Order of operations - ???
Quoted: 198 Post(s)
Liked 52 Times
I took apart a bike and painted the frame. now I want to re-assemble but am not sure of the sequence.
so far:
forks on/ stem & handlebars / seatpost on
front & rear derailleurs on
new tires & tube installed/ wheels trued - Thanks Jim Walsh @ Stedman's - wheels on frame
bottom bracket/ cranks/ pedals on
brakes on
left to go: saddle/ brake cables/ shift cables/ racks/ fenders/ brake hoods/ wrap bars
everything on is snug but not socked down tight
what's next?
thanks
so far:
brakes on
what's next?
thanks
Quoted: 4211 Post(s)
Liked 3,881 Times
I start with the direct to complete frame and contact points. The fork, crank and seat. The move onto brakes then gear and end up with accessories like racks and fenders. As long as you end up with what you like does it really matter? Until your pay depends on your efficiency just enjoy the build up. Andy
AndrewRStewart
AndrewRStewart
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
Andy's right (it doesn't really matter), but for posterity this is my order:
wheels/tires/cassette
fork/headset
bottom bracket
cranks
brakes
stem/handlebars
derailleurs
brifters
cable up
handlebar tape
seatpost
saddle
pedals
tweaks
fork/headset
bottom bracket
cranks
brakes
stem/handlebars
derailleurs
brifters
cable up
handlebar tape
seatpost
saddle
pedals
tweaks
Liked 3,881 Times
I sound drunk in my first post-spacing away some of the meat of my reply
The reason I start with the rider's connections is that so much else of the set up has to work around stem length/height, front chainline, and the biggie as a rider the saddle location over the feet. It's part of the core stuff first then outer stuff second method. Andy
AndrewRStewart
AndrewRStewart
Quoted: 18381 Post(s)
Liked 4,512 Times
Fenders often connect to the brakes. So, they may go on before the brakes, depending on the actual method of connection.
How is the rack mounted? It might just get in the way, or it might also connect to the brakes, or otherwise be an earlier step. Would it affect how you route the cables? It may also share the lower mount points with the fenders (mount the rack to the inside, and fenders to the outside, I think). So, perhaps mount rack, then fenders.
Bar wrap is the last thing to do, and I often ride the bike a couple of times before wrapping the bars.
Likes For CliffordK:
Quoted: 4806 Post(s)
Liked 3,932 Times
The rest of the stuff - usually I have most of the gear and not one or two important parts on hand. So order is dictated by what I have. It all works.
Ben
Likes For 79pmooney:
Quoted: 198 Post(s)
Liked 52 Times
in any event, everything fit before, so it must fit again!
thanks for the encouragement.
Bikes: 2012 Surly Ogre, 2008 Fisher Wahoo
Quoted: 7 Post(s)
I agree that the order doesn't really matter, but something you said made me thing about this: The one rule I try to never break when putting a bike together is that I never tighten something part way. That is, if it looks like it could be tight, I make sure that it is put on with the right torque and ready to ride. Too often I get called away from my bike projects by something else, and I come back to it days later, having forgotten exactly what I've done. I don't ever want to hop on the bike and start riding, only to remember that I hadn't *quite* tightened the stem up all the way.
Others are probably not as absent-minded as me, but when the OP said that things were snug, but not tight, this is what I thought about.
Quoted: 198 Post(s)
Liked 52 Times
I can't say I've not been bit by that gremlin. when I had the bike in question put together for its test ride, I hadn't tightened the handlebar in the stem. as I applied the brakes, the bar rotated forward in slow motion. a lesson to be made aware, but I am not confident in my abilities yet to do things once and for all.
but I will heed the advice and be mindful as I go through the process.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
And just for yucks, my order is as follows:
headset and fork
bb and crankset
derailleurs
chain
calipers
wheels
stem and handlebars
brake levers
shifters
cabling
seat post and seat, usually after all the fiddling is done.
pedals
Likes For seedsbelize:
Blamester
Liked 3,881 Times
Funny that I do quite the opposite, I purposely leave an assembly loose so I will know where I left off. Regardless of the order of the steps I still will take the few minutes to review my work, component by system, Just like reviewing test answers. Oh wait! work and life is the grand test Andy
AndrewRStewart
AndrewRStewart
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
And tightening things to full torque right away seems less than ideal unless you are forgetful or normally in a rush. There aren't that many nuts and bolts on a bike that you can't go back through them all and double check with a torque wrench (especially if it's your bike and you can take your time). You could also use one of those marking pens to check off the bolts you have torqued (you see that on some new motorcycles, maybe cars too).
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
seatpost, so I can clamp it in a workstand
then
headset
fork
stem
bottom bracket
cranks
handlebars
brakes
shifters
derailleurs
wheels
chain
pedals
most of these are not necessarily in any order, except for bb/cranks, derailleurs, and wheels w/cassette before chain.
then
headset
fork
stem
bottom bracket
cranks
handlebars
brakes
shifters
derailleurs
wheels
chain
pedals
And don't forget, leave everything "race loose", meaning, loose enough so that when you crash, the part will give way, for example, the bars will turn sideways instead of staying rigid, which will lessen the chance of denting the top tube when the bars go all the way over.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Likes For San Rensho:
Quoted: 198 Post(s)
Liked 52 Times
