why drop stand so rare?
In China there are lots of drop stand on single speed bikes. i also ocassionally see old deraileur bikes with drop stand. I am trying to find a drop stand that will work with a cheap 6 speed derailler bike. but LBS say new bikes dont come with those drop stand no more.
i have a single speed city bike with dropstand. it is super stable. especially when u have a bigbasket hauling things. yeah they r heavy, not good for endurance touring...but great for city bikes. They are attached to axle...there super strong.
they look like great product. i scoured China online sources but cannot find anyone making/selling them.
Likes For HTupolev:
Thread Killer
Quoted: 3136 Post(s)
Liked 1,704 Times
mtb_addict have you considered a twin leg, center mount stand like the Pletscher?
https://johnnyisaak.com/tweaking-div...ger-kickstand/
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
A big heavy clunky kickstand that is heavier and clunkier than anything else and looks like it is great for Walmart quality and below doesn't really appeal to anyone but maybe you? Get a double leg center mount stand or buy a dedicated cargo bike if you are loading it down and you will get plenty of great kickstands sorta like that but way better quality and even more sturdy and durable.
I enjoy single speeds because they are lightweight adding a crap ton of weight doesn't make sense. When I am locking up a bike I want to get closer to the thing I am locking to and also don't need a stand at that point. If I am loading down my single speed with enough weight I need a kickstand like that, I am clearly doing something wrong in my life.
Likes For veganbikes:
I am sure someone with skill and resources can make a lighter version of the drop stand with aluminum or something.
By the way, such drop stands are still very popular in Japan. But they are losing popularity in China, and extinct in US.
Likes For mtb_addict:
I think that is not good place to attch. Attach to axle is better. Axle is strongest part of bike.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
Axle?
https://omniumcargo.dk/shop/product/...d-new-classic/
I have the new one that is a stronger version of the Ursus Jumbo.
Not my bike, but I have one about the same
Likes For CargoDane:
Quoted: 356 Post(s)
Liked 323 Times
Just to add an explanation to the above post: It is attached to a thick double plate just behind the seat tube and in-between the backstays.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Gotta be honest: Some people want certain accessories, and most people do NOT want this stuff attached to their bike. If you want it, fine. Let’s not think it’s odd that others have not made it a priority!
Thread Killer
Liked 1,704 Times
Regardless of where is strongest because it’s simply not a relevant use concern, IMO, I mentioned the twin leg stands because, unlike the drop stand, the twin leg stand is easily available and stabilizes the bike for cargo loading.
Quoted: 2482 Post(s)
Liked 2,952 Times
With the exception of frames that have a kickstand mount plate welded in place, the only frames that are appropriate for use with kickstands that clamp onto the chain stays behind the bottom bracket are high-tensile steel frames. Carbon and aluminum frames are especially vulnerable to damage from such a kickstand, but chro-moly frames are likely to be damaged as well.
Likes For Trakhak:
Thread Killer
Liked 1,704 Times
Clamping a kickstand to robust steel frames has been happening for a very long time, so the cases where Surly was pointing out people over-tightening and crushing the stays is just that outlier segment of ham-fisted morons who make good cautionary tales for the rest of us. Particularly when clamping a double-leg, less torque is needed because there is no rotational force on the stand like there is with a single leg. Additionally, Pletscher uses rubber U-brackets over the stays to manage compression and protect the stays.
Properly installed on a suitable steel or aluminum frame, a Pletscher double-leg should be a great alternative to an unobtainable drop stand.
Likes For chaadster:
Clark W. Griswold
Liked 3,989 Times
Not true. When I was in the States, I had a Dutch-made commuter bike with a similar drop stand. I had several bike commuters come up to me asking about the stand...because it was so stable. They wanted to know where they can get one. I told them its hard to find and probably only works with single-speed. So, cyclists like commuters are desperately need better stands than what is available on the market.
https://m.youtube.com/watch?v=RLXnCu-KMdY
The Mamachari is an interesting Japanese cargo bike hence the need for a stable stand when loading kids. Any cargo or kid carrying bike could benefit from a good stable stand but there are plenty of excellent kickstands that will work and be a touch sleeker.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I can't imagine a single moment when I would want a kickstand on my bike. I hang it from a hook on the ceiling for storage and if I am out and about, I gently lay it on the ground or lean it against a tree. otherwise, a kickstand is just heavy, annoying, bouncing clutter on my bike.
Quoted: 1062 Post(s)
Liked 665 Times
Practical, utilitarian cycling has always been a niche in the US, and a subculture to some extent. I've lived with aftermarket kick stands, but there's always room for improvement. Axle mount would be OK on my single speed, but it's also supposed to be my lightweight speedy bike that doesn't have a lot of attachments. I actually removed the kickstand when the COVID started, because I no longer had anywhere to go but out on long recreational rides. The utility bike has an IGH and its axle isn't long enough to accommodate anything like that.
Making any kind of useful accessories is hard because of the proliferation of frame materials and shapes. Long gone is the time when every bike shop had a Wald basket that would fit on any bike that deserved one, and proper bikes came with a kickstand already welded on.
For those who are new to cycling, or live in regions where cycling is less popular, just keep your eye out and observe how people use their bikes. Especially for utilitarian riding, such as shopping and commuting, there is no one-size-fits-all solution, and folks will often adapt their bikes over time to fit their local riding conditions and living situation. These arrangements are hard to explain over a web forum, where adapting to prevailing conditions is seen as a sign of weakness. The most ironic thing about the kickstands on my bikes is where I get the best use of them: In my garage.
Likes For Gresp15C:
Quoted: 94 Post(s)
Liked 151 Times
The drop kickstand picture in post #1 is mounted on the rear axle. It appears to be made from steel (heavy) and since it is attached to the rear axle it must be removed when taking the rear wheel off (for example for tire/tube repair). I find axle mounted kickstands are a bit of a pain when repairing a rear flat tire. I think a center mounted double leg kickstand is a more appropriate solution like the one from Pletscher as it is light-weight and out of the way (do not need to mess with it when removing the rear wheel) and since it has two legs it is more stable than a single leg kickstand and probably as stable as the axle mounted drop kickstand. See photo...
Bikes: Way too many
Quoted: 897 Post(s)
Liked 606 Times
I can understand not wanting to pay for a heavy component you wouldn't use though.
Some people think what’s right for them has to be right for everyone. But there are different people with different needs.
Maybe someone rides mostly on deserted beaches or sand dunes and there is nothing to stand a bike against and and sand is too soft for a regular kickstand doesn’t need a lock. You wouldn’t like it if they said “carrying a lock for a single speed bike is just extra weight and would appeal to no one except maybe you”
Or maybe they can only afford Walmart bikes. Walmart bikes are excellent and maybe not as good as what you ride but 90% as good at a fraction of the price.
Or maybe they don’t mind extra weight because they’re biking for exercise and such strong riders they don’t care about a little extra weight. Many people bike to get exercise and less the weight less of a workout.
Lots of possibilities, lots of different needs. Which is great. A tip: if you think someone is doing something wrong, always take a step back and ask “under what circumstance would what they’re doing make sense?” It will open your heart and mind to lot of new possibilities.
Clark W. Griswold
Liked 3,989 Times
In terms of wally-mart bikes they are not even close to 90% as good as a bicycle, they are designed for failure because they are built with the lowest grade parts by the lowest grade labor. They are bicycle shaped but the quality is not there and wasn't designed to be there and while there are some people who are quite impoverished and maybe a bicycle just isn't the thing they need in their lives at that point as probably food, shelter and water will be more important. However with some simplifications a wally-mart bike could be barely decent but they don't want to do that, they prefer putting suspension on it and gears because it looks cool to some people. A heavy bike isn't a bad thing but a heavy bike because of really poor low quality parts is not great. However again this thread is 3 years old and hasn't been active since then and was started by someone who was involved with trolling.
Cantilever believer
Quoted: 532 Post(s)
Liked 1,830 Times
1. I do it that way (or a similar way) too
2. You do it that way, but I do it this way
3. I do it this way, WHICH IS THE ONLY WAY, AND YOUR WAY IS WRONG, WRONG, WRONG
I've found the "ignore" function to work well with frequent #3ers, and where others have quoted those persons, it seems to support that action.
(now looking that this post to see where to categorize it...)
As to the actual topic: the kickstand the OP favors would seem to only fit on a limited number of bicycles, typically those with nutted rear hubs, a specific dropout configuration (to accommodate anti-rotation features) and a specific outside rear dropout dimension. And I think most of these kickstands are installed at the factory for that make/model of bicycle. Unless speced on an OEM bike as noted, this type of kickstand could be a challenge to produce and sell for a wider variety of bicycles. The weight could also be a turn-off factor for some riders. Two-leg kickstands, as noted by other posters, might be a practical option for aftermarket installation where a standard kickstand is deemed insufficient. Disclosure: I have two-leg kickstands on two bikes (tandem and light cruiser) and kickstands on all but my lightest two bicycles (and occasionally I miss having them there, although my racer won't accept any kickstand at all).
Quoted: 4227 Post(s)
Liked 2,488 Times
I hate any type of kick stands and would never put such a useless piece of scrap metal on my bike. There are plenty of object out in the world to lean your bike against or just lay it on the ground.
Expired Member
Quoted: 3667 Post(s)
Liked 5,420 Times
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Likes For datlas:
Quoted: 18411 Post(s)
Liked 15,531 Times
Likes For indyfabz:
