Anodized rims; removing from brake surface?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Has anyone ever done this with good results? I've removed anodizing from rims before, but only from the entire rim. I never liked the finished result so vowed to not do it, again. However, can you just remove it from the brake track? Is there a good way to do it? Hoping for better braking.
FYI, I'm using early 90's Shimano low profile canti's with Salmon pads. And, yes, they are adjusted properly geometrically at the brake and tuned for lever pull...if that makes sense
Thanks
Thanks
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Brake pads do a pretty good job of removing anodizing. Or if only there was some kind of easily obtainable abrasive paper or fabric...
Likes For cxwrench:
Quoted: 4222 Post(s)
Liked 3,908 Times
The classic method to "dress" a rim's brake track is with a piece of emery cloth between the pad and rim. If done well the portion of the rim "above" the sides will be un effected. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 5840 Post(s)
Liked 2,673 Times
OTOH, if you're talking about hard anodizing, that olive colored finish reminiscent of Calphalon non-stick cookware, be aware,that it's a thicker coating and will take a lo-o-o-ong time to remove even with sandpaper.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
+1 this is the way to do the job if you're too impatient to wait for it to happen naturally.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For Hondo6:
I've heard of people running super aggressive pads to do this. Like ceramic specific pads you would run on the textured ceramic coated Mavic rims, or the WTB speedmaster pads. Both are probably hard to find at this point. My Swissstop pads took the regular black ano coating off my rims in about 500 miles.
Likes For wesmamyke:
Quoted: 511 Post(s)
Liked 646 Times
Thanks
Thanks
Likes For KerryIrons:
Quoted: 511 Post(s)
Liked 646 Times
Thanks
Thanks
Old fart
Quoted: 3598 Post(s)
Liked 3,423 Times
I've used Modolo "Sinterized" brake pads for this. Run them for a few weeks, and the anodizing is gone from the brake track. Leave them on longer, and you'll wear out your rim. Not sure if they were ever offered for cantilever brakes, though.
Likes For JohnDThompson:
Liked 2,673 Times
FWIW - i've been riding on hard anodized rims for decades, While there is some measurable reduction in brake friction, I still have no problems, either locking the rear wheel, or lifting the rear with the front brake. Rain braking is lousy, but I can't really tell whether it's worse than with any of my other aluminum rims.
Rarther than focus on stripping the hard coat, try using "stickier" rubber brake shoes. Think about the shoes on your feet. Your leather soled dance shoes may be very slippery on the varnished wood of a basketball court. However they don't sand the courts, instead players wear shoes suited to it's surface.
Shoes do vary by brand, and even by color within brands. For example, I've found KoolStop grey colored shoes to be a bit stickier then their other colors.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
. . . . Back in the day when these rim "coatings" were popular, you used to see brake tracks with pulsed colors: the slight distortion of the rim by spoke tension would bulge the rim just a bit and as the anodizing wore off, you would have shiny aluminum alternating with the color of the rim.
Wanna guess why I'm manually de-anodizing the sides of a pair of old Araya rims?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
So, what I'd thought of doing was masking off the rims and spokes cutting off tape where the brake surface is. Then spraying a light coat of easy off to the brake surface and then cleaning it to expedite the process. Meh....it all seems laborious. Maybe just stick with the tried and true natural process. It's coming off slowly as it is, I suppose. The other superficially annoying thing is the color...haha! It just hardly matches well with but a couple of color schemes. .
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Commute in the rain and it’ll take half the time.
I wouldn’t recommend any corrosive, you’re likely to end up with pitting, which may be the least of your issues at that point.
Likes For jccaclimber:
Quoted: 97 Post(s)
Liked 294 Times
Does anyone want to try and diagnose the marks on this rim?
Is it an attempt at removal of anodization?
Pattern is consistently even
Around one entire side of rim. Deep enough to just barely feel by, or catch, my nail, smooth enough to hardly be able to tell they have a depth by using a finger pad’s feel.
Bikes: '99 Pinarello Stelvio; ‘85 Cannondale ST500; '75 Austro-Daimler AD-SL; '84 Peugeot PH11; '83 Peugeot PH18; '91 Bridgestone MB3; ‘95 Bridgestone NB26
Quoted: 12 Post(s)
Liked 74 Times
Scratches or Deposits ?
I can’t tell from the photos if those are patterned surface scratches from grit imbedded in the brake pad or bits of brake pad material transferred to the rim … or both!
I have found both conditions on some of my vintage rims - remedied (right or wrong) by wet sanding the rims with very fine 600+ sandpaper and a very light touch. It’s a time consuming process and kinda rough on the fingers, but the result is a pretty clean and smooth braking surface. Coupled with new pads, it seems braking efficiency is improved too.
BTW, I’ve also seen a SwissStop block that looks like a medium sized blue eraser marketed for cleaning up whatever it is that collects on the
sides of rims, but haven’t tried it FWIW.
Quoted: 12 Post(s)
Liked 74 Times
