Cold temps. Whats your breaking point?
Bikes: 2015 Cannondale Caad8 105 '92 Specialized HardRock,
Quoted: 7 Post(s)
I look outside. Its beautiful and sunny. For some reason i still equate sunny with warm. I would say my breaking point is 0- C. Hills, check. Wind, check. Cold, not so much. Whats your deal breaker?
aka Phil Jungels
It's April - you should no longer concern yourself with cold!
Depends on the conditions (wind/road) but I've ridden down to 25F (-4C). You just need to wear warm clothing. Much below that ice on the roads starts being an issue, and I'm not going to spend a huge amount of money on studded tires.
Non omnino gravis
SoCal checking in to say 40º. We only get a few dozen days where the nighttime low is any colder than that anyway... so I'm basically unequipped to handle those temperatures. I have gloves etc. good to about 40º. To be completely honest, we had a "cold" day this Wednesday where it didn't get above 60º, and I stayed in. Mostly because it was 75º the day before, 74º the day after, and will be 88º by Tuesday. My body is already used to warm. I can't just switch back.
I'm looking forward to the companion thread to this one, only about hot temps. SoCal pre-checking in to say I guess I don't have one. Finished a ride last July and when I got home it was 114º. At 11am.
Proud hobo biker
Bikes: 2019 Surly Ogre, 2016 Giant Anyroad 2, Lightspeed Roadrunner trike, SE Tripel (in process)
Quoted: 202 Post(s)
I hate 40 degrees but as long as it's not too windy and wet, I'm OK. Below that and this Texas boy stays home.
As for high temps, I haven't dealt with 114 yet but it's routinely above 100 for my rides home during the summer.
The Fat Guy In The Back
Bikes: '81 Panasonic Sport, '02 Giant Boulder SE, '08 Felt S32, '10 Diamondback Insight RS, '10 Windsor Clockwork, '15 Kestrel Evoke 3.0, '19 Salsa Mukluk
Quoted: 320 Post(s)
Liked 177 Times
I don't really have a limit in either direction, hot or cold. I've ridden down to -14F, and up to 105F with no ill effects (thankfully not on the same day!) My wife gets nervous if I'm riding in sub-zero temps so anymore I usually drive the car to work much below -5F. Then I have to put up with all the, "you drove your car today?" comments.
Since my most recent 50 pound weight loss I do notice I get cold a lot faster, especially on days when I'm eating light. It's not when I'm riding though, just when I'm sitting around the house or the office. Once I'm out on the bike I heat up just fine.
Visit me at the Tundra Man Workshop
Quoted: 2604 Post(s)
Liked 1,933 Times
Check the Winter forum for some opinions that'll blow your mind!
I've worked my way down to below 10F. With no wind, it's almost pleasant, although you have to balance "ride fast to generate body heat" with "ride slow so the wind doesn't freeze you."
It's all about the windchill and if my gear can block the wind. Otherwise I have enough winter riding gear that I should be good to -10°F. At 40°F I have a super light jacket that I tend to sweat through with non-insulated cycling tights on and a short sleeve underneath and fingerless gloves. And that is after work without sunlight.
Wind is more of a deal breaker for me. I live along the coast and gusting cross winds can rise to the point where it is dangerous to ride.
Bikes: Kona Lana'i, Cannondale CAADX Disk
Quoted: 55 Post(s)
Wind is the deal breaker.
I have ridden with temps around -5° C before, but sunny and almost no wind, I was fine. It only happens on very rare occasions during the winter in my area.
Just Keep Pedaling
Bikes: 99 Schwinn Mesa GS MTB, 15 Trek Domane 5.9 Dura-Ace, 17 Trek Emonda SL6 Pro & 18 Bianchi Vigorelli
Quoted: 251 Post(s)
Liked 67 Times
I started once at 38 degrees so I guess that is my limit
Quoted: 7 Post(s)
aka Phil Jungels
Yep, but that 50MPH wind today made the last mile toward home tough! Wind was worse than the 36 degree temp, that's for sure. I was really wishing I was skinny!
Quoted: 27 Post(s)
I have a dedicated winter studded bike and
I actually watch for record cold days and make sure I get out.
Heated insoles solved my last cold problem,
-4F last year and -5F this year !
I'm at 199# right now so that may not count in this forum
What keeps me inside on the air-dyne is hard rain.
I still need to learn to gear up for that,
Bikes: s-1
Quoted: 221 Post(s)
over the winter I rode a few days without regard to temp because I just wanted to say I did it. it sucked lol.
I only have mid weight cycling gear so wind/rain dependent I cut it off around 45F, 35 if it's super sunny and calm for short rides.
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
I took all winter off and concentrated on XC skiing, and now that is over I can get back to riding... except it has been between 0 and -12C for the past week. If I wear warm boots on flat pedals, I can stay out for a couple hours, but I was determined to start riding in earnest, so I wore my Sidi shoes and clipless pedals, and my toes are hurting after ~15 km. Unfortunately, yesterday 15 km was my turnaround point, so buy the time I got home my toes were numb and white.
Quoted: 5888 Post(s)
Liked 3,472 Times
On cold days, it's all about dressing right. I have yet to see a day that is too cold to ride in IA.
Bikes: Trek Domane AL2, Pedego Stretch
I ride all through the winter. I'll ride down to the single digits (F), and during the winter anything above 20 feels good.
Now that it's April, though, I all of a sudden balk at 40 F. Funny how that works, isn't it?
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times
I used some gloves that are sold for people who work in Deep Freezers/fridges and that are good for -25 degrees C, and I dress warm with a skull cap, scarf, t-shirt, jersey and waterproof jacket etc, but when it's -5 degrees C or colder, and it's windy and raining at the same time it's very unpleasant then I use the car or train or bus
LET'S ROLL
It rarely gets to below 0F/-17C here in the New York City area. I'm
ok at that temp; it's the snow and ice that's a problem at times.
5 Fahrenheit/-15 Celsius by 1nterceptor, on Flickr
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 26 Post(s)
32 degrees is the limit. Rarely get that in No CA thank goodness.
Funny thing happens when it gets that cold. Usually the hot water goes out at work so no hot shower at the end of a chilly morning commute to work. That's the deal breaker. Takes a long time and many cups of coffee to get warmed back up on those days.
Bikes: 3 good used ones
Quoted: 83 Post(s)
Typically, in the fall and early winter, I'll ride no matter how cold it is, but I quit once the snow sticks to the ground. In spring, I try to start riding again once the snow is gone for good, but I also tend to wait until temps reach mid to high twenties. Some years I stop early though and do more hiking instead. Last year I quit riding in November even though we never really had any snow. It just depends.
