Looking at clothes for winter cycling
Old 08-18-19, 11:36 AM
voyager1
voyager1's Avatar
Bikes: 2018 Trek Domane SL5
Quoted: 81 Post(s)
Liked 5 Times in 5 Posts
I am going to be doing an event in the spring next year, and this is going to require me to actually ride more in the early mornings before work this winter. Looking at building up a little cycling wardrobe. I looked at the winter cycling forum, looks like that is more of a commuting forum. Location is Birmingham Alabama, so no snow.
Here is a tentative list. Any suggestions or substitutions welcomed!
Arm Warmer
Gloves
Maybe these gloves too
Vest
Alternative Vest
Jacket
Alternative Jacket
Tights
I have a Castelli Head Thingy to use as a buff to already. Used it this past winter, and it worked well. I didn't ride a bunch this past winter, and most of the clothes I used were just old running stuff. Worked fine for short rides (10-12 miles) here and there.
voyager1 is offline
Old 08-18-19, 11:57 AM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
Your lists looks very good. Everybody is different in terms of how their bodies react to cold weather. I know guys who ride with Arm and leg warmers with a thermal vest in 40 degree weather. As you ride in colder weather, you will have a better idea of what you need to buy.
colnago62 is offline
Old 08-18-19, 01:42 PM
MSchott
Bikes: 2017 Specialized Roubaix Sport SL4
Quoted: 94 Post(s)
Liked 44 Times in 33 Posts
Not sure how cold it gets in Birmingham, AL but if you need all that you need neoprene covers for your clipless shoes.
MSchott is offline
Old 08-18-19, 03:37 PM
voyager1
voyager1's Avatar
Quoted: 81 Post(s)
Oh good point. Many of the mornings in Jan and Feb can be in the high 20s.
voyager1 is offline
Old 08-18-19, 06:05 PM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
I like a thermal jersey plus wind shell.
By itself, the thermal jersey is insulating but has no wind protection. Without a top layer it's comfortable through 60 degrees.
By itself, the wind shell has no insulation so it fits in a jersey pocket as the temperature warms up.
Together, they're peasant at 40-45 degrees. Below that I substitute an insulated jacket for the shell.
I really like the Louis Garneau speedzone jackets (available through their custom program), also available as vests.
They have a hole in back so you can keep everything in your jersey pockets and get at them while riding.
I'm more of a wind shell than vest sort of guy. If it's cold enough I want the wind blocked, I don't want cold arms.
I like thermal tights over regular cycling shorts. That lets you have a clean chamois every day without doing laundry that frequently or owning a closet full of tights you only wear three months out of the year, and pull them off as it warms up over a few hours.
Drew Eckhardt is offline
Old 08-18-19, 06:08 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
Definitely something for your feet. I would suggest wearing your normal bibs and getting a few pair of waist tights in different weights. The two layers will be warmer where it counts and you'll have more versatility. A newspaper stuffed in the jersey front works great and can be ditched when you warm up.
shelbyfv is offline
Old 08-18-19, 07:18 PM
CadenceCrazy
Bikes: Nashbar CR5 Ultegra, Trek 2300
Quoted: 14 Post(s)
Liked 4 Times in 4 Posts
I've lived in Montgomery and Selma and remember pretty cool winter temps . On cold mornings, don't forget your balaclava and possibly a helmet cover.
I also recommend non-chamois tights over your normal bibs.
Sierra Trading Post, among others, can have some notable sales.
CadenceCrazy is offline
Old 08-18-19, 09:42 PM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Consider a carbon fabric baselayer top. Pearl Izumi's Minerale fabric was outstanding but discontinued and new/old stock is decreasing in choices of sizes and types. It's sometimes advertised for cooling but the Minerale fabric was outstanding for any weather. I've never worn anything that wicked perspiration better or was more comfortable in hot and muggy or cold and damp weather. I even wear it under dress shirts in summer to reduce sweat printing through. It was more of a woven or knit yarn type fabric, snug yet stretchy.
The current PI baselayers don't compare at all -- I sent 'em back or gave them away. Via email a PI rep said it was too expensive to continue. Don't waste your money on the current Pearl Izumi baselayers.
There are several bicycle apparel companies offering carbon fabric, but check out other winter sports wear makers for hikers, climbers, etc. Pricey but outstanding stuff. Probably will cost $50-$150 unless you can luck into discounts. I got one of the last Pearl Izumi Thermal RX Minerale fabric baselayers in my size for around $30 in 2015 or 2016. Wish I'd bought a couple more.
canklecat is offline
Old 08-19-19, 06:19 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
@voyager1, I am next door in North Georgia and ride throughout the winter in temperatures as low as 20°F. I will be training for Southern Cross through this winter.
I looked at your list. Most of it looks good but for truly cold temperatures, if you plan to ride when it is below freezing then windblock garments will be needed.
Have a look at the Castelli Alpha ROS jersey and Alpha ROS jacket. The jersey version is the most versatile piece of cold weather gear I own.
Also look at the Castelli Sorpasso Wind bib tights.
Swany X-Change gauntlet style gloves will serve you well and have a zippered pocket for chemical hand warmers. These are bulky but your hands absolutely will not get cold.
The one thing I recommend above all else is a neck gaiter.
-Tim-
TimothyH is offline
Old 08-19-19, 08:57 AM
Abe_Froman
Abe_Froman's Avatar
Bikes: Marin Four Corners, 1960's Schwinn Racer in middle of restoration, mid 70s Motobecane Grand Touring, various other heaps.
Quoted: 9347 Post(s)
Liked 57 Times in 51 Posts
We've still got people in shorts at those temps here
Not me though. Wool long johns, wool t shirt, long sleeve thermal shirt, long sleeve jersey, balaclava, gloves.
Abe_Froman is offline
Old 08-19-19, 11:17 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
https://www.summitpost.org/little-annapurna/151427
Seattle Forrest is offline
Old 08-19-19, 11:34 AM
dmanthree
dmanthree's Avatar
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times in 191 Posts
At those temps I wear Zwift.
dmanthree is offline
Likes For dmanthree:
Old 08-19-19, 03:08 PM
JCNeumann
Liked 7 Times in 3 Posts
I'd investigate winter cycle boots. 45NRTH makes great ones, and have worked very well for me down to 10-15F.
These have SPD clips, and attachment makes a difference in crap weather
JCNeumann is offline
Likes For JCNeumann:
Old 08-20-19, 03:10 AM
rivers
Quoted: 96 Post(s)
Liked 137 Times in 79 Posts
Wool socks, shoe covers. In the winter, I wear a pair of thermal bibs, underamour type baselayer, jersey, merino wool top if its really cold, and a jacket. A pair of grip grab winter gloves as well, Pretty good down to about -5C
rivers is offline
Old 08-20-19, 04:08 AM
Stormsedge
Stormsedge's Avatar
Bikes: 2017 Trek Domane SL6 Disc, 1990 Schwinn Crosscut Frankenroadbike, 2015 KHS Team 29 FS, 2000 Gary Fisher Tassajara--gone but not forgotten
Quoted: 155 Post(s)
Liked 49 Times in 30 Posts
I like your list...I have a fleece jersey I wear with or without a windbreaker, and like wool socks. I had a (and am looking for another) set of tights that had windproof fronts...really nice, but finally self-destructed after twentyish years. Some shoes are not really suited for cold weather (or wet weather) work.
Stormsedge is offline
Old 08-20-19, 08:25 AM
jfranci3
Quoted: 120 Post(s)
Liked 44 Times in 38 Posts
A vest is useless unless it can breathe out the back and can be packed down to the size of a 12oz can and put into your back pocket. I'd spend money on a nicer jacket rather than a vest. A breathable thermal long sleeve is always a better choice than a heavier vest. In my experience, you'll either have arm warmer + jersey days or jacket days, but rarely a 3 stage arm, vest, short sleeve jersey day. The light vest is a just-in-case item.
Gloves- Gore Windstopper non-insulated have the best high-low temp range I've found (like 70-48deg). You can put a liner glove inside for colder.
jfranci3 is offline
Old 08-20-19, 03:42 PM
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 768 Post(s)
Liked 984 Times in 508 Posts
Merino wool is your friend. RedRam and Smartwool are a few of my favorite brands. Use it as a base layer, head to toes. Then perhaps add a mid layer on your torso, and top it off with something waterproof and/or wind blocking as needed.
I use this system, and my body doesn't get cold when I ride, even below 30 degrees F. My toes, fingers, and nose sometimes freeze, but these can be addressed with some specialized gear. Torso, arms, and legs are never a concern. Merino is perfect for active outdoor performance because it is insulating, wicking (so you won't get too sweaty), and naturally odor-resistant. It's also very thin and light, and it won't make you itch.
Broctoon is offline
Old 08-20-19, 06:40 PM
voyager1
voyager1's Avatar
Quoted: 81 Post(s)
Sounds good.
voyager1 is offline
Old 08-21-19, 10:08 AM
rower2cyclist
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times in 35 Posts
I absolutely love Castelli head thingy. Toe thingy is also another fav all the way down to 40F. I still like to wear them under my booties when temps go down below 40. Still haven't found warm booties? Got a pair of Raphas but they are not very snug. Guess you need to pair them with leg warmers which I don't really like.
My wife got me this Castelli Wind Jacket way back as a xmas gift but seems like they don't sell them anymore (is there a smiliar model now?). It's really one of the best clothing I have. I just wear different base layers depending on the temperature with my neck thingy. I also have a similar Rapha Jacket that has become my go-to jacket when I'm not wearing the Castelli. Rapha thermal bibs are also pretty warm and comfortable. For whatever reason they fit me better than their regular bib shorts.
I like Pearl Izumi thermal arm warmers and 3/4 leg warmers. They fit me well and they stay in place no matter how long I ride. PI Transfer wool thermal base layer (both LS and SS) is superb. I also love their Elite thermal wool socks. Hope this helps!
rower2cyclist is offline
avole
Winter Cycling
25
01-03-19 12:00 AM
rachel120
Winter Cycling
35
11-04-17 05:50 AM
just dank
Road Cycling
33
09-25-13 04:05 PM
Coby
Road Cycling
20
11-18-11 04:03 PM
scott kursk
9
08-29-10 12:52 PM
