Gp5000 hard to find
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Gp5000 hard to find
For several weeks I’ve been monitoring 700x28 gp5000 (NOT tubeless) and have had little luck tracking them down at reasonable prices. Is this the dreaded supply chain problems I hear in the news?
Quoted: 1098 Post(s)
Liked 1,037 Times
Looks like it, checked bike24, probikekit and a couple others. Issue seems to be with your desired size, they have 23, 25 and 30s available but not 28. Was indications that they'd be available at the end of Nov. Did find them available in the 75.00 range but I'd hold out for the 80-90.00 pair from probikekit.
Likes For Russ Roth:
Sunshine
Quoted: 11009 Post(s)
Liked 7,538 Times
https://bikecloset.com/product/conti...RoCPM8QAvD_BwE
$83/tire for the TDF sidewall version.
https://www.probikekit.com/bicycle-t...E&gclsrc=aw.ds
$115/pair for black in...30mm?
They aren't cheap right now.
Likes For mstateglfr:
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 765 Post(s)
Liked 4,053 Times
They’re all over eBay.
Advocatus Diaboli
Quoted: 4755 Post(s)
Liked 1,537 Times
I don't know what 'reasonable price' means these days, but Excel has them at 15% off from what they indicate as MSRP
https://www.excelsports.com/continen...5000-road-tire
RacingBear
If you can settle for 25mm they are 42 bucks at probikekit. I guess everyone wants 28mm, so they are hard to find. Not just GP5ks, other brands also.
https://www.probikekit.com/bicycle-t.../11959283.html
The 30mm are 65 bucks.
Quoted: 2333 Post(s)
Liked 2,097 Times
28mm gp5000 tubeless is hard to find.....clincher can be found
Quoted: 6240 Post(s)
Liked 4,840 Times
Liked 2,097 Times
What's your point? Should I have given the UPC codes? Standard terminology is tubeless or clincher. One uses a tube and the other does not. The one which does not use a tube has been in short supply for many months, especially in 28mm.
Advocatus Diaboli
Liked 1,537 Times
Meanwhile we have no idea what the OP is referring to, TL or non-TL. Or maybe neither, but rather clinchers
Liked 2,097 Times
The answer to his question is obvious. "Yes"
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
FWIW friend owns a local LBS, I just got the last of his gp5000’s in TL still had some clincher but no 28’s. He mentioned that his incoming shipment continues to get moved further out and was recently cancelled and replaced with the new variation of GP5000’s. But then also pushed out by almost 3 mths. He spends half his time sitting online trying to grab needed parts to complete builds or lose them to other shops. Crazy times
Likes For robbyville:
Argh it’s so frustrating. I’d been waiting for disc brake pads for what feels like weeks, finally managed to snag a set but it took awhile. Even my LBS was out for a good long while.
I have some 28mm Conti 5000s sitting in my basement. Let me know if you’re interested.
Liked 4,840 Times
Indeed, The Pro's Closet even has a page that says clincher tires must contain a tube.....
https://www.theproscloset.com/blogs/...RoCs9AQAvD_BwE
Though a couple of tire manufacturer sites I went to don't specifically say that a clincher must have a tube. They describe clinchers as simply tires that mechanically hold to the rim by their beads and air pressure. But they do go on to later describe tubeless tires as not having a tube, but not in the same paragraph as clinchers.
So I'll not speak of this or admonish you or others again ...unless I'm able to find some further support for my position.
Liked 2,097 Times
To me a tubeless tire is also a clincher tire. They mechanically fit to a rim by the same ways. However I took another look at what being said today, it seems like many vendor sites are now merchandising them as if they are different and separate from the clincher class of tire.
Quoted: 2997 Post(s)
Liked 1,192 Times
No it's not. Took me 15 seconds.
https://www.backcountry.com/continental-grand-prix-5000-tl-tire-tubeless?CMP_SKU=CON005Q&MER=0406&skid=CON005Q-BK-S28MMBKCL&mr:trackingCode=C12DD57D-5573-E911-810C-005056944E17&mr:referralID=NA&mr:device=c&mr:adType=plaonline&CMP_ID=PLA_GOc001&utm_source=Google&ut m_medium=PLA&k_clickid=_k_EAIaIQobChMItYX79sb38wIVeGxvBB0Iag2cEAQYASABEgJ0KvD_BwE_k_&utm_id=go_cmp-213415837_adg-13362825397_ad-92885919277_aud-318683175055la-1457379567078_dev-c_ext-_prd-CON005Q-BK-S28MMBKCL&gclid=EAIaIQobChMItYX79sb38wIVeGxvBB0Iag2cEAQYASABEgJ0KvD_BwE#
https://bikecloset.com/product/conti...iABEgIeo_D_BwE
https://www.bicyclebuys.com/continen...CABEgLc8fD_BwE
https://www.competitivecyclist.com/c...CABEgKd2fD_BwE
Liked 2,097 Times
https://www.competitivecyclist.com/continental-grand-prix-5000-tl-tire-tubeless?skid=CON005Q-BK-S28MMBKCL&CMP_SKU=CON005Q&MER=0406&CSPID=0914&mr:trackingCode=2232F4E4-5073-E911-8101-0050569428E8&mr:referralID=NA&mr:device=c&mr:adType=plaonline&mr:ad=302442016703&mr:keyword=&mr:matc h=&mr:tid=pla-450518941845&mrloc=9019169&mr:iloc=&mr:store=&mr:filter=450518941845&CMP_ID=PLA_GOc014&CSPID=0914& utm_source=Google&utm_medium=PLA&k_clickid=_k_EAIaIQobChMI6eeJqMf38wIVAXxvBB1olArCEAQYCCABEgKd2fD_Bw E_k_&utm_id=go_cmp-1596143923_adg-59468410479_ad-302442016703_pla-450518941845_dev-c_ext-_prd-CON005Q-BK-S28MMBKCL&gclid=EAIaIQobChMI6eeJqMf38wIVAXxvBB1olArCEAQYCCABEgKd2fD_BwE
Why don't you place an order and see how fast they come.
Liked 1,192 Times
I've bought from all of those places at one time or another. They are reputable. If you refuse to open your options then no wonder you can't find stuff.
This whole thing about "can't find bike parts" is overated. You just have to be willing to look at other places.
I just recently put some new parts on my mountain bike...Dropper post, dropper post lever, 2 new SRAM rotors, new seat, new cables, new SRAM X01 Shifter...ordered all parts from Amazon and had them within a week.
Method to My Madness
Quoted: 1976 Post(s)
Liked 1,499 Times
Sunshine
Liked 7,538 Times
backcountry and competitive cyclist are the same thing.
Regardless, none of those are priced very well relative to what we are used to. I think that was part of the point t of the initial post- not that there are 0 options, but there are no reasonably priced options..
So get into an argument over what is and isn't considered reasonable, I guess.
I'll just say that I expect the paid price for gp5k to always be less than the paid price for Rene Herse tires. Gp5k for more than RH is a touch excessive.
Liked 2,097 Times
I had to order a 12 speed cassette from europe. Of course, some smart ass will come on and show that they are available TODAY w/o consideration that they may not have been available last week.
Likes For GhostRider62:
Quoted: 345 Post(s)
Liked 237 Times
Very kind of you to offer but I'll wait it out. Still have life left on my Gatorskins
Likes For Symox:
