Please suggest a durable hobby grade chain tool
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I replace 6 to 10 chains a year. I use Shimano or Sram chains for 8, 9 or 10 speed bikes.
Please suggest a reliable chain tool for a user with moderate requirements.
Quoted: 454 Post(s)
Liked 104 Times
Park mini chain brute Park Tool Co. » CT-5 : Mini Chain Brute Chain Tool : Chain
Quoted: 2952 Post(s)
Liked 3,106 Times
That's the one I use. Well made and does what it does.
Really Old Senior Member
Just get a good chain tool and not have to worry about the cheap one failing when you really need it.
My first cheapie lasted 2 uses, but I learned what not to do.
Second one lasted about 3 years, but I really had to baby it for the last 2. (push a bit, back off & reset......repeat 3-5 times)
I finally broke down and got a PARK CT-3?
Liked 3,106 Times
The Park CT-3 is the one I use in the shop .
Liked 6 Times
I have both the Park CT-3 and the CT-5. The CT-5 is now a carry-along. I recommend either one as a home tool. I use to have a Topeak Chainbot, but it just broke on me one day, so I bought the CT-5 for home use.
Quoted: 910 Post(s)
Liked 288 Times
I've been using the the tiny folding tool in my Topeak travel tool-kit for four or more years. I feel like I can get more than 3 years from any Park tool, Mini or not.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Quoted: 2604 Post(s)
Liked 1,934 Times
It's the one I prefer to use in the garage shop. I got it when I had to use a channel-lock to hold the CT-5 so I could turn the handle with a pair of pliers on a new Shimano chain. (CT-5 had worked all right for SRAMs, but the CT-3 is a whole lot easier with either.)
However, these days I usually just use it to break chains if they need it. I use a quick link to put them back together.
Old. Slow. Happy.
Quoted: 5 Post(s)
I have a Cyclo that's been in service for 30+ years. Only replaced it (with another Cyclo) is because I needed one that was compatible with narrower chains.
Bikes: Trek Domane 5.2, Ridley Xfire, Giant Propel, KHS AeroComp
Quoted: 1648 Post(s)
none of the chain tools are really expensive...pick one and go for it.
Constant tinkerer
If you're doing even a couple chains per year just get the CT-3. Spending money on good tools that you will use is always worth it.
now derailleur chains are shorten only. so the pushing your pin out to make it short enough is really not that fussy.
Bikes: 89 Schwinn 754, 90 Trek 1100, 93 Trek 2300, 94 Trek 1400 (under construction), 94 Trek 930, 97 Trek 1400
Quoted: 29 Post(s)
I gave up on the smaller compact chain tools last year after having used them for over 40 years, the way that chains have progressed makes a larger/stronger chain tool a necessity .
Over the years I've broken a cyclo, then a cyclo designed for Shimano SIS chains, then a ELDI, and then bent a Park compact CT-5 (that lasted about 10-15 years). Now I'm using a larger Park CT3 and it's much easier to break the newer style chains. With the short handle (that utimately bent on the CT-5 (and the frame bent), the CT5 was getting to hard to break KMC chains with the flared or mushroomed pins/rivets. Breaking a modern KMC chain involves physically breaking the flared head of the chain pin off the pin, and leaves a ring of broken off metal on the chain tool's pin.
The compact tools work/ed fine/easily with older 5-speed type chains with straight pins. They can work with effort on Shimano chains that use oversized pins to lock the pins inplace. From my experience, compact tools are not designed for use with modern chains that feature pons that don't stick through very far, and/or are flared or mushroomed to lock to the sideplates of the chain.
Performance Bicycle (and I think Nashbar) offer a lifetime warranty. I suggest that everybody buying tools that might get broken would be better off buying them where you can get a warranty that will replace the tool, or allow you to trade up in the case that you decide to upgrade.
Parktools also offer a "lifetime warranty" on their tools . Just sent them a email and they take care of you .
Bikes: Rockhopper, Azor Oma cruiser
Is there any reason for not mentioning the Park CT-4.3 chain tool??
Bikes: 87 Raleigh 531C Team Replica, 96 Litespeed Classic, 01 Lemond Tete-De-Course, 99 Mongoose RX10.9, 03 Lemond Wayzata, 00 Litespeed Appalachian, 99 Bianchi XL Boron, 98 Litespeed Tuscany
Quoted: 35 Post(s)
Liked 53 Times
I've been using the same old Cyclo tool for the last 30+ years, but then my newest bike is from 1996.
AddictedToMusic
Bicycle Mechanics
3
04-07-12 07:54 AM
whitekimchee
Singlespeed & Fixed Gear
11
08-23-10 02:45 PM
