best place to order spokes online?
bannned
Bikes: black bike, white bike, blue bike, yellow bike, silver bike
anyone know? specifically looking for a combination of butted standand and straight-pull spokes. replacing the crappy aero spokes on my rd-600. thanks.
Scott
Bikes: Too Many
Good selection and prices.
https://www.biketoolsetc.com/index.cgi
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
I order all of my spokes from https://www.lickbike.com
Have always been in stock/available and brass nipples are included.
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
Nashbar has Wheelsmith 15ga for $7/20, 14ga for $8/20, 14/15/14 for $12/20, and *black* 14/15/14 for $18/20. Pretty good prices if you ask me, and they come with Wheelsmith brass nipples (I've ordered them before). https://www.nashbar.com/results.cfm?c...it=y&pagename=
ride, paint, ride
+1 for Nashbar, at those prices. I got enough 14/15/14's to build four wheels, at the best price I've ever seen for Wheelsmith (the only spoke I'll use--much better than DT IMO).
How do different brands of spokes differ? I've only used Wheelsmith straight-gauge and they work well for me. What's wrong with the DTs?
bannned
hey thanks all... however, none of these places offer direct pull spokes. I might be SOL in that regards eh?
Radfahrer
TH 1.81 (133kg*62)
TH 1.81 (133kg*62)
ride, paint, ride
DT's are still pretty good spokes, but they make the elbows longer than Wheelsmith does. The distance from the spoke head to the bend is unnecessarily long, and they did this to accommodate machine building of wheels. That longer elbow makes it more likely that the elbow will flex more with each wheel revolution, hastening the fatiguing of the metal and causing spoke breakage. Peter White used to have a page up which detailed this problem, but that page is no longer up on his website. He switched to Wheelsmith specifically because of this issue, and uses them exclusively now. I compared both DT and Wheelsmith, and found that the workmanship on the Wheelsmith was jewel-like in it's finish and they just make a gorgeous wheel. I found all the claims that Wheelsmith makes on their website, to be absolutely true. DT can also be used successfully, but I'd recommend spoke washers to take up that extra elbow length. The bad news is that spoke washers are very hard to find.
I recently had problems with spokes breaking on the elbows on the 32H rear wheel of my commuting bike. Most of them were on the left side. It's laced 3-cross. After 5 broken spokes or so, I got fed up and retensioned the wheel from scratch. I inspected the spokes and several had notched elbows. The notches looked kind of like what happens to a paper clip after you bend it too many times, which makes sense based on your explanation.
I should check what brand of spokes those were that were breaking...
ride, paint, ride
You may need to replace all the spokes to keep this from happening, since they are probably all compromised now, at least on the left side. My personal rule is that three broken spokes = three strikes. Time to rebuild the wheel! And of course, get the tension as high as possible for your rim, and even tension from spoke to spoke. If you can respace your hub at all to decrease the dish, that helps too. It all depends how much room you have between your outboard cog and your dropout.
Bikes: Klein Quantum Pro
Yep, that's where it happens a lot due to undertensioning. The left side rear is always prone to undertensioning, because of the dish. Even when the right side has good high tension, it can be difficult to get enough tension on the left side. The more extreme the dish, the more of a problem this is.
