FSA Omega, AKA PITA
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Is it actually seized, or are you lacking adequate torque? IIRC that crank has a self-extracting bolt that needs 40Nm to tighten it....and typically breaking torque (AKA loosening) is a fair bit higher.
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 64 Post(s)
Liked 29 Times
I agree with Marcus Ti that it is probably not seized. I removed an Omega crankset from my old GT Grade, and I had to use a cheater bar on the end of the allen wrench to get it off. I put the allen key through the hole at the end of a large crescent wrench which gave me enough leverage to break it loose.
Liked 14 Times
5 mm allen slot at bottom of fastener has stripped. I tried cc with the pinch bolts loose and a flat blade lightly inserted to insure the bolt wasn't trapped. Stripped. Hammered a 12 mm into the larger diameter- stripped. I' m thinking hole saw to drill down through shoulder and with the shank still stuck slide the arm off. Also, where should i have put this question?
I was just being silly, since that is the typical solution: Hit it with a hammer. If it breaks, it was unfixable.
bikerbobbbb
Bicycle Mechanics
6
04-20-16 12:28 PM
richeydog
Bicycle Mechanics
47
02-14-16 06:27 PM
