BB cross threaded
Bikes: Gravel, MTB , aero
BB cross threaded
Hi
Does anyone have any tips on how to rethread the BB?
I've had the frame resprayed and the thread is now clogged with paint, i've managed to get the right side in but am struggling getting a straight start to the thread on the left (none drive side).
The frame is aluminum .
Any ideas out there?
Quoted: 18373 Post(s)
Liked 4,508 Times
Paint or powdercoat?
Many older bike shops should have thread taps, and chasing the threads should be relatively easy if there is enough to catch the original threads.
You can also "face" the bottom bracket which will clean any paint off of the outside edges, and get yourself a nice square face to work with.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Clifford has the best choice. If you're strapped for cash, try a brass brush rotated along the threads to expose more of them, then chase with a well lubricated cup a few times.
Use a power drill + wire brush wheel of appropriate size inserted directly into BB shell. If your drill is even moderately powerful, the paint will come off.
Likes For Reynolds:
Liked 4,508 Times
Really Old Senior Member
Likes For Bill Kapaun:
The dropped
Liked 1,014 Times
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Are you first turning it in the wrong direction and feeling for it to "drop" and align? I realize with the fine threads of a BB feeling the drop isn't like coarse threads.
Liked 4,508 Times
For standard English/ISO threading, pedals are right/right, left/left
Bottom brackets are just the opposite.
Right hand side, left threads.
Left hand side, right threads.
So, if the OP has already gotten the right hand side in, then that shouldn't be an issue. But, it is always worth considering.
Friendship is Magic
Bikes: old ones
Quoted: 26411 Post(s)
Liked 10,377 Times
...find someone with a set of piloted taps. Takes 5 minutes with the right tool, and the repair costs if you genuinely cross thread it the entire length of one side will far exceed whatever someone charges you to do it. We have a set of piloted taps at the bike co-op here, (both English and Italian). See if there's a similar bicycle co-op near you. If you already have one side working well, the pilot shaft will make short work of getting the other side started properly.
Quoted: 2338 Post(s)
Liked 2,822 Times
Quoted: 1303 Post(s)
Liked 1,910 Times
Triple alarmer,
Those taps aren't cheap! the last set I bought were $160, so any bike shop doing thread chasing is gonna want some compensation for the tools and the job.
But the best way to do a thread cleaning is with the piloted threading tools. I have a number of vintage bikes that were sent out for recovering with powder coatings and the best option was to use the piloted taps for cleaning the threads after the painting. My advice to anyone with this problem is to look to a professional for help. The cost are just too high for the home mechanic. Smiles, MH
Friendship is Magic
Bikes: old ones
Liked 10,377 Times
...I bought some Cyclus ones through an online Dutch website about 8-10 years ago (for about 100 bucks a set, with the handles) when I got tired of always dragging my projects over to the co-op. In my case, they've more than paid for themselves, but I have a lot of projects.
I see they're up to 118 bucks American now. But unless you have some other stuff to order at the same time, the shipping costs are another 30 bucks. Nonetheless, they seem to be pretty solid tools based on my experience with them. I wish I could get a set of French threaded ones somewhere, instead of using my trusty single tapered tap in that size, one side very carefully at a time.
Quoted: 1062 Post(s)
Liked 665 Times
Sometimes, if just one or two threads are dinged up, you can use a hand tap of the same pitch but a smaller diameter, as a scraper to clean internal threads. An old machinist taught me that.
Quoted: 4806 Post(s)
Liked 3,928 Times
If these are English taps and they cannot be saved and you want to keep this frame there is always the Italian thread option. Italian BBs are enough bigger that any English, French or Swiss BB shell threads at any state of disrepair can be drilled and tapped to Italian and basically be like new. (But care for them. There is no place to go if you mess them up.) You will have to find the shop that has the taps and they will want real money to do this.
I've never had to do this but have known of this for the past 40 somethng years.
Ben
Ben
Likes For 79pmooney:
Quoted: 501 Post(s)
Liked 626 Times
And yes, it takes longer to take the tool out of the case, clean it, and put it away that the job itself, but hey, the only tool I like more than taps (grinder doesn't count) is my Abbey HAG.
Quoted: 101 Post(s)
Liked 49 Times
On a recent build my favorite shop gave the new-to-me frame a full inspection and did a needed "chase and face" on the BB shell for $35.
I cannot tell you how much better a build goes together with this sort of treatment. I used to just work with what I got and then after a couple of builds with properly serviced Headtubes and Bottom Brackets and aligned Drop-Outs, etc. I am not going to skip this stuff again.
I am cheap, would rather DIY whenever I can, but ...
Really, it's worth it.
Likes For hokiefyd:
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
OP: Is it cross-threaded or just clogged with paint?
Some in this forum default to the most destructive methods first and forget that taps only remove metal, not "restore" it. Using a tap should follow after some other (nondestructive) methods have been tried, and only when proven necessary. Also as mentioned above, even brass wire brushing will damage aluminum threads if not done gently. Excessive brushing work-hardens and distorts the surface making subsequent remediation much more difficult.
Hi People
Thanks for all the advice , I didn't want to take it to the shop nor buy a special tool that I would only use once in a blue moon, as I wanted to see if I could do this myself. So this is what I eventually ended up doing.
Faced the edge with a packing knife blade, this made it easier for me to see what I was up against.
I then used the packing knife in the grooves of the thread, I was surprised how easy this was to get out a lot of the paint.
Eventually I used the "RJ guys" method (thanks hokiefyd) of using an old square type bottom bracket to re-cut the rest of the threads . Did this on both sides and now I can screw the new bottom bracket all the way in and out with my fingers.
Thanks to everyone for all the suggestions, really appreciated
