Speedplay and Shoes
Bikes: 2012 CAAD 10
Speedplay and Shoes
I've been seeing a lot of ads for 2012 model shoes that add a speedplay edition or model. What is the difference from the speedplay to their normal road shoe?
Live to ride ride to live
Bikes: Calfee Tetra Pro
I not sure if I understand the question correctly so tell me if I missed the point. Speedplay cleats have a four bolt pattern. Look style pedals have a three bolt pattern so Speedplay users need to use an adapter plate with the majority of road shoes.
Bikes: LOOK 595 & Cannondale CAAD9
There really is no point in going with a Speedplay specific bolt pattern. The shoe manufacturer has to add more material on the carbon sole to create the flat mounting surface for the Speedplay cleat. The 3-hole shoes with an adapter just use the adapter itself to elevate and flatten the surface where it would normally be curved. Stack height ends up being virtually the same. Also, if using a Speedplay specific shoe, you are supposed to use a very thin steel Speedplay shim between the cleat and the carbon mounting surface to avoid damage to the carbon fiber. Why not just kill two birds with one stone by using a 3-hole Look/SPD-SL shoe and an adapter? Then you have the option of running Look or SPD-SLs as well.
I bought Speedplay Zero Stainless pedals and used them for several hundred miles before deciding I didn't like them. Had I gone with an expensive 4-hole shoe over my S-works 3-hole shoes I would have had to sell the shoes at a loss and buy another pair. It's just not worth going that route.
Bikes: Sarto Asola, Colnago EPS, Specialized Crux Sport E5
Quoted: 5 Post(s)
SIDI will be coming out with a Speedplay-specific sole for 2012. The advantage is that you don't have to deal with the 4-hole to 3-hole adapter. According to their web site, you get 62 grams lighter installed weight, 6 mm increased aft adjustment, and 4 mm lower stack height. There are many people who like Speedplay and like SIDI, so I am sure these shoes will be very popular.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
My Rocket 7's ( which unfortunately aren't made anymore) weigh a total of 360 grams for the pair in a speedplay pattern, and I can tell you the thickness of the cleat area is very thin.
My Lake's with a speedplay pattern are also very light. While not as light as the Rocket 7's, they're lighter than a lot of expensive shoes, including shoes like Sidi Genius'
As for the stainless steel plate, not all Speedplay drilled shoes require it. Moreover, the plate weighs about 3 grams, and s about 1 mm thick. It's really a non issue.
I've ridden with Look pedals, and 3 bolt shoes, Speedplay pedals with 3 bolt shoes, and Speedplay pedals with 4 bolt shoes.
There is a noticeable difference in stack height with the 4 bolt shoes, and a measurable weight savings.
Admittedly, if you're just trying Speedplay's out, it makes sense not to buy dedicated shoes, but if you're already comitted to Speedplay pedals, why not get shoes designed specifically to work with them?
You could get lost and die.
You could hit a tree and die.
Not my experience at all. It doesn't take extra material to shape that section of the shoe flat, the manufacturer just needs to shape it flat.
Sure looks like more material to me. Since they can't take away carbon at the rear part of where a normal 3-hole cleat attaches (the flatter part), and the Speedplay cleats require a flat surface, the only way to do this is to fill out the forward portion with more carbon.
The BONT shoes seem to have a little more material than what would be necessary, but the other shoe companies still need to do what I mentioned about to achieve a flat surface.
I'm just saying I don't think it's worth it to run a 4-hole shoe even if you are committed to Speedplay pedals. That's just my opinion though.
Bikes: Yes
Quoted: 9 Post(s)
pan y agua
Liked 727 Times
And there shouldn't be any inherent reason that you would have to add significant material for 4 bolts; you just shape the material a bit differently.
For the Sidi's we do have an actual comparison: 61 grams saved and 6 mm.
whether that's worth it, is another issue.
https://www.competitivecyclist.com/za...ODUCT.ID=10350
It's ALL base...
Drive on.
Bikes: Yes
Quoted: 9 Post(s)
there's no comparison pic, or data, for a 3 bolt Bont.
There's a comparison pic. There is clearly less material there. It's not just shaping it differently. The sole is going to have a minimum thickness at the rear of the cleat area. The sole usually curves up towards the toes. 4-hole specific soles fill in this curved area to make it flat from the rear of the cleat to the front of it. Dunno if that makes sense..kind of hard to describe.
Bikes: Yes
Quoted: 9 Post(s)
Bikes: 2011 Look 566 Ultegra, 2010 Specialized Sirrus Sport
pan y agua
Liked 727 Times
https://www.cyclingnews.com/features/...or-2011/144839
Rocket 7's at 180 grams a shoe clearly show you can build a 4 bolt shoe without a lot of excess material.
Based on those pic's I'd be skeptical about getting a 4 bolt Bont shoe, without seeing and feeling it side by side with a 3 bolt, but it wouldn't steer me away from all Speed play specific shoes.
Bikes: 2012 CAAD 10
Yeah after looking at my shoes with speedplay cleats and the new shoes I feel like an idiot. Pretty self explanatory
Quoted: 10 Post(s)
No, you should really read their website and have some on your shoes like I do. It is a 3 and 4 bolt system.
THE LOWEST STACK HEIGHT: The Zero cleat positions your foot closer to the top of the spindle for improved power transfer.
- 11.5 mm stack height for 3-hole mounting
- 8.5 mm stack height for 4-hole mounting
FITS MORE SHOES: The Zero cleat fits any shoe with a 3-hole or 4-hole mount.
It comes with the plate for 3 mounting right in the box!
