Grease or Oil?
Quoted: 72 Post(s)
Liked 19 Times
Grease or Oil?
I'm wondering if I should use grease or oil to lube the larger seatpost that drops through the frame on the Dahon eezz d3. I'm using silicone oil on all the moving parts of the fold but I'm not sure what to use on the drop down seatpost.
On a vertical surface like a seatpost or seatmast, I like grease. Oil can get messy and leak into areas you don't want it to, whereas grease tends to stay put.
Xootr folding bikes recommends applying Boeshield T-9, wipe excess off, and let it dry overnight. Not saying that applies to your Dahon though. Seems to work without being a greasy mess.
Explorer
Bikes: Dahon Jetstream XP, Merlin Road Ti, Fisher Mt. Tam
Boeshield is what I use too. It's wax based rather than oil based and leaves less of a sticky residue to collect dirt.
I came to say I must be folding . . .
Dahon Jetstream XP
Dahon Helios SL
Strida 5.0
Twenty project
— or not . . .
Fisher Mt. Tam (c.1988)
Merlin Road flat bar project
Schwinn Twinn Deluxe
Dahon Jetstream XP
Dahon Helios SL
Strida 5.0
Twenty project
— or not . . .
