Drill a Steel frame for Bottle cage mounts?
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Hi all, Can I drill holes in a 35-40 year old steel frame that doesn't have any bottle mounts, or should I just use some kind of clamp-on mount?
Calamari Marionette Ph.D
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
Bottle mounts are not just holes in the frame; they're threaded fittings. What you're thinking of doing won't work.
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
Some steel frames are made with butted tubing, which means the tubing is thicker, in some places, than others. The typical locations for bottle cages are usually where the tubing is very thin, so it won't hold threads very well. Drilling will also reduce the overall strength of the tube, and introduce a location for corrosion to set in. Not much good comes from drilling bicycle frames.
Clamp on might be a better choice, especially if the frame has any value.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
You wouldn't want to simply drill holes and tap/screw into them, but you could drill holes and install rivnuts to receive screws. Whether you should depends, in part, on what kind of bike we're talking about.
And of course, classic clamp-on bottle cages look right at home on older bikes.
Quoted: 1438 Post(s)
Liked 1,092 Times
You could drill the frame and insert RivNuts (threaded Pop Rivets, essentially), but I wouldn't do it myself, there are a lot of different non-invasive ways to mount cages:
https://recklesscognition.wordpress....ws-and-bosses/
Adding Water Bottle Cages to Bicycles without Braze
Quoted: 1815 Post(s)
Liked 1,693 Times
Quoted: 270 Post(s)
Thanks all, just wondering...it's an old Brittany Free Spirit that I brought back to life. Cost me $15. Sounds like a bad idea...
buy a Two Fish Velcro strap on bottle cage https://www.twofish.biz/pdf/StainlessCages.pdf
Then you can change Bikes Under the Bottle cage.
Cheap frame Thick wall Mild steel tubing ?
I could probably make threaded holes.. A center Punch can deform a dent in the Tube wall,
and in making that dent, when the hole is drilled and threaded, will have more threads in it,
than if you just drilled a clean hole and then threaded It.
Making an alignment Jig using a Piece of angle Iron on a drill press is useful in getting the holes On Center.
Service charge will me More than the $15 you paid for the bike at a Yard sale.
Quoted: 252 Post(s)
Cheap low end bikes don't use thin butted tubes. It still might be tricky to get the holes aligned properly.
Some bottle cages have tabs where they mount with screws, most vintage ones or vintage styles ones have it. You can use hose clamps or vintage style bottle cage clamps to attach these cages to a frame. Common in the 60's when braze-ons were not standard.
Friendship is Magic
Bikes: old ones
Quoted: 26388 Post(s)
Liked 10,365 Times
...probably less trouble would be a Nashbar handlebar cage mount. They work pretty well, and it's where bottles rode for many years back in ancient times.
Don't make me sing!
Quoted: 308 Post(s)
Quoted: 270 Post(s)
I've been able to make it look and function nicely now...it hangs on my office wall as a vintage decoration/ emergency transportation when I need it...or don't want to drive somewhere close. I don't consider it junk at all, and would put it against a Wal-Mart cruiser any day. It has a nice lugged frame and the paint is not bad either...Mayne I'll get a pic of it on here soon ( can't do that on the phone)
Quoted: 9 Post(s)
Besides, what a bike is "worth" means fair market value, not what the owner actually spent on it. If somebody gave me a bike worth $15 for free, I'd use hose clamps. If somebody gave me a bike worth $500 for free, I'd use a "proper" vintage cage mount or maybe even have braze-ons added (but realistically speaking, I'd expect a bike worth that much to either have braze-ons already or be a "collector's item" that I should resell instead of ride).
(By the way: it goes without saying that hose clamps on a bike frame should have something tucked under them to protect the paint, such as a bit of disposable latex glove or a piece of old inner tube. Using hose clamps doesn't mean you don't care.)
Quoted: 270 Post(s)
Here we go... Got some pics, unfortunately no "Before" pics.
I bought it for 15 in unusable condition: rusted stiff chain and derrailers, couldn't pedal, lots of rust on components.
I stripped it down to bare frame, repacked bearings in BB, headseat, and wheels, cleaned everything, removed SOME of the rust, not all.
New items are: Tubes, tires, cables, housing, chain. Everything else stayed. I'm actually surprised the derrailers still worked fine once they were cleaned up. It rides and shifts well now. No collectors item, but fun for me.
I just thought it would be more useful with a bottle cage...and though plastic clamp mounts wouldn't fit the vintage look. But metal ones might.
Don't make me sing!
Quoted: 308 Post(s)
Why wouldn't the cost matter? If you're riding a cheap bike, it's because you either can't afford or don't feel that it's necessary to have an expensive one. Why, then, would you suddenly change your mind and go for the expensive solution for accessories? If you wanted to spend extra money, it would have been better to get a bike fancy enough to have braze-ons to start off with.
Friendship is Magic
Bikes: old ones
Liked 10,365 Times
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Quoted: 427 Post(s)
Liked 339 Times
Quoted: 340 Post(s)
Liked 275 Times
I have drilled and tapped an aluminum frame for a bottle mount. The downtube was thick enough to tap. Just an example of owning too many tools. Later, I feared I had potentially weakened the frame, so I posted a query here and was told not to worry. I probably have weakened the frame, but not gonna worry.
