Changing rider position to help lower back pain?
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I just tried some 165 mm cranks, and they were a revelation for me. Very good for hip pain compared to the 170's and 175's I've been using for 30+ years.
I'm thinking the reason they work for that is, my hip is not flexed as much at the top of my pedal stroke when I'm applying power, as it would be with 175's. And when you do something like climbing a ladder, you will find that when the hip is flexed a lot, you have power, but not as much as you do as the leg straightens out, since we have an increasing ability to apply power as the leg straightens out.
So a shorter crank requires less hip flex with each pedal stroke, puts the leg in a more advantageous position at the top of the pedal stroke, and reduces the range of movement required for each revolution. I can really see this adding up over a 50 mile ride that requires thousands of pedal strokes, some under very heavy load.
To my mind, this is a different way of attacking the problem of reducing hip flex, via the crankarms, rather than attempting the same thing by having the rider sit up more, which will cause a whole slew of problems in and of itself by putting more weight onto the seat. Might be worth a try for the OP, especially if the woman has shorter than average legs, she might just need shorter crankarms.
A friend is having back issues and would like me to modify her road bike. We rode a century last year and her back was screaming after 60 miles.
The pain is at the right butt/hip from a pinched nerve. She was told she needs to sit up straighter.
The bike is an older Jamis Ventura 9 speed with Shimano 105 STI brifters. The bars have already been raised and it there are a bunch of spacers on it already.
I'm not sure what to do with this bike, with all the spacers that are already there-- and the stem already has a good rise. I was thinking the drops should be replaced with flat bars that have a rise, which means the brifters would need replacing as well. These Fairdale bars have a 50mm rise and also sweep back as well The bikes a 3 x 9 so I think could use these Alivio shifters.
Any other recommendations to change the rider position?
Thanks
Thanks
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
Also, it looks like the seat is setback with that post. Maybe she's comfortable sitting back like that over the pedals, but if it could be moved to a more neutral position then the reach issue on a bigger frame would also be avoided. This set up gives me the sense she looks like Easy Rider when biking.
I adjusted my hips to not press down on the saddle nose 40 years ago ,
but I'm not trying to race, even back in the 70s..
Now I am 70..
Now I am 70..
