Woe is the Hozan
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Woe is the Hozan
Have any of you ever successfully repaired or readjusted the Hozan or Cyclo thread rolling head? For some reason mine - after about 50 spokes - decided to not work for me. Now I'm a retired machinist. I got quite the knowledge base on threads and machines, surely, but this bloody Hozan eludes me. I guess what really irritates me the most is that there's no price-point-higher thread roller between the Hozan and the Morizumi. like a $500 dollar version that actually WORKED.
Comments? Advice? Thanks!
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Replacement heads are available, but it's worth playing with the adjustment before biting the bullet on a new one. The thread on the main body is tapered much like a pipe thread, so moving the nut in or out will adjust the clearance.
I built a lot of wheels using a Hozan before finally buying the Morizumi. I replaced the rolling head a couple of times.
2-Wheeled Fool
Liked 677 Times
Beware that you pretty much need to flood the Hozan's head with oil, or it will wear out in short order. I keep a can next to the ones that I use, and a drop goes on right at the base of the rollers for every spoke. The large nut needs to be turned up or down the head, depending on the spoke you use, as not all blanks (or threaded spokes) are the same diameter, even if they are nominally. Noodle with a sample spoke until you can thread the nipples that you are using with no issues.
Just as an aside, I find that Wheelsmith blanks leave a ton of swarf compared to other brands when I am rolling them. The price of being inexpensive, i guess.
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
I've had success adjusting a Hozan that was given to me after the prior owner gave up on it. What worked for me was to back off (loosen) the adjustment nut to a point where it just started to leave thread marks on a fresh spoke. Then I tightened the nut a wee bit and tried again on another fresh spoke. 'Did this over and over until I liked the fit of the nipple to the spoke. The key step for me was to use a fresh, unthreaded, spoke each time after adjusting the nut.
In a prior attempt, I rolled over the same threads after each adjustment. With this approach I could get a decent fit on the trial spoke, but attempting to thread a fresh spoke with the same set-up on the Hozan tool was a disaster.
It is probably obvious, but you can do a heap of test rolls with just one spoke. Just cut off the threaded portion, de-bur the cut end, and use the same spoke in the next test.
I've never used my Hozan for a complete wheel build, but it is very handy when I'm short a few spokes to complete a build or make a repair.
Dean
Dean
Roll Me Up and Smoke Me When I Die
LBS uses their's like that 1 or 2 spokes for a bike tourist riding the coast.. have not every length needed, in stock ..
2-Wheeled Fool
Liked 677 Times
That indicates inferior steel or some shortcuts in the manufacturing process, like drawing and/or heat treating. Is this on plain steel spokes? Stainless? Curious...
Friendship is Magic
Bikes: old ones
Quoted: 26401 Post(s)
Liked 10,374 Times
...I've never seen a Wheelsmith spoke that was not stainless.
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
My impression was always that they were made for Wheelsmith by someone else back then, and I've used both those and DT's without noticing any significant differences. Again, these are from probably ten or fifteen years back. I don't know who makes them currently, but the remaining brother has some kind of ongoing blog presence that might tell you.
The only real problems I've ever encountered is with trying to cut to length and roll threads on galvanized steel. That was abad idea to begin with, and I don't use any galvanized steel spokes any more, ever.
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
Quality of the Wheelsmith spokes is fine...my observation was simply...that. Simply an oddity, not that they were poor quality, or some such.
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
...here is the story since 2007. All my spokes are probably from before that time. I'm pretty old.
