Any headlights designed for GoPro hanging mount?
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
Hi All,
I'm looking to see if there are any headlights specifically designed to use a lower or hanging GoPro mount such as you find on those out-front Garmin mounts. You know what I mean:
I've seen that light brands like Lezyne, Blackburn, NiteRider and Light&Motion have GoPro mount options, but the actual headlamps are just their regular ones, which are really designed to mount above the bar.
A purpose-built light for that mount position is what I'd like, such that design elements like lens hoods, graphics, and control buttons would be properly located for their purpose and use in the lower position.
Anyone seen a light like that?
Thanks!
Thanks!
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Garmin UT800:
https://www.amazon.com/Garmin-Varia-...keywords=ut800
Have one on my k-edge. You can monitor it with your garmin (battery level etc.) and can se it up in various automatic modes (if you have garmin, brightness based on speed, etc). Button is on the side, so easily accessible.
Thread Killer
Liked 1,704 Times
Ah, yes, thanks @GeneO! I have seen the UT800, and as a Wahoo user, it's a little less attractive because of the lost functionality, although the styling doesn't catch me, either.
Quoted: 2604 Post(s)
Liked 1,928 Times
I don't know if the Cycliq (https://cycliq.com/products/fly12/) cares which end is up, unless you think the writing on the side is significant. Interesting concept, I'm not sure how I feel about the combination of a light and camera, but it makes SWMBO feel better.
Thread Killer
Liked 1,704 Times
Thread Killer
Liked 1,704 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Light & Motion Urban 650 - $39
https://www.excelsports.com/main.asp...ajor=3&minor=6
Light & Motion Urban 800 Fast Charge - $69
Both have GoPro mounts. I own the 800 fast charge and paid $120 for it when it first came out.
-Tim-
-Tim-
Thread Killer
Liked 1,704 Times
But, I ain't...that smart.
Ride it like you stole it
There is a guy from Vancouver BC that has aluminum GoPro style mounts for the Magicshine lights. If I can find the link I will post it. He is usually on MTBR.com
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
Thread Killer
Liked 1,704 Times
https://www.sigmasport.com/en/produkt...0?submenu=sets
https://www.amazon.de/SIGMA-17003-Ad.../dp/B01MU9BRA6
https://www.ebay.com/sch/Lights-Refl...r&LH_PrefLoc=2
Also there are option to mix differend kinds of mounts ant lights together.
lupine.de/products/parts-and-accessories/mountkits/adapter-for-gopro
lupine-shop.com/en/accessoires-and-parts/gopro-for-lupine/
shop.supernova-design.com/shop/product/supernova-gopro-mount-160?category=226
bumm.de/en/products/akku-scheinwerfer/parent/164/produkt/164bla-silber-164bmla-schwarz.html
Or you use an GoPro mount extension stick and go for the Outbound Light Focal Series kickstarter project:
google.de/search?q=gopro+extension
forums.mtbr.com/lights-night-riding/outbound-lighting-focal-series-discussion-1055278.html
They have some internal battery lamps:
Magicshine Lights - EAGLE DV Action Camera with 1400 lumens
Magicshine Lights - Monteer 1400
Magicshine Lights - EAGLE 600
Thread Killer
Liked 1,704 Times
Sire, Sigma Buster 2000.
SIGMA SPORT
SIGMA SPORT
Thread Killer
Liked 1,704 Times
Is this the place: GoPro Mounts and custom parts
Thread Killer
Liked 1,704 Times
Sweet, thanks for the heads-up. The Magicshine Monteer is more than I need, but maybe I’ll check to see if there is a GoPro mount for its Eagle mount system. I’m hoping to pull off a tour in southern Brazil/Uruguay in the next couple of years, and the discreet, dual circuitry with easy swap 18650 cells is attractive for that.
Thanks. Although none of those are what I am looking for, it’s nice to be aware of options.
The Lupine SLA is so very close to what I want stylistically, and really cool, but needs on-board battery, topside mount point, and relocated controls. It’s so neat, though, I might just want one anyway!
For example, combining the Supernova Adapter with the B&M IQ-X Speed and the K-edge holder gives you plenty of light with cutoff-beam.
What exactly do you mean with onboard battery? The frame-mounted battery pack of the SL A is connected to the lighthead via DC-cable.
Mounting point can be topside or downside, since the mounting holes are on the side of the lamp.
Thread Killer
Liked 1,704 Times
So what exactly are you looking for, when all these options to mount a light below the handlebar aren't the ones you want?
I want a simple, single-unit (i.e. battery & lamp in same housing) solution which is meant and designed to be mounted by the top of the unit.
Looking at the example of the desired light type and mount position pictured below, you can clearly see that the light was neither designed nor meant to be mounted in that position. Lettering and housing design elements plainly indicate it is upside down, the mount is an ungainly, afterthought adapter, and control buttons and indicators are out of sight underneath the unit. Bad.
Non omnino gravis
The Light & Motion lights operate from a single button, which does indeed face down when the light is mounted underneath a Garmin. But the light itself is not up/down directional like many lights, and I find the light far easier to operate "upside down" than "right side up." Also really helps that the lights are plenty bright, inexpensive, and the GoPro adapter is $12.
Added bonus, the amber side markers are really nice.
Thread Killer
Liked 1,704 Times
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 102 Post(s)
Liked 26 Times
I appreciate that you are looking for a battery powered solution so discard this post from that perspective but since dynamo lights got referred to I thought I would mention that Busch & Muller and Schmidt do dynamo front lights designed to be mounted "upside down."
The Schmidt Edelux II comes with a version which is an upside down mount:
and the Busch & Muller Lumotec IQ-X mounting ring can be turned to mount the light upside down [and it is designed for that purpose].
- Soli Deo Gloria -
Liked 736 Times
Barfly mount with Light & Motion Urban light.
Thread Killer
Liked 1,704 Times
Oh, I just read DCRainmaker's review, and I didn't realize the comm channel with a GPS head unit (for settings and features like auto speed dimming) is an open ANT+ protocol, so Wahoo could enable that functionality in future firmware updates to ELEMNT, so maybe the UT800 will be the one after all! Thanks again.
Thread Killer
Liked 1,704 Times
Also, Cycliq just announced their new Fly12 CE model, which is a light/safety cam combo. Not bad!
https://www.dcrainmaker.com/2017/11/...irst-look.html
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Hi All,
Thanks!
Thanks!
Stuart Black
Stuart Black
