How to separate these shoes?
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times
Is it easy to separate these brake shoes?
Quoted: 6269 Post(s)
Liked 4,863 Times
- Separate them from the rim for spacing.
- Separate them from the rim for wheel removal.
- Separate them from their holders for replacement.
Which?
1. Usually there is a barrel adjuster on the part of the caliper you didn't get in the picture. Screw it in some to open the gap. If no barrel adjuster on caliper or brake lever then undo the cable from the pinch bolt.
2. Some have a release on that part of the caliper you didn't get in the picture that you just flip and it opens much wider so as to let the wider tire pass. If no release, deflate the tire or turn the barrel adjuster all the way in.
3. That's for others to answer. I usually just replaced the entire pad and holder.
Centering next?
Likes For Iride01:
Quoted: 530 Post(s)
Liked 474 Times
Depends. Sometimes you can just grab the rubber block with pliers and twist it out, or stick a flat screwdriver in the end and pry it. Then you have to tweak the holder to fit the new friction material - gently open the long sides until the block can be fitted, then close them up again.
Likes For grumpus:
Liked 4,863 Times
Quoted: 530 Post(s)
Liked 474 Times
The Weinmann button is a neat design - I imagine you're not the only person who failed to notice its added function, in fact I have a vague recollection of someone complaining about its sloppy fit.
Likes For bboy314:
Quoted: 4846 Post(s)
Liked 3,976 Times
@juntjoo, tell us more about what you are wanting to do. Yes, some here will consider nearly anything you want to know a dumb question but others want to help. And there is a lot of knowledge here.
There are brakes more modern than yours that are much easier to work on and live with, plus modern levers that offer features seldom found in the older brakes. Also other parts and tricks that can address specific issues. Probably a few workarounds on what you have now. But to help you, we need to know what you want changed
Likes For 79pmooney:
Quoted: 103 Post(s)
Liked 8 Times
Which?
Centering next?
Liked 3,028 Times
I'd drop the wheel assembly out. While it's out, inspect & clean the mech parts.
-Oh Hey!
-Oh Hey!
Quoted: 530 Post(s)
Liked 474 Times
[MENTION=552772]
Old fart
Quoted: 3606 Post(s)
Liked 3,431 Times
To get to the OP's apparent issue, to remove the pad itself from the holder, you can often pry the pad out with a screwdriver. If the holder is of the type that is stamped from sheet metal, with the edges folded up to retain the pad, you can bend one end of the holder down to create an opening through which you can drive out the pad and slide in a replacement. N.B. Most of these types of holder are aluminum, and can be weakened by bending the tab to create the opening; after doing so, position the pad with the weakened tab toward the rear, so that braking action does not bear against the weakened tab.
Another option is to replace the entire pad/holder assembly; these are usually quite generic. The Dia-Compe "G" caliper in your picture uses a 6mm x 1mm (M6) threaded stud to secure the holder to the caliper; this is a very common design, and any replacement with the M6 stud ought to work.
Quoted: 103 Post(s)
Liked 8 Times
Here's a closer look. Not sure how these work. My rim is a little off. I adjust often and can never get perfect, thus it rubs against the shoes a little. So I'm thinking pulling them apart might help
Quoted: 564 Post(s)
Liked 422 Times
Those calipers were popular on almost every low-end bike from the 80s, it's centered by using two 10mm wrenches and you turn the entire assembly.
Long time part timer
Rim width?
Just a thought...
Is the wheel original to the bike? If not, perhaps the replacement rim width is a bit too big for the caliper.
Quoted: 374 Post(s)
Liked 848 Times
Still hard to ascertain exactly what issue you’re having from your description, but… if the brake caliper won’t open enough, with no cable tension, to clear your rim completely, you can pop each side of the spring out from behind the caliper and gently bend it out, essentially increasing the tension.
Quoted: 530 Post(s)
Liked 474 Times
Your barrel adjuster is screwed right down, no further adjustment available, so you'll need to let the cable out a bit. Loosen the pinch bolt, gently pull the lever so a small amount of cable slips through and retighten the pinch bolt. If that's too slack take it up by screwing the adjuster out.
Likes For grumpus:
Liked 4,863 Times
Ditto what @grumpus said. You don't have any adjustment to open them. I usually will undo the pinch bolt, then unscrew the barrel adjuster about half way and then squeeze the calipers together with my hand and snug the pinch bolt down with the other. Make sure to pull on the end of the cable before you tighten it to get all the slack out. As well, make sure the cable housing is fully in the barrel adjuster and any cable stops or ferrules all the way back to and including the brake lever.
It's easier to do than you might think from the description. But if the caliper springs are too strong for you, a quick clamp or even a old inner tube stretched and wrapped around the pads and wheel will hold them to the rim while you snug up the pinch bolt. After that you should have enough adjustment to screw the barrel adjuster in a few turns to open up the calipers. If your wheel is warped you might need more. If so, then just unscrew the barrel adjuster more before tightening the pinch bolt.
And it does look like you have the lever to open up the calipers for changing wheels quickly. It might be that someone set the pads with it open. And now that it's in the normal closed position the pads are too tight. You could just lift up on that lever with the black plastic on it and they'll open. But that's not the correct position intended for riding. That's just to open them wider for getting wide tires past when changing.
Likes For Iride01:
Old fart
Liked 3,431 Times
Likes For JohnDThompson:
