So, if you take a screwdriver and tap it on a part of the frame that you know is good, it'll give you a certain sound which will be very sharp. Move around the entire bike. It will continue to sound the same way unless you get to a bad spot which will sound very flat. I don't know how else to describe it, but if you get to a bad spot, they really stand out.
Incidently, the is a reasonable way to do non-destructive testing on a lot of things. Steel parts will often 'ring' when hit with a screwdriver (assuming you aren't damping the vibrations by holding the piece in your hand). If the piece is cracked, it won't ring. Again, a little hard to describe, but very apparent once you come across it in real life.
Bikes: Specialized Roubaix Comp, Soma ES
psst... Just get you some yellow fingernail polish or model paint and cover the marks. Ride it till it falls apart one day. Make sure your medical and dental insurance is adequate.
Demented internet tail wagging imbicile.
Wheelsuck
This is really a case where you need to be able to have the ability to 'show and tell'. It's tough to describe it like this. It's probably not a good way of testing for a rank amateur.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
such as the other seat stay.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
Carpe Diem
Bikes: 2007 CAAD9; 2014 CAADX; PedalForce CG1
i've done this. friend endoed on his Felt F1SL. The bike suffered little cosmetic damage but the friend thought his top tube might be cracked, based on how the bike landed. Everything looked fine, but we did the "tap test" with a quarter and there was a noticeable difference in sound at one spot on the top tube. Whereas surrounding areas rapped sharply, this one spot thudded lifelessly.
Frame got sent to Felt and, sure enough, there was a crack in that spot.
"When you are chewing the bars at the business end of a 90 mile road race you really dont care what gear you have hanging from your bike so long as it works."
ΛΧΑ ΔΞ179 - 15% off your first Hammer Nutrition order!
Liked 9 Times
Indeed, I used the other seat stay as a control. There was no difference in the sound of the two. Several people in this forum and others have suggested this is a very good method.
Microscopic examination with a magnifying glass is also a good way, looking for damage to the carbon layer. This too appears fine. The damage appears limited to the paint and primer layers.
The plan now is to cover the "wounds" with a clear coat, apply bondo and sand down smooth. I'll then either mask and spray with black paint, or better yet, find an appropriate decal(s) to cover the spot and the corresponding area on the other seat stay.
Liked 9 Times
Bikes: 1976 Fuji America 1980 Fuji America 1984 Fuji America TS V 1982 Fuji Royale II 1993 Trek 970 1997 Trek 5000 2004 Trek Calypso 2007 Trek Portland 2008 Surly LTH
Liked 8 Times
https://rgl.faa.gov/Regulatory_and_Gu...LE/ac145-6.pdf
ultrasonic or other approved NDI methods)
a. Damage Assessment and Teardown....
Due to the tendency of composites to rebound and mask any impact damage, and the strong likelihood of non-visible microcracking, a visual inspection or coin tap test for determination of the extent
of any composite damage should be supplemented with additional NDI techniques ( i.e.,
Spotty Herbert
Oh Dear Lord,
That's SOP from the FAA? Do I have to watch out for guys walking around under the plane with a quarter on my next flight? Fantastic.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
I have Level II NDI cert and yes, the tap test is valid. We use it on aircraft, a simple quarter and the human ear is decidedly one of the best ways to find delaminated areas or voids in composities. The difference in sound is easy to pick up. Of course we use other methods to delineate the damage for repair.
With a coin, tap the tube starting above the damaged area and continuie across the damage, if there is a change in tone that area is higly suspect.
Liked 9 Times
Due to the shape of the seat stay, there is a change in tone across the entire seat stay, the thicker top being low pitched, and thinner bottom being higher pitched. The important point here is to note that the same tones were heard across the same span of the "control" undamaged seat stay.
