Abiding hatred for bicycle derailleur drive trains
Quoted: 7 Post(s)
Liked 5 Times
Derailleur drive trains are putrid piles of pus. They are promulgated by the industry for two reasons: 1. To make your cycling life at some point in the not too distant future dysfunctional, filthy with grease, out of adjustment, worn out and miserable which then sends you to number 2. A bicycle shop or mail order house for new freewheels, chainwheels, cables and housings, and chain. My hatred for this lousy dirty exposed to the elements high maintenance system goes back to the 70's when I first got into bike racing. I've been stuck dealing with this crap system ever since.
I've wanted a drive shaft system with an infinitely variable ratio from say 20inches to 110 inches, with the only adjustment knob on your handlebars being selector of pedal rpms you want to maintain which the infinite ratio adjuster adjusts so that your pedal rpms stay within that general ballpark setting. There would be no visible parts with all the drive train hidden behind protective shrouding in an oil bath.
Ahh! just think about it - no maintenance, you just grab your bike and go, no more roadside filthy greasy hands anymore when the chain pops off, no more cable adjustment of new or stiff cables, no more derailleur screws to finagle with etc.etc.
I've wanted this for the last 4 decades. We could put a man on the moon with the computing power of a modern smart phone but we can't come up with my desired drive train. Why? Because the industry is not willing to put in the R&D to design and tool this because they know they will be shooting themselves in the financial foot. They don't want a bunch of happy cyclists simply doing what they want to do which is just go for a ride and not have to deal with the grief and expense of the derailleur system.
Imagine my excitement about the new Pinion 12 speed 637% gearbox and totally greaseless Gates Carbon Belt Drive. It's not my dream system but it's a huge leap forward. I recently purchased the Priority 600 and am setting it up now. I live on a dirt road and am pretty excited about it.
On my other old primary bike the derailleur drive train is worn out now and slipping under torque when hauling groceries. I'm thinking the next best thing is to have a Nexus multispeed hub on the rear with the perfect chain alignment that a single rear cog gives you, along with no god awful rear derailleur.
They don't call'em derailleurs for nothing - they derail your cycling happiness when they irritate your cycling life.
Likes For Old ABLA Member:
Quoted: 3231 Post(s)
Liked 2,079 Times
I’m sure it makes sense for you. Pinion easily adds a pound or more to the bike. I have had no F or R derailer issues in 30 years and other than chain, cassette, the occasional chainring and cables needed, the systems work fine. My Di2 system is 2 years old and I’ve never adjusted it.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1236 Post(s)
Liked 318 Times
Shaft drive has been tried and failed, both 20 and 120 years ago. The angle bevel gears just don't work unless they can be really tight, sealed and lubed. NOT possible on a bicycle because of weight and the wheel has to be taken off often.
Variable transmission has been largely a fail with POOR GI range and huge weight and pathetic inefficiency.
Yup, I call them deFaileurs too. Fine for weight weenies but load them up and the lopsided tension spokes start going pling pling. LOL
Rohloff14 with disc for the WIN for me. Dirty chain and all.
Quoted: 451 Post(s)
Liked 364 Times
I am totally all for technological advancements when they add value, but just in my cycling life, my derailleurs have been pretty silent partners. I'm no kind of racer or bicycle guru, but I have ridden quite a bit. I am about to buy a bike with electronic shifting, but for me, other than that, the biggest technological advancement I personally would like to see is a road tire that is virtually entirely puncture resistant but still has awesome rolling resistance. I would be in heaven. I didn't say it could be done or that I even thought it could be done. And even if it could be done, it might put some tire makers out of business, so the company that developed it might just put it in a corner on a shelf--forever. But it is a dream.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I've often wondered if the derailleur wasn't an accidental discovery. It is, after all, a broken chain drive. It's a kluge, and people have been refining it for over a century (I think). And I'm not a fan of them either.
Still, it has a lot of advantages (mostly low cost and light weight), and even 20 years ago, when I last rode derailleur bikes, they (usually) performed very well (I learned to equip them with Third Eye Chainwatchers.).
Sadly, I don't see internal-gear drives ever competing with derailleurs in cost or weight, both of which limit market appeal and thereby cancel economy-of-scale advantages.
To me, shaft drives are a non-starter. Chains just work, and if you don't like the grease, put a chain guard on the bike.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
II find rear derailleur drivetrains brilliantly simple, work nearly flawlessly, easy to adjust, light, and efficient.
Road, gravel, MTB, commuting... they just work. Like someone else said, a silent partner.
I gather you do not share my thoughts on the matter
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,589 Times
Amateur Bicycle League of America
Quoted: 1581 Post(s)
Liked 1,189 Times
They all work, flawlessly, and have done so over the years that I have had them. Light, efficient, and requiring only a modicum of maintenance: wipe off/lube the chains; change the chain when worn; change the cassette when worn; change the chainring(s) when worn, and keep the cables (inner and outer) in decent condition.
I'm sure that at some point someone will develop an internal gearbox system that is as light, reliable, and efficient as a derailleur system. If and when that day comes, I'll welcome it, but until then I'm perfectly happy with what works and has done so for decades.
Pennylane Splitter
Bikes: Yes
Quoted: 1789 Post(s)
Liked 1,439 Times
And continuously variable shifting? Ask mechanics about the CVTs on newer automobiles - still a lot of problems with them creating maintenance issues and short lifespans. No thank you. .
Likes For skidder:
Registered User
Quoted: 188 Post(s)
Liked 276 Times
Somebody didn't read Park Tool and Sheldon Brown.
I've maintained my bikes for 20 years and the derailleurs are rarely a problem.
I guess some people just don't understand rocket science! I have adjusted derailleurs on during several road side repairs for strangers. Once I show them the basics, they see it's not a big deal. Pretty easy. Keep em clean, not much hassle.
Likes For TheDudeIsHere:
Quoted: 604 Post(s)
Liked 1,063 Times
Either you have mechanical aptitude or you don’t. Someone clearly doesn’t!
Tim
Tim
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
This is good bikeforums.
You know what I hate? Round tires. We can put a man on the moon (50 years ago) so why can't we get dodecahedron tires?
It's all a conspiracy by Big Circle, I'm telling you.
Likes For ksryder:
Expired Member
Quoted: 3660 Post(s)
Liked 5,407 Times
I guess I was able to figure out derailleurs w/o too much drama and haven't had OP's issues. However, that Priority is an interesting bike and I look forward to a report when OP has some miles on it.
Between the Rohloff Speedhub, Nuvinci CVT, and Pinion gearboxes (combined with belt drive), you have plenty of much cleaner, more self-contained options at your disposal.
Mass-market bicycle design is more focused on light weight, speed, and efficiency, not necessarily convenience and longevity of wear components.
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
That’s not really all that impressive for range. A “normal” 44/34/22 11-34 derailer drivetrain has a 618% range. A bit of file work and a change to a 20 tooth inner and a 36 tooth cassette extends that to 720%. My touring bike uses a 48/34/20 crank and an 11-36 cassette for a whopping 785% range.
And both do that for about 1200 grams less.
Or don’t use grease...or more specifically, oil... on the chain. I haven’t used oil on my chains in more then 25 years. I don’t deal with dirty drivetrains because my drivetrains don’t get dirty.
Stuart Black
Stuart Black
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Likes For dedhed:
Lopsided biped
Quoted: 316 Post(s)
Liked 160 Times
Cycleway town
I'm not a fan of derailleurs, but it's the only way to get the range I like.
I'm struggling with the tandem. The extra long gear cable and 10 speeds have proven impossible to get right. I have no choice because I use a rear hub motor, but I'll go back to the more forgiving 8-speed on the next full rebuild.
Derailleurs are a simple but crude way of shifting gears. Bend the chain until it has to go to the other sprocket. They work pretty well in nice weather with friction shifters and 5 or less sprockets on the rear. They make sense in niche applications like racing and mountain biking where weight is believed to be a factor.
For normal everyday riding, commuting etc. IGHs are more suitable. But only Rohloff and SA-AW.
Quoted: 18409 Post(s)
Liked 15,520 Times
Winter has come early to the northern hemisphere.
Likes For indyfabz:
Quoted: 1364 Post(s)
Liked 1,677 Times
https://www.evelo.com/evelo-differen...-transmission/
Continuously variable, automatic bicycle transmissions are already on the street.
Likes For BobbyG:
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
Old ALBA, thank you for the entertaining rant. Turned out being a good read for me this morning.
I too want to hear how your Priority Pinion 600 works for you now and over time.
Likes For FiftySix:
Advanced Slacker
Liked 2,537 Times
I wonder if there is a correlation between those insisting that derailleur shifting is garbage and those insisting they don’t need a hangar alignment gauge.
Likes For Kapusta:
Quoted: 97 Post(s)
Liked 106 Times
It's too bad you have such a problem with maintenance and your first post at that! Bummer. I enjoy maintaining the gear train on my vintage bicycles. I still ride the ones I raced. I do maintenance often enough that nothing ever, or hardly ever, needs replacing and they aren't that grimey. They are so clean, shiney and quiet! This gives more incentive to ride, too! It gives me a chance to use my Campagnolo tools of which I have almost every one. If I could only find a nice Campagnolo wooden chest for them all.
