Camera w/ Seat Stay Mount?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
I am planning on buying my first rear-facing video camera for my bike, and am wondering if there are any that have a seat-stay mount. The ones I am seeing are either seat tube mount, seat post mount or helmet mount.
Quoted: 4560 Post(s)
Liked 2,802 Times
I've seen hub level/dropout camera mounts. Mostly used with the smaller cameras like the GoPro Hero 5 or discontinued Polaroid cubes.
I'd be cautious about a clamp mount on a seat stay, especially carbon fiber. I do mount a Cygolite Hotrod on the seat stays of my carbon fiber bikes, but those are featherweight lights with rubber band mounts. Even a small camera would need a more secure mount.
Standard Member
Liked 940 Times
I mount my rear facing camera directly on my rear rack. It's literally in their face when any driver approaches me from behind.
It's clear view of their licence plate, even at 1080p30fps.
Likes For Daniel4:
Quoted: 1364 Post(s)
Liked 1,678 Times
My last two action cams have had standard threaded 1/4" female receptacles. While I don't use a quick release to mount them on my helmet, there are many more mounting solutions for standard 1/4" threaded camera mounts than for any proprietary mounts.
I like the idea from Daniel4 of mounting on a rear rack (if possible).
Likes For BobbyG:
Liked 2,802 Times
Yeah, I use a clip-in mounting shoe on the rear rack of my hybrid. With the Drift Ghost cameras the mounting shoes are all you need for flat surfaces (like racks) or slightly curved surfaces like helmets.
On my road bikes I use Drift's clamp-on articulating mounts, usually on the stem or handlebar, and on the seat post facing rearward.
Lower mounting is often better for recording license plates, but handlebar or seat level is good enough and offers a slightly higher vantage point which can help with perspective and recording the surroundings. Lower mounts tend to limit visibility beyond anything directly in front of or behind us.
Likes For canklecat:
OwainGyndwr
Years ago after purchasing a couple Go-Pro knockoffs I rigged the enclosed attachment with a seat-stay light mount, foam and some duct tape. It wasn't pretty, but it was functional. Had to mount it below my pannier and by trial and error got it dialed in. Attached it nds as that was roadside. The front was easy. Handlebar mount with foam. Both cameras were rechargeable. The images were crisp black and white. Served me well for about 5 years.
Likes For GhenghisKahn:
Standard Member
Liked 940 Times
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
I've been using saddle rail mounts for the past few years. It works well, but if you go this route, be sure your camera is tethered somehow. I've had a few mounts break on me, whether plastic or aluminum. The first time it was untethered and I didn't know until I got home, but thankfully I was able to backtrack and find it. I've had it break again, but the tether held on to it.
Likes For mcours2006:
Cop Magnet
My rear cam is a GoPro Hero Session 4 with a saddle rail mount. I got the mount from K-Edge. It was kind of pricey, but it's been reliable. Now, it also meant I had to get rid of my saddle bag to make room, so now I use an aero top tube bag that mounts directly behind the headtube.
Likes For JW Fas:
Quoted: 9 Post(s)
Liked 13 Times
Been around the block
Quoted: 102 Post(s)
Liked 231 Times
My rear facing camera is mounted to the rear basket, and it really shows how close a pass some drivers make. Another plus is that my incidents with drivers, while stopped at stop signs and stop lights, greatly dropped when I installed a rear facing camera. It seems that many driver are very observant of a camera when it's being pointed at them.
Likes For roundypndr:
Regardless, it appears the presence of the camera in plain sight is already a deterrence.
Quoted: 102 Post(s)
Liked 231 Times
There was some jiggle on my initial trials, but with some zip ties, and having a sturdy built basket, I usually get a good number of clear frames of viewing at 30 fps in 1080p.
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Quoted: 474 Post(s)
Liked 204 Times
I made this for someone.
https://www.shapeways.com/product/GF...40219&li=shops
Go to the Electronics, Lighting, & Gadgets forum and look at the 3d printed mounts thread.
Likes For JonnyHK:
Likes For work4bike:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
I don't often use this mode, but it works fine. Contour camera with ski-pole mount on my seatstay.
Quoted: 18382 Post(s)
Liked 4,515 Times
I might be interested in a dropout mount, but one of the main things I am aiming for (hence, my desire for a seat-stay mount) is high-visibility to motorists who might have less-than-honorable intentions. I figured up higher is better. The bike I would be using this on (Technium) has steel seat stays. Yeah, I like the rubber-band mount on the Cygolites.
I'm seeing a few seat rail mounts.
There seems to be almost any imaginable gopro mount, but I'm not seeing any small tube mounts.
Perhaps a bolt on rack mount?
I doubt would have noticed the camera if it was mounted on the seatstay especially as a motorist as I'd be looking at the cyclist's jersey and helmet. A camera behind a rear basket would be more noticeable but the top of the helmet is absolutely the best spot and by far.
Standard Member
Liked 940 Times
