What are you using for a helmet light?
Old 10-13-19, 11:29 AM
PastorJim
Bikes: Trek 1.2, Schwinn Sidewinder 26" Men's (SRAM Max Pro) & Trident TW Bents
Quoted: 32 Post(s)
I want to add to my arsenal of lights a "helmet light". Please share what you are all using and/or recommendations.
Thanks,
Jim
PastorJim is offline
Old 10-13-19, 11:48 PM
znomit
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times in 366 Posts
Originally Posted by Spoonrobot
Front or rear?
For front I use a Zebralight H600w MkIV Neutral White. Nice blend of throw and flood, good color rendition, and has very long battery life with commonly available batteries while still being reasonably lightweight.
+1
Also it's easily adjustable up and down to point exactly where you need it.
znomit is offline
Old 10-14-19, 04:36 AM
bpcyclist
Quoted: 451 Post(s)
Liked 364 Times in 227 Posts
Cygolie Metro Pro 1100 w/Helmet Mount Kit
bpcyclist is offline
Old 10-15-19, 08:38 AM
Milton Keynes
Milton Keynes's Avatar
Quoted: 2281 Post(s)
Liked 1,710 Times in 936 Posts
My helmet has a built-in red LED in the rear, two modes of flashing or solid on. Not super bright but noticeable. I don't rely on it, mainly on the taillights on my bike, but use the helmet light to augment my other lighting.
As far as a white light on front goes, I have a light made to clip on the visor of a ball cap which easily clips onto my helmet visor. Again, it's not super bright, wide field lighting, but just augments my bike's headlight and gives me a little more visibility as well as allows me to look down & see my bike if I need to.
Milton Keynes is offline
Old 10-15-19, 08:49 AM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
To see with, or to be seen? For example, I'm considering a better to-see headlamp because I ride so often at night in rural areas with lots of critters.
To see with, many folks seem satisfied with the helmet-specific Light & Motion Vis models. It's one of the few L&M lights the local REI still stocks, presumably because of demand by gravel and mountain bikers.
Most others I see are regular bike headlights cobbled onto helmets and they look about as awkward as it sounds. If the light is mounted into a helmet vent, it's lower profile but can't be adjusted so it needs a broad floodlight beam. If it's adjustable it'll probably be on a mount that sticks way up.
To be seen, for years I've used a Blackburn 2'Fer, mostly as a rear light. The 2'Fer is cleverly designed, with four modes: white and red steady and flashing. A single button cycles through the modes, with blinking red the default. A long press turns it on and off. Decent strap mount although I prefer homemade straps from thin, lightweight velcro or rubber. The plastic spring clip is sturdy and secure, with more than one nib/hook doodad to grab mount straps.
On the front of my helmets, I vary between another Blackburn that's not quite as satisfactory -- the Click front -- and what was called a Vivo-Bike Illuminati, which is now only available through Chinese bulk order suppliers although some will fulfill single or small batch orders.
The Blackburn Click is white only, steady or flashing, and has a fussy on/off switch. I'd skip it. The 2'Fer is much better.
The Illuminati is a clever little thing, about the size of a Bic lighter but weighs less, with two steady and one flashing mode. It's directional but not quite bright enough for a to-see headlamp. And it has big, bright side ports, enhancing visibility. It's been so useful I may order a few more from the bulk supplier. Recently I haven't used it as often because it partially blocks my Drift Ghost X video camera mounted on my helmet.
canklecat is offline
Old 10-15-19, 09:15 AM
rseeker
rseeker's Avatar
Quoted: 318 Post(s)
Liked 149 Times in 104 Posts
I have two eBay "tactical" flashlights on top, pointing forward. Having two gives a nice wide field of lighting. They're attached with hair ponytail bands, looped over one end of the flashlight, down into the helmet through a vent, back out through another vent and looped over the other end of the flashlight. This keeps them in place while allowing me to think they'll be break-away (stretch-away) in a helmet-skidding crash.
I've had these for a year. I got good runtime with disposable AAA cells (three each flashlight) but finally started using rechargeable 18650s (one per light). The runtime seems somewhat less and once they need charging the light output falls off fast, but they're very bright.
Flashlights were $12 for the pair; batteries $22 (that's two to use and two as hot spares), charger $15, hair bands $2. The downside is I look insectile or crablike with those two lights up there. I'd rather have the lights integrated like engine nacelles on a B-2, but I won't get that for $12.
I have both set to widest beam width, which overlaps about 20% in the middle. This is fine, it's like a brighter spot where I'm looking. I do wish I could diffuse the beam edges toward the sides, but when I tried a diffuser it cut the light output too much.
Anyway, this is working well for me.
rseeker is offline
Likes For rseeker:
Old 10-15-19, 09:17 PM
ab_antiquo
Quoted: 44 Post(s)
Liked 25 Times in 17 Posts
A Gemini Olympia. The wireless remote is nice since it also syncs with my bar light and I can change the brightness without taking my hands off the bars.
ab_antiquo is offline
Likes For ab_antiquo:
Old 10-31-19, 02:34 AM
blue192
blue192's Avatar
Bikes: Norco Scene 1, Khs Westwood, Jamis Allegro 3x
Quoted: 142 Post(s)
Liked 74 Times in 47 Posts
I am currently using a Cateye Volt 800 as a helmet light am quite happy with it. I have also used a Cygolite similar to a previous poster and those are nice choice as well.
blue192 is offline
Old 11-01-19, 06:43 AM
Robert C
Robert C's Avatar
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times in 48 Posts
I'm using an older Light & Motion 360. It is several years old, but it still works well.
Robert C is offline
Old 11-03-19, 09:25 PM
a1penguin
a1penguin's Avatar
Quoted: 139 Post(s)
Liked 33 Times in 20 Posts
A 1" diameter, 4" barrel 18650 flashlight. My Shiningbeam S-1 is showing signs of aging and I just purchased a Convoy S2+. It claims to be 1100 lumens (the S-1 was 400, tops) and I'll be using it on medium or low. https://www.fasttech.com/p/7875500 is a good velcro mount for helmet. Back when I used a flashlight on the bars (pre Cygolite days) this was the best handlebar mount (if your bars are sized right): https://www.fasttech.com/p/1193005.
a1penguin is offline
Old 12-02-19, 04:51 AM
rdrsonthstrm
rdrsonthstrm's Avatar
Bikes: Argon18 Nitrogen
Moon Vortex Pro (or just the Vortex if you’re happy with less light).
rdrsonthstrm is offline
Old 12-04-19, 04:58 AM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Triban RC520 Gravel Ltd, Btwin Ultra 520 AF GF, Triban Road 7, Benotto 850
Quoted: 402 Post(s)
Liked 215 Times in 137 Posts
I use this on the handlebars:
https://es.aliexpress.com/item/32679...chweb201603_55
And this on the helmet:
https://es.aliexpress.com/item/32614...chweb201603_55
Note: I have no affiliation with this seller. It's just a link with the same product I bought.
The first one has a nice spread and more than enough power to descend at hight speed. I power it with a 6 cell 18050 battery attached to the handlebar. Battery life is around 3hr at low setting, and 1.5hr at max.
The second one has a more concentrated lightning area. Not ideal for great forward vision as it lacks enough spread, but excellent to light the area that I'm looking at. I power this with a 4 cell 18050 battery I carry on my backpack. Battery life is around 4hr at low, and 2hr at max.
The helmet light comes handy to look the sides of the road/path for wildlife and other potential hazards. Also, it lets me see around me and not just in front, which is always nice when pitch dark, and finally, provides a backup light in case the other one suddenly fails, which is something I always worried about when descending at night.
If it's a lighted area, I only use the handlebar light at low. On dark areas, when climbing, I use both at low. And when descending both at high setting.
Amt0571 is offline
Likes For Amt0571:
Old 12-11-19, 11:24 PM
Vintage Schwinn
Quoted: 346 Post(s)
Liked 393 Times in 257 Posts
I do like all of the MacGyver-ing that all of you have done.
RockBros has an excellent helmet with built in light.
https://www.ebay.com/itm/RockBros-Ro...arms=aid%3D111
There are so many bicycle headlights that can be utilized, on the handlebars, or the stem, or front brake caliper bolt on ancient bicycles.
You also have many ready made, flashlight mounts that can be found by searching twenty or so ebay pages SEARCH: china bicycle ON EBAY(search all categories).
Then further search "view other items" within these mammoth chinese ebay powersellers...........hit the see all categories on the left side......see Sporting Goods....select Cycling, bicycle parts, bicycle accessories, bicycle lights, etc.......whatever relevant heading, and look through the offerings..............pay attention also to the other sellers' offering the same item at equal or lesser costs.........repeat the process.......... ......you will be surprised at the huge breadth of different mounts, lights and everything you can imagine.............yes, it might take you searching several days, of one hour of searching, but you will find plenty of handy items that you cannot find
at the LBS, Target, or Wal-mart. Buying these New chinese goods via ebay offers you significant protection from being totally ripped off because you will be protected if for instance that the seller doesn't ship you the item----Paypal and ebay will protect you the purchaser. Now you're outta luck if the item is just ineffective but accurately pictured and in otherwise good condition. Obviously, there are many items out there and in retail stores and also local bike shops that "promise" more than they deliver as far as practical functionality. It is your duty as a shopper to determine that and do your due diligence and decide accordingly and determine whether it is likely just hype or something that might actually have practical functionality that will benefit you and make your bicycle riding more enjoyable.
......Heck, even something as MacGyvered like two stainless steel radiator hose clamps from any auto parts store or wal-mart auto parts section, will snugly secure any of those four inch long, round metal 9 LED, three AAA battery flashlights that Harbor Freight sells in packs of two for about $1.99...........they once had a regular FREE COUPON with any purchase for just one of the all Black version flashlight.
You should really look at the many ready made BICYCLE lights from the many mammoth China based EBAY sellers. You'll find so many lights under $10 and none of the lights will be more than $20. I don't have to tell you that the exact same light might be in Wallyworld or your LBS for much much more, and you'll find a larger selection from the ShenZhen, and Hong Kong based mammoth Ebay sellers rather than locally.
Vintage Schwinn is offline
Old 12-12-19, 11:52 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
For what it's worth, REI has some head lights (for hikers) on sale right now. Some are up to 350 lumens, and can do white or red light. (Hikers user red in camp to preserve their night vision.)
Seattle Forrest is offline
Old 12-12-19, 06:19 PM
tomtomtom123
Quoted: 350 Post(s)
Liked 122 Times in 90 Posts
I made my own magnetic breakaway lights.
https://www.bikeforums.net/electroni...l#post21207410
tomtomtom123 is offline
Likes For tomtomtom123:
Old 12-14-19, 11:00 AM
tcs
Palmer
tcs's Avatar
Quoted: 1657 Post(s)
Liked 1,803 Times in 1,050 Posts
Hey, I got no dog in the fight - or the manger - just thought I'd pass this opinion from the Bicycle Helmet Safety Institute along for anyone who's open to an opinion other than their own:
'The first and most important rule for mounting a light on your helmet is that it must break away readily when you crash or catch an overhanging obstacle. If it does not, you risk having your neck jerked when it snags on the pavement or tree. Besides jerking your neck, that can add to the g's of the shock to your brain when you hit pavement.'There is no standard for how easily the light should detach. The CPSC standard says it should "readily" detach during normal lab impacts. But "readily" is not defined. Few helmet or light manufacturers have given enough thought to their mounts. Only one helmet manufacturer we have spoken to provided their lab test levels, Uvex, proving that they actually have an internal standard. And the light manufacturer Jet Lites has a standard requiring their mount to break away when loaded with a 5 pound weight.
'Some manufacturers use hook-and-loop straps to hold their lights on. We have seen some that wrap through the vents and under that seemed unlikely to detach when they should have. But again, there is no standard for that.'
Straps that wrap from the exterior to interior of the helmets would of course need to not capture any anti-rotation feature of the helmet and keep it from functioning.
tcs is offline
Old 12-14-19, 02:15 PM
tomtomtom123
Quoted: 350 Post(s)
Yes I know this. Which is why I made my lights attach magnetically. It will slide off with a 300g perpendicular weight. All that would remain is a 1.5mm think washer with a piece of tape covering it, that could possibly also come of since it's only got a piece of double sided tape under it.
Old 12-14-19, 03:01 PM
bpcyclist
Quoted: 451 Post(s)
The Cygolite helmet mount kit wraps around and through the vents and then attaches via a very strong velcro. Sounds like that might not be so safe, at least according to the above. Does anyone know of any alternatives that might fit a Cygolite light?
Old 12-14-19, 03:27 PM
noglider
noglider's Avatar
Quoted: 7336 Post(s)
Liked 2,435 Times in 1,422 Posts
I bought an inexpensive helmet from a Chinese supplier, and then I read that some of them make some very defective helmets, and you can't tell by just wearing them. I imagine some are OK, but I want to be assured by buying from a local, known company.
noglider is online now
Old 12-16-19, 07:15 AM
tomtomtom123
Quoted: 350 Post(s)
Glue a magnet to the bottom of the mount and glue or tape a thin steel washer to the helmet.
Old 12-16-19, 08:33 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
I had a nice bright headlamp that fir nicely with my helmet. gave it to my daughter & I ride with a helmet that had a face shield so that technique has limited use for me. but you reminded me to get myself another good headlamp, cuz it's useful for other stuff like stopping & going in your bag, or fixing a flat etc
gonna give this one a try LUX · PRO Bright 400 Lumen Camping LED Headlamp - LP347
rumrunn6 is offline
Old 12-16-19, 09:53 PM
Koyote
Quoted: 6932 Post(s)
Liked 10,932 Times in 4,669 Posts
tcs , I have no dog in this fight, either. I've never used a helmet-mounted light. However, I do wonder about this: when I've seen such lights, they are mounted directly on the top of the helmet (for obvious reasons). I have crashed and wrecked a few helmets over the years, but never put damage in that spot; rather, I usually land on the side or very rear of the helmet. So, I wonder if a helmet light is theoretically dangerous, but practically not quite as dangerous...?
Also, if a helmet-mounted light does reduce a helmet's effectiveness, that must be weighed against the reduced likelihood of a crash from using the light.
Koyote is offline
Old 12-16-19, 10:02 PM
bpcyclist
Quoted: 451 Post(s)
Interesting point. The only times I have hit my head (always with helmet) on the pavement, it has always been one side or the other. I think if I hit the top of my head ever, I may have bigger problems than a head injury--namely, my cervical spine. The brain can often heal. The c-spine, sometimes not.
Old 12-17-19, 06:20 AM
tomtomtom123
Quoted: 350 Post(s)
My magnetic mounts completely side off with 300 grams of load.
An injury with a hit to the top of the helmet with a firm protruding helmet light could happen for example if you ran into tree branches.
Old 12-19-19, 11:31 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Older Light and Motion model with largish battery pack.
~800 light mounted on a dedicated helmet, battery pack goes in jersey, or more often jacket pocket, as used mostly in winter.
A bit clunky but battery lasts very long, & weight on helmet is low. Mostly on lower setting as also using handle bar light.
woodcraft is offline
