Mold in Camelbak drinking tube
Bikes: 1. Trek fuel ex 8 GX 2022 ML. | 2. 1995 Green Trek Mountain Track 850. | 3. Avanti Pisca pro-Track bike. | 4. Some 10 year old upgraded BMX
Quoted: 10 Post(s)
Hello fellow riders,
I have noticed a lot of this stuff that looks like mold in my Camelbak drinking tube. I have tried using vinegar, dish soaps and letting it soak but this does not work. Can anyone tell me a solution to getting rid of it?
Thanks
Thanks
Sr Member on Sr bikes
What I do if/when I get mold…take the tube off the bag, and mouth fixture off tube. Straighten out a wire coat hanger (make sure it’s at least as long as the tube). Spray a bleach solution into the tube. Then force a small wad of cotton or cloth through the tube with the wire until the mold is cleaned off. Rinse thoroughly, and reassemble.
To prevent mold in the future…if you’re putting sugary drinks in the bag…make sure everything is rinsed thoroughly after each use. If it’s necessary to keep unused beverage in the bag…keep the bag in the garage fridge between uses.
Dan
Dan
Quoted: 714 Post(s)
Liked 800 Times
I push a ball of wet paper towel through with a length of cable housing. With my latest pack, I decided to stick with plain water to avoid this issue.
In addition to cleaning after use, remember to let thoroughly dry before storage.
Likes For Oakman:
Quoted: 6199 Post(s)
Liked 4,816 Times
Soak for a time in water and Clorox bleach. Or soak in hydrogen peroxide. Or soak in some water and Oxyclean.
Hydrogen Peroxide probably works the best. But bleach is cheaper and always on hand here. I sometimes will have to take the silicone nipples apart on water bottles and soak them good when little bits of mold or mildew start showing. Probably would be better to just regularly soak them before it shows up. But I haven't gotten into that habit.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Tube brush and bleach.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Stuart Black
Stuart Black
Clean somewhat frequently and hydrogen peroxide is a great bleach substitute. If it is too bad already, just buy some new tubing at Hone Depot. that way you also can different lengths.
I used to store them in my freezer after use. That way you prevent any growth. it is nearly impossible to get it 100% sterile after every use.
Liked 4,816 Times
Common household bleach, otherwise known by the brand name of Clorox is good for both a disinfectant and sanitizer. And it's EPA approved and at the proper dilution levels it even tells you on the label that it is safe for dishes and utensils and other things you use with food.
Not certain why the caution not to use bleach. However I will agree that hydrogen peroxide generally works best between the two for mold and mildew. Especially on porous surfaces.
Likes For Iride01:
Quoted: 18424 Post(s)
Liked 15,582 Times
This is why this kit is made.
Likes For indyfabz:
Bikes: lots
Liked 2,932 Times
I would not use bleach. It’s not really meant to be consumed. Soak in hydrogen peroxide with a bit of dishwashing liquid. Then physically remove any remaining bits with a piece of chinelle (pipe cleaner for the less sophisticated) dipped in the same solution. That’s what “pipe cleaners” were designed for. Rinse well.
Likes For cxwrench:
Liked 15,582 Times
Definitely an amateur...
Quoted: 33 Post(s)
Liked 94 Times
I have a CB bladder soaking with a bleach/water solution as we speak (type?).
A capful of bleach in 3L of water...let sit for a day or so, then rinse with warm water. I've been cleaning hydration bladders using that method for @ 20 years with no ill effects to me or the bladders.
Liked 4,222 Times
It is foolish to use the toxic alternative when a nontoxic, or at least less toxic, alternative exists.
Stuart Black
Stuart Black
Liked 4,222 Times
As someone who have worked extensively with chlorine and chlorine containing compounds, I can tell you that is not a material to treat lightly.
Stuart Black
Stuart Black
Likes For cyccommute:
Don't they dunk chickens in bleach to disinfect the meat?
I understand the concern with plastic and bleach, though. Best to avoid any chlorine. Even if you don't touch or ingest it, it's gases attack your lungs.
As for H2O2, I recently bought 12% off Amazon since most what is sold is 3% only. You can see it foam when it hits organic matter. At my workplace the custodians clean the bathrooms with a machine that uses a hydrogen peroxide cleaner. It is much more environmentally friendly and less harsh than what they used before.
Only caution is that it can degrease your skin. Do wear some gloves. But that is true for any cleaner.
Quoted: 365 Post(s)
Liked 419 Times
It's a pain, but I've learned from hard experience (i.e. having to throw away my first Camelback bladder, and a couple of bottles). The combination of sugary drink and any backwash from one's mouth create a perfect environment for bacteria/mold growth. Rinsing/washing/drying bottles and bladders always, and I mean ALWAYS, takes place within half an hour of ride completion - I think of it as part of my "cool-down".
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
As others have suggested a bottle or tube brush works.
Be aware that if you opt to use a bleach solution, go sparingly with the bleach. It can damage the liner of the bag itself and actually lead to further problems with mold and such.
Quoted: 2604 Post(s)
Liked 1,933 Times
If you've got mold in the tube, a combination of bleach solution and tube brush may be needed. I'd think about a quick rinse, followed by scrubbing with the brush, then coil the tube up and soak it in a bleach solution. Rinse with water (three times or until you're bored holding it under the faucet) and dry thoroughly.
To prevent recurrence, as noted previously, use only water in the hydration pack. (Carbs and salts go in a more easily cleaned water bottle.) After each use, I unplug the mouthpiece and bladder plug from the tube and dry it open. You may not need to do this if you're using the hydration pack daily, but my tube is clean and still long enough after several years' use and annual trimming (to deal with stretching over the end pieces).
Reminds me of the middle 1970s when the California legislature considered a bill to outlaw chlorine in any product. IIRC it passed one house before someone pointed out that salt (NaCl) would also be outlawed by that bill. This kind of phobia isn't really called for. "The dose makes the poison" still applies. The soaking can be done outdoors if the bleach odor is offensive, diluting the outgassing hypochlorite to well below the damage threshold.
Liked 15,582 Times
Liked 1,933 Times
Likes For pdlamb:
Quoted: 5224 Post(s)
Liked 3,585 Times
