Garmin Ant+ HRM Strap Alternative?
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I now own my 3rd Garmin HRM strap where I cannot get the screws out of the back of the module. I have 3 different 'Precision Screwdriver Sets" (down to 2mm and/or PH0 Phillips heads). They are too big. A 1.4mm flathead kind of fits but I still can't get the screws out.
I am tired of collecting functional Garmin HRM's with dead CR2032 batteries. What is a decent HRM strap alternative (ANT+)?
Thanks.
dave
Thanks.
dave
Non omnino gravis
Quoted: 452 Post(s)
Liked 162 Times
dave
Bikes: 2024 Specialized Tarmac SL8Pro, 2022 Specialized Epic Evo, 2021 Framed Alaskan Fatbike,2019 Trek Emonda SL6 Pro, 2018 Trek Stache 9.7, 2013 Specialized Roubaix SL4 Expert, 2009 Ritchey Breakaway Cross, 2016 Lynskey ProCross, 2008 Trek T1000 Tandem,
Quoted: 18 Post(s)
Liked 5 Times
Scosche Rhythm+ armband
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Wahoo Tickr, 4iiii, there are many ECG straps that are out there.
Likes For DaveLeeNC:
Quoted: 3460 Post(s)
Liked 1,466 Times
I bought a Garmin ANT+ strap from Asia, shipping can take a month, opens with a coin. Similar to this one.
https://www.ebay.com/itm/New-Origina...T/254442510724
While looking for above, this one is in USA and might need a new battery.
https://www.ebay.com/itm/Garmin-Prem...W/174116366720
I've been happy with the Polar OH1. Not a chest strap, but when I had my stress echo done a few months back I wore it and the numbers seemed to align well enough (same peak, slightly delayed, but generally within 1-2 bpm). Rechargeable battery, strap seems solid. I wear it on my tricep and usually within a couple minutes I forget it is even there (did take some time to find the right balance of tightness to keep it in place and looseness to make it feel invisible).
Quoted: 452 Post(s)
Liked 162 Times
I just ordered a Wahoo from Amazon - had no idea that non-screw Garmin's existed. We'll see how the Tickr works. Should be here tomorrow.
dave
dave
Quoted: 2604 Post(s)
Liked 1,933 Times
The first time my Garmin battery died, I took it down to Walmart and asked the lady at the watch counter to unscrew the cover. She was able to with her screwdriver, and pointed out it was from a set that was displayed there. I bought the set and replaced the battery myself the next time.
Just MHO, Husky and precision don't go in the same sentence.
Likes For pdlamb:
Quoted: 452 Post(s)
Liked 162 Times
dav
Quoted: 2952 Post(s)
Liked 3,106 Times
I bought at 4iiii HRM last year to work as an Ant+/BT bridge so I could run Zwift through my iPad. Excellent product and you can change the battery with a coin.
Garmin has 2 types of hrm band. The premium one and the "cheap" one.
The cheap one opens with a coin. I've been using it since January 2013 and it's been flawless. Still on its second battery.
I see no reason to purchase the premium band.
I also have a Decathlon Ant+ band and it works OK as well. Also opens with a coin.
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
Been using my Tickr for over 5 years now, batteries last most of the year each. Easy to change. I'm on my third strap. I'm giving thought to the TickrX next time.
Quoted: 452 Post(s)
Liked 162 Times
I got the Wahoo TICKR several days back. It is pretty much a one for one replacement for the Garmin - at least based on early usage. I did not have any trouble getting two different (Garmin) computers to connect to it. And the flashing LED could be handy if there was a connection issue and you weren't sure which end of the system was the problem.
I am assuming that when the time comes, the coin sized screw slot will allow me to actually replace a dead battery using tools that I own which includes 3 (all different brands) 'precision screwdriver sets'.
dave
dave
Quoted: 152 Post(s)
Liked 173 Times
My Garmin HR monitor battery died before my ride yesterday. I use a cheap all-in-one screwdriver from Home Depot that has #000 , #00 , #0 & #1 philips driver bits. The thing works great for Garmin and other devices that use very small screws. Had the battery swapped in a minute or two. If you already have a Garmin strap and want to stick with it this is a lot cheaper than buying a new strap.
Home Depot all-in-one small screwdriver
Quoted: 284 Post(s)
Liked 385 Times
