Welding my own frame -- is it crazy?
Quoted: 2236 Post(s)
Liked 1,314 Times
I have finished my build of a touring bike in August using a 1994 Trek 520 frame. So far I've put about 500 miles on it, with shorter (20-50 miles) rides around town. I am restless, and curious about making the same/similar bike with a lighter frame. Would transfer the wheels and saddle, but put a new groupset. It would not be a tourer, but an everyday rider plus randonneur. I like the slender lines of steel frames; in fact I gave my 2021 Trek FX4 Sport Carbon, a very fine bike by any measure, to my wife. She loves it and says it's the highest quality bike she's ever had. But for me it's steel all the way.
I am considering welding up my own frame. By background, I am a medical professional, but I am a garage guy, and hobby welder, and am moderately experienced with TIG welding (and am decent with SilBr brazing) and own a competent AC TIG machine. I can also do basic fabrication, have a shop press, a brake, tube notcher, metal bandsaw, CNC plasma setup (Hypertherm 45XP), fixturing top.
The voice of reason in me says it's crazy and "Don't do it", but wanted to solicit y'allz's opinion.
The plan is to start with a Rene Herse superlight Kaizei tubeset (around $200) plus the BB shell, fork crown and blades, and various smaller add-ons. Would probably need to build a frame-maker fixture out of plywood and 8020. Maybe I should have myself professionally sized/fitted first (although my current Trek 520 fits well).
In the end will paint it this gorgeous Colnago blue.
Would add a 2x groupset, maybe campagnolo with rim brakes (probably centerpull).
Alternative #2 is to buy an old (1980s-1990s) Italian frame off eBay and build that up. My concern is about how wide a tire I can fit. I have a very strong preference for knobby 42-44 mm tires which work best for the style of riding I am doing; certainly nothing thinner than 38mm is of interest).
How hard is it to build a frame from a set like the one above? WHat alternatives are there -- can I buy a frameset from other sources? Any and all advice is greatly appreciated.
1. What's the downside of trying it. A couple of hundred bucks is pretty cheap for a hobby. Worse case - you learn something along the way.
2. If you have a bike that fits very comfortable I don't think I'd bother with a pro fitting. Just replicate that bike with better material. I have an Apollo like that. If I ever wanted a custom build I would take that bike in and tell the builder to replicate it with better material/fittings.
3. When I dream of a custom build it isn't really for the frame itself. as Tourist in Msn said, I fit a lot of off the wall bikes and could probably just find a nice quality frame far cheaper than a custom build. What I would like are certain attachments. Three bottle points, pump pegs, eyelet on the top tube for a gas tank bag and on the forks, horizontal dropouts...
Also integral racks for a rando bag and saddle bag. It's funny we buy bikes and then have to bolt 2- $400 racks on them. Sleek, minimalist welded racks that suit the function of the bike would be a benefit and custom/unique.
Likes For Happy Feet:
Quoted: 3455 Post(s)
Liked 1,454 Times
A couple years ago I saw a gal that had some really nice racks on her bike, asked where she got them. She had them custom made by a local frame builder. Unfortunately I did not have a pen, by the time I got home I could not remember enough to find the contact info on that frame builder.
Welding your own frame is an adventure ! Expect to make mistakes, but it makes you a better builder next time around. Maybe try straight gage cromo tubing or even high ten steel on your first projects. Move to the exotic stuff as you get better. As for jigs, I started out with wood jigs - just make sure to have a fire extinguisher nearby just in case. We visited a local town framebuilder in Italy maybe 30 years ago. All he had were hand tools, gas welder and a bike stand. No jigs. Everything was done by eye and simple hand tools. If you really want to do it, it can be done with some hard work and research. Your enthusiasm and ingenuity can trump the need for expensive tools.
Here's a frame I brazed over a decade ago using straight gage cromo tubing .035 wall thickness. Started out as a road bike but reviving it now to become a touring bike with more upright bars to match the aging rider. Changing it to a 1x drivetrain so this old geezer doesn't get confused as to which side to shift.
Good luck on your frame building adventure.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
I strongly discourage you from the idea of building a frame that would take really long side pull brakes for 42 tires, because of the long arms, they will not be rigid and braking will be really really lousy, that's why no one does it. You really need to think cantilever or disc brakes. (or v- brakes with special brake levers) I know about lousy braking with long reach side pulls from having walking aid scooters made in China
I just got the Proteus book (a 1976 edition) in the mail today and have looked through it. Read the bits about brazing and it was quite helpful.
Yeah this is not a simple call. If I could buy a sleek and light Italian frame with rim brakes and room for 42 mm tires, would do it in a heartbeat. Couldn't find any, alas.
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
Hi,
I just noticed that you are in Phoenix. I did not realize that you were close. I am out in Globe. Would it help to come out and see what you need to build a frame? In the last 8 years, I have been focused on building road bikes (and flat bar road bikes that take wide tires.) I have one one road bike that I built with dual pivot long reach side pull brakes that takes up to 700 x 32 tires. (barely)
Liked 1,454 Times
My Lynskey Backroad frame is disc, not rim brake. That is my first and so far my only disc brake bike. I built it up with a LHT rim brake fork that I already owned. Thus, it is rim brake in front, disc rear. I think the frame will take 45mm tires, but I have fenders on mine, mine is now limited to 37mm tires because of the fenders. I am very happy with that bike.
It however is a touring bike, with touring strength wheels, etc., so even though it has a titanium frame, it is not that light.
Likes For Tourist in MSN:
Likes For headwind15:
Quoted: 1034 Post(s)
Liked 1,289 Times
I will say, given your experience, and equipment, and interest in bicycles, it seems like a natural transition. Learn all you can form others who have done it, and go for it.
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times
I made a set of cone wrenches a couple months ago - just because - I was doing some wheel work and my regular wrenches wouldn't fit so I thought I'd just make some. Used sheet metal for the wrench claws lined with 70k psi tensile filler metal (7014 electrodes) for the faces, ground to fit. They work great.
Next fab project appears to be a trailer for the bike. I am contemplating trying my hand at welding aluminum. I have electrodes, and can get more at my local welding supply. If I could TIG I would, but you can most certainly stick aluminum. It just doesn't work, or look, nearly as good as TIG. We'll see. I am more confident with steel, by a long shot, but it would be a neat project to try aluminum. The same advice I gave earlier is very much true here - weld test pieces and destructive test to prove the process before going hog wild on the assembly only to run in to problems.
Likes For KC8QVO:
Likes For phughes:
Wait!
Horizontal, and opposing, hmm, is that a boxer? Per chance a Porsche rebuild?!
Liked 1,454 Times
I am guessing a BMW.
Liked 1,289 Times
Likes For phughes:
Built my first frame in 2001. Have built 5 frames in total now, but no forks. This winter will be my first fork. Have zero experience with TIG, but had sweated copper once and learned brazing back in the 70's, but never did it after learning it. Jumped in using lugs and no jig, just pegged the joints together and cold set alignment where needed. Still use that first frame as a daily rider. No videos, only books on brazing. It went very well and have only replaced the drive side drop out after 20k miles. Figure it overheated during the build. Have close to 40k on that frame now.
Originally built it because stock frames simply didn't do it for me fit wise, and didn't give me bragging rights (lol, I ride alone 99% of the time). It isn't hard to do, and gives you complete control over the creative process and you can make it any way you want it. Braze-ons where you want them, details that are unique to your frame and will not be found anywhere else. JUST DO IT
Likes For TiHabanero:
Tappet
ha, makes me think of that radio show ,, Car Talk, with the "tappet brothers", Boston guys I think.
would occasionally hear it on npr here in Montreal, couple of wacky characters that made for fun, often sarcastic humour listening.
seems to me one of them died a bunch of years ago
but wait, we can't admit to being petrolheads here can we? Naw, we can be both. I've always been.
Likes For djb:
Liked 1,289 Times
Tappet
The brothers were Ray and ... Magliozzi (sp?) . Loved that show.
Likes For koenbro:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 809 Times
Tappet
Tom and Ray..from Cambridge, MA ("..our fair city..")
Tommy came down with Alzheimer's and continued to do the show..while both acknowledging that things were slipping away. Great show..listened to them for years. I miss it.
Likes For fishboat:
The goofy banter and wacky offshoots of topic were often hilarious.. mixed in with actual good car advice sometimes.
like I said, I heard it infrequently, but have good memories of their silly chemistry.
Quoted: 759 Post(s)
Liked 809 Times
If memory serves..I think they both had engineering degrees from MIT. Though they'd never admit it, they knew their stuff and had a great track record of correctly diagnosing issues people had with they vehicles.
I tried to find it, but didn't come across a source to hear one of my fav shows:
#1452 : Max and the Schnauzer
Apparently there's still some shows available:
https://www.npr.org/podcasts/510208/car-talk
I drive regularly to another city for family and always organize podcasts to listen to, so this will be a larf to hear them again.
Thanks a bunch
Liked 1,289 Times
